curved dagger boards
I think a list of approved GPS devices is a good idea, at the moment magnetic sailing compasses are more expensive than their GPS counterparts anyway (Tacktick etc).
Not aware that there are any F18s with curved foils.
With boats are expensive enough as they are and declining fleets I'm not sure if that is the way to go.
With regards to GPS enabled devises.....things like the Speedpuck will not change the game. The guys at the front of the fleet will be the same guys whether or not they are using one. Same for the mid fleet and back of the fleet groups. Personally, I tried sailing with a tack tick for a while. While racing though, I hardly ever looked at it. After a tangle with the spin sheet, it went over board. Never bothered to replace it. Results certainly have not changed as a result.
Curved daggerboards are another story. The council could, potentially, make every F-18 currently sailing obsolete. If they want to bring about the end to the class, then go ahead and approved curved boards. Personally, I think it would be crazy to approve. If there are sailors out there that want to sail boats with curved foils, go by an A-cat, F-17, or Nacra F20. Leave the F-18's out of that game.
You can see the boat. Check this out. But please....DO NOT make it F-18 class legal!!!!
http:/
Would this then doom the F-18 design to obsolescence?
Sort of like when the N20 rule kept an outdated sailplan?
But I guess there are still many huge fleets of outdated designs (laser, Opti, Star, 420, etc)
F-18 was never meant to be cutting edge. It was meant to provide a level playing field between manufacturers with controlled development that would keep it
affordable
to the sailors. So far, that plan has worked brilliantly.
F-18's could be built full carbon, carbon spars and beams, curved foils, etc. but that would defeat the purpose of the class. If that's the kind of boat you want to sail, go buy a Marstrom 20. That is not what F-18's are meant to be.
Jay, the N20 didn't die because of the
outdated
sail plan! If that were true we should have seen the N20 resurrected from the ashes when the p-cola group created a new class allowing sail plan development. You also need to ask yourself why the F20C class hasn't blown up.
Many consider the F18 obsolete right now and so freaking what! I didn't join the F18 class because of its light weight and carbon fiber!
Like Karl said there are several curved dagger board options out there, leave the F18 alone. I for one feel very comfortable that straight daggerboards will NOT be the classes downfall. When racing class do we really give a sh!t if we don't have the latest go fast gizmo? There is a lot to be said for stability. When someone lays down 20K+ for brand new boat only to find out that they need to upgrade their boards at the tune of another $2400 can get you thinking, is this class worth the expense?
We also need to ask ourselves who is bringing the proposal forward, who do they work for and are they really considering the impact to the weekend warrior, which by the way is the core of the class. What is good for the pro's can often be at the expense of the amateur.
I put together a poll for the Eastern Area F18 group that addresses the proposals on the agenda. Mike and I are trying to get it circulated amongst the other areas as well. If you are a US F18 sailor, please fill it out and pass it along to your fleet.
https:/
https:/
Jeff,
The first question under F18 Branding needs a
none of the above
option.
As far as I know curved daggerboards for the F18 are not on the agenda.
I think the agenda point is about the observation that in the today's handicap rating systems (e.g. Texel), the form of the boards is not a factor affecting the rating. This is disadvantageous for the F18 when it competes at for instance Round Texel (e.g. Nacra F20, F17).
Over the past few years we have seen the changes in handicap formulae pretty consistently 'hurting' the F18's rating.
Rating committees are 'behind the curve' so to speak on curved boards; that's hurting the F18, and should be addressed a.s.a.p.
The agenda items is pretty vague:
18. To discuss Formula 18 handicap regarding curved Dagger board
Some could argue that the class needs curved dagger boards to better compete in handicap racing. I know it makes me feel unclean to even type that statement but the point is the agenda item is very vague and I'd really like to see what this item really is. As stated though, it's just a talking point at the meeting as you said.
Didn't they just make the F18 rating faster!? If the intent of the curved dagger board discussion is for the International class to go to the various handicap committees and petition that all the curved dagger boats get a rating hit I really think that is is going to fall on deaf ears. I'd also be a little disappointed to find out the IC is getting distracted by handicap racing.
I'll let you in on a little secret regarding handicap ratings... they rate the talent not the equipment.
Oh and the argument that handicap racing results are hurting or helping the class is rubbish! When was the last time a Hobie 16 won Texel? Yet strangely the class survives. Please please please lets not get sucked into the handicap racing vortex.
The calculator is being revised again now. As Dave points out - the adjustment is to make the formula match the racers results.
The discussion of a formula based system is basically BS. The A class long ago left handicap sailing where they used this, as the correction factor for them was so severe, there was no way they could ever correct out. Note the A class is going strong worldwide without having to tag along with some handicap system.
Currently there is no adjustment in the calculator for curved foils. If this falt in the calculator stands another season (and you think there is an advantage to having curved foils) then this would be a free ratings basher - like they need another one of those.
You guys have a strong class, why is there any discussion about screwing it up for some moving target. I though that was the whole point of a formula/box rule class was to have equalracing in a fleet that was not subject to the whims and problems of the handicap racing.
Handicap racing isn't something the F18 class needs to be worried about. Most racers don't really care that much either (ex: Alter Cup). Besides, the F18 is the reference boat under some handicap systems (SCHRS).
The more important question the class should be asking is how to handle future development. Besides continued sail and aluminum mast section improvements, it could be argued the class is tapped out on gaining performance through hull shape and current foils within the existing rules. I think that is just fine and I bet the majority of sailors would agree, but there is always the concern that some wiz bang new boat shows up on your beach and beats you to the bar a few miles away.
Sam,
Lots of F18 sailors attend regattas like Texel with the intentions of winning, therefore the handicap system is very important. We don't need to worry about it a lot but it is something we have to keep up to date. I believe Eurocat and some other major regattas also have a distance race that's scored on handicap? Not to mention our little races over here.
I disagree with your perception that the class is tapped out with hull shape and current foils. Boats all have different chord lengths, shapes, and etc. If it was tapped out everyone would be using the same blade. In addition, manufacturers are still toying around with where the best placement of the board is. While the boat is most user friendly with it at the shroud, it's still not known if that is the fastest place to have your board. There's even been talk about having it in front of the beam but no ones figured out how to keep the load off the rudder in this situation. But if someone could who knows if it would be faster.
All the developments coming through these days are minor but that's what is keeping the class alive. I definitely wouldn't say the development is done anywhere, but it is hard to imagine any kind of game changer coming along which is exactly how we want it.
- 7,122 Online
