Spinnaker Set-Up Pix
Here are a couple of examples using a Nacra 5.5 not exactly the same but the general idea is there. One uses a bag launch the other uses a end pole snuffer. Mid pole snuffer rigs are what everyone uses now.
http://home.comcast.net/~ragenpl/nacra/NACRA_55_SLOOP_SPINNAKER_USING_INTER_20_SNUFFER.htm
http://home.comcast.net/~ragenpl/nacra/nacra_spinnaker_1.htm
I made my spin setup on my P19, pics can be found at:
http://www.thebeachcats.com/index.php?module=pictures&g2_itemId=72912
The design was done after studying the manuals for the N20 and the F18 (all MFG's)
Some quite good technical writeups can be found at:
http://www.hobiecat.com/support/tech/sailboat.html
Materials:
Spin pole was bought at a local aluminum supply house, 24', 1.5" .065" sidewall T61 anodized and cut to 12'6"
Hardware from West Marine, wires I made at Wast Marine, end caps and pin from Murrays.
A mid pole F18 setup would be ideal for you IMO
Good Luck
ButchG wrote: I made my spin setup on my P19, pics can be found at:
Materials:
Good Luck
Thank, saw what you did and it go me to thinking.
- 346 K Posts
- 1,655 Online
- 31.2 K Members
