Telltails on Spinny
10 Users
12.5 K Views
(@waynemarlow)
[#29088]
Has anybody fitted telltails to their Spinny. The Spinnys are getting flatter and flatter and it must be getting near to a sail shape like a reaching sail where telltails are a method of setting the sail.
If you have had them on the spinny, where is the best place to put them ?
Posted : May 22, 2012 6:42 am
pgp
 pgp
(@pgp48)
I can't sail without them. My first spin did not have them. When it came time to replace it, the new sail had them, and my down wind improved dramatically. Immediately rumors began to circulate that I was cheating. People
new for a fact
my spinnaker was over sized. In fact it measured slightly under sized.
That's the difference tell tales make.
I'm scheduled to sail Wednesday, I'll try to remember to get measurements and some photos.
Posted : May 22, 2012 6:50 am
(@ringo1508)
I bought my Falcon in January and Matt ordered a red spin from Glaser for me as I didn't care for the purple ...it came with telltails. I think they've been like this for a while now though as I am pretty sure it was Matt telling me to watch the leeward telltail in order to not over sheet (a huge problem I had starting out.) I love it! Now whenever I have someone new on board I just tell them to immediately sheet so thar the leeward one is flying and not to care about the windward one ...then to make sure the luff curls slightly.
Posted : May 22, 2012 8:24 am
(@waynemarlow)
Sort of what I suspected, Pete piccies please or some dimensions approx. how far from the front of the sail and how many, thanks.
Posted : May 22, 2012 8:29 am
(@ringo1508)
There's just 2: one on each side. I believe mine are around halfway up the luff or just below that, and maybe a foot back. If Pete doesn't beat me to it I'll measure mine and post.
Posted : May 22, 2012 8:31 am
(@ringo1508)
Check out this pic. You can see the leeward one half way up.
http://4.bp.blogspot.com/-G6MzhlOVn... _128571883832583_1017506_338626493_n.jpg
Posted : May 22, 2012 8:34 am
(@ringo1508)
This is a perfect view. If you look at the very top of this picture, you can see the tell tails.
http://4.bp.blogspot.com/-o71UtjSc67E/T6FdOBRHOjI/AAAAAAAANWc/1uSVnwgR550/s1600/7.jpg
Posted : May 22, 2012 8:36 am
pgp
 pgp
(@pgp48)
My sails are AHPC, there may be something on their website. But there are three sets and Robbie D. told me to watch them all! That's another reason to have four eyeballs on the boat. <img src="<>/laugh.gif" alt="laugh" title="laugh" height="15" width="15" />
Posted : May 22, 2012 8:39 am
Gilo
 Gilo
(@Gilo)
One set does the job just fine. They are there to get the spin close to perfect and then you ease out as much as you can to hit the sweet spot. Could be only 5 centimeters more, but the last centimeters really matter with the spinnaker.
Gill
Posted : May 22, 2012 2:05 pm
scooby_simon
(@simonJlongstaff)
Wayne; I had 3 on both my Spis; about 25cm back from the luff; one about 1m up from the tack; one about 2m from the head and the third 1/2 between the two.
Posted : May 22, 2012 3:01 pm
Smiths_Cat
(@Smithscat)
Usually best performance is achieved just before the luff is collapsing, hence sheeting out to the maximum and than slightly sheet in does the job. In this case the windward tell tales are stalled. However with a straighter and more tensioned luff this rule may be obsolete.
The real accelerator is to sheet the main correctly while under spi.
Cheers,
Klaus
Posted : May 23, 2012 2:34 am
pgp
 pgp
(@pgp48)
How do you sheet your main, under spi?
Posted : May 23, 2012 4:56 am
(@ringo1508)
I've noticed what Klaus has said. After I've gotten the spin sheeted to what feels right and look up, sometimes my windward tell tales are still floating up on my main, so I sheet it in to correct and it speeds up quite a bit.
I've been told that if it gets too crazy on the water that I can just over sheet the main to stall it and drive deeper, to try to avoid crashing (in excessive winds.)
Posted : May 23, 2012 9:34 am
Tony_F18
(@Tony_FX1)
Sheet with your teeth.
Posted : May 23, 2012 11:22 am
pgp
 pgp
(@pgp48)
I know a guy who did that and pulled out a tooth.
Sorry Wayne, no pictures.
