remove tramp on a nacra 450
Technical Help
2
Posts
2
Users
0
Reactions
2,049
Views
The beam may be bedded with 5200. If you have removed the 2 bolts and it won't budge, I would use a board and place it under the beam in a way that it supports the boats weight. Make sure the hull cannot drop too far without being supported as well, but leave a gap for it to drop. Then use a heat gun inside of the beam to loosen the adhesive and slowly work it off. You might try to pass a thin wire through the bed.
Posted : March 2, 2014 12:07 am
Forum Information
- 1,858 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
