problem with nacra450 center beam
Technical Help
3
Posts
3
Users
0
Reactions
1,867
Views
You may have a bit of corrosion on the threads, or one or two threads are chewed up. I would find someone with a tap & die. Run the bolt through the die, & the tap into the fitting in the hull.
Put some oil on for lube. Run it in straight for a few turns then back it out, repeat.
If it is a thread or two that got chewed up, this will fix it.
As Bacho said, don't try to force it, you will just end up chewing up all the threads, creating a bigger headache.
Don't forget to put some grease on all the bolts when you re-assemble.
Edited by Edchris177 on Jun 10, 2014 - 09:09 AM.
Posted : June 10, 2014 3:08 am
Forum Information
- 736 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