Measuring from the tack (sorry)head down and the luff inward:
6' x 13
13' x 19
19' 9' x 23"
Posted : May 23, 2012 3:24 pm
(@_removed-account)
Four Star Admiral Registered
One on each side is all you need for sheeting. 3 on each side lets you adjust your sheet leads and hoist to the kite and conditions.
Posted : May 23, 2012 5:06 pm
pgp
 pgp
(@pgp48)
I'll keep that in mind, thanks.
Posted : May 23, 2012 5:47 pm
danielt1263
(@danielt1263)
I have three sets on mine too, but I only really look at the bottom set. I can't even see the top set from the helm.
https://www.dropbox.com/lightbox/home/Photos/New%20Boat?select=Boat2.jpg
Posted : May 23, 2012 7:31 pm
(@waynemarlow)
Put a set on quickly last night, just 1 on each side about 1/2 to 2/3rds from the top, quite surprised at how well I had been doing without them on. Setting the spinny normally and looking up and telltails are flying nicely. Quite surprised at how wide a band of tension you can have on the sheet before they really start to not fly though ?
I seemed to have adopted the let the sheet out until the luff starts to fold and then on with a bit of tension and the woolies are flying perfectly. I would guess though if you are new to the game then working the other way, getting the woolies to fly would be more indicative and quicker to learn.
I think Scarecrows suggestion of putting 3 sets on though is very valid as I have no real idea whether the lead angles are correct. Next step.
Thanks for all the info guys.
Posted : May 24, 2012 3:48 am
Smiths_Cat
(@Smithscat)
a) double handed
b) single handed, hiking. Tiller extension dragging thru the water. Let go briefly the tiller/crossbar, adjust the main with the traveller. Grap the tiller/crossbar again and go on sailing.
c) single handed, trap'ing. Don't know, cant touch it. Set the treveller right before going out...
Cheers,
Klaus
Posted : May 24, 2012 1:10 pm
(@_removed-account)
Klaus,
there is another way but you'd have to wear a strap style trap harness not a nappy style.
Posted : May 24, 2012 4:37 pm
(@ringo1508)
Originally Posted by Scarecrow
Klaus,
Posted : May 24, 2012 4:38 pm
 Karl
(@sogncab)
Singlehanded and sitting on the boat I butt cleat the tiller extension, and use my free hand to sheet the main.
Singlehanded on the wire? If I remember, (which is rare), I lay the main over the top of my foot, cleat the spinnaker, adjust the main, pickup the spin sheet and keep trucking.
Posted : May 24, 2012 6:48 pm
(@_removed-account)
Klaus,
The scene is set, a dark night, cold wind blowing, campfire flickering, stars twinkling in the dark sky.
Three cat sailors sitting on the beach by a campfire, one from Australia, one from South Ifrika and one from New Zulland. Each embroiled in the bravado for which they are famous. The night of tales begins...
Kiven the Kiwi says,
I must be the meanest, toughest, sailor there es. Why, jist the other day I cipsized in a lake and scared a crocodeale, he came out of the lake and ate sux min who were sailing close by. I grebbed the crocodeale and wristled him to du ground and killed em with my beer hends
Alan from South Africa who typically can't stand to be bettered said,
Well you guys, I pulled up on a beach orfter a 200 mile race and a Namibian snike slid out from under a rock and made a move on me. I grebbed de borsted with me bare hinds and beet it's head off ind then sucked the poison from it's body down in one gulp. End I'm still here today
Terry, the Aussie remained silent, slowly poking the fire with his penis.
Posted : May 24, 2012 7:38 pm
 Karl
(@sogncab)
Good modification!
Posted : May 24, 2012 8:19 pm
(@waynemarlow)
Always knew Aussies were a hot headed bunch <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
Posted : May 25, 2012 4:32 am
scooby_simon
(@simonJlongstaff)
Wayne; how far back on the sail are the tell tails? if too far back they will always be flying !
Mine were about 25 cm back and a few CM of sheet would make a massive difference to speed!
Posted : May 30, 2012 6:01 pm
(@waynemarlow)
Mmmm interesting as I would say without measuring, probably closer to 300mm.
Looking at my spinny last night it would seem very very flat along that leading edge for about the first 100mm or so, not a good looking leading edge at all. As soon as you release the sheet to the point the luff collapses, that whole 100mm and next 100mm in the middle section folds. How much change in shape can you get by tightening the luff tightening lines ?, surely just raising or lowering spinny pole will do the same.
Posted : May 31, 2012 4:33 am
