Hobie Tiger weight
First you start with the following fact.
"The Pints a pound the world around"
There are 2 pints in a quart. A quart of beer therefore weights about 2 lbs. Depends on the spesific density of the beer and the temp in the room. Americans drink beer when it is cold and more dense.
Europeans being far less cultured, drink their beer at room temperature, ie less dense. Now Europeans drink metric beer. As we all know, the Germans drink beer from the time they are 8 days old and can drink more then us. Therefore they buy beer by the liter. Now being a practical people and realizing they only had 10 fingers, they invented the Metric system. Since a liter is 1000 ml and a ml of beer at room Temperature weights about 1.009 Grams a liter of beer weighs 1000.9 grams.
Add to this the fact that a fine malt beverage Called Colt 45 was so named because there are 0.45 Liters of beverage in a 16 OZ can, and the following conversion factors can be arrived at:
1 electron = 9.110 e-31KG
1 lb=0.4536 kg
1kg=2.205 lbs
so 180 kg= 396.82 lbs
IF your Hobie tiger was make up of just electrons, there would be a buttload of them.
Eric
Congratulations with the new boat. You can find the website at http://www.naf18.com/.
Bob O’Connor
@palm.net">Tiger852@palm.net
Remember, a NAHCA class legal Tiger is a NAF18, but a Tiger modifed to NAF18 is not NAHCA class legal.
If you show up at Midwinters or NA Championships(Mega Event) with a NAF18 modified Tiger you will have to change it back if you want to race in the Tiger class.
Save all your parts.
Hi Mike!
There is a proposal to add a self tacking jib to the ONE DESIGN Tiger, among other modifications.
These can be found on the rules forum at
Hope to see you soon!!
Roger, you have my statement backwards.
A Hobie Tiger Class compliant boat IS automatically NAF18 Class compliant.
I was trying to point out that IF you modified a Tiger to some NAF18 rules, it COULD become non-compliant to the Tiger class rules IE: blades and boards by Hobie Corp., no tapered lines, etc..
Funny thing, I am reading the Tiger class rules and it says that "Replacement blocks or fittings shall not be constructed of exotic materials such as carbon, titanium, etc". Many of us are using the new Harken carbon blocks and they are CHEAPER, lighter and stronger than the old style blocks. EARTH TO HOBIE!!!!!
Hobie Tiger is a one-design class but as soon as hobie decides to go with new spreaders, new squaretop, selftacking jib, new boom outhaul setup and other goodies; Hobie corp itself just changes the rules of the ONE-DESIGN class to allow these changes.
I say "ONE-DESIGN" is only a lip service with respect tp Tiger. So forget this "One-design" crap and go formula all the way.
Wouter
Sam,
What do you mean by your statement, "Many of us are using the new Harken Carbo...", did you get a Tiger? Is there something you aren't telling us?
Anyway, Harken Carbo blocks are not made of carbon fiber. Its just a fancy name for the new type of plastic composite that they mold the blocks out of. My Tiger came from the factory with some carbo blocks, so how could they be illegal? Its my understanding that Harken will be phasing out the old blocks anyway.
Dennis
Wouter,
How does updating equipment on a boat make it no longer one-design? If that is true, then how does the Tornado class consider itself "THE" one design catamaran? They have been updating the Tornado for over 30 years, yet they are still considered one design. Am I confused, or should the Tornado class be called Formula 20 with a hull shape and foil restriction? Because those are the only things about that one-design that haven't changed over the years.
Dennis
Dennis,
You know I don't have a Tiger, but I am using carbon blocks.
And YES, thay have carbon fibers in them. That is why they are called COMPOSITE. I spoke with Peter Harken a few months ago and he explained that they had finally figured out how to mold products with long fibers in them. He specifically stated that you could burn off all of the plastic and end up with a pile of long carbon fibers.
My quote was from from the IHCA Tiger Class Rules website.
My comment was pointing out the fact that their rules don't agree with the boats they sell.
Which is class legal?
Whatever you buy from the dealer or whatever complies with the rules?
If someone without carbon blocks protests you at the Mega Event, can you PROVE you bought the boat with them on it and therefore ARE class legal?
What if you replace just ONE of your old blocks with a carbon, are you still class legal?
Remember, this is the bunch of idiots who wouldn't let us splice smaller lines and now we can't even use the tapered lines.
It's your boat, run what you want.
http:/
From Harken Website
We designed our 75 mm Carbo AirBlocks for speed. Made of high-strength engineering plastics, the single weighs in at a very light 6.9 oz (195 grams) - including the shackle. Doubles and triples aren't much more! The strength-to-weight ration on these blocks is extremely high. They are the first all-plastic blocks with a safe working load of 1,200 lbs.
End Harken web site
Note: the last sentence "First All-Plastic Blocks "
I wonder why they would not want to advertise that there is carbon in them? In fact when I do a search for "carbon" on their web site, I only find reefing and furling systems for much bigger boats.... I don't understand? Sam, am I looking at the wrong blocks?
Bob O
Tiger 852
The Tornado is often considered to be a Formula class in EU. For example multiple manufacturers can make tornado's and sell them for racing. However Marstrom competed all others out of business. The tornado class has very strickt formula rules and is strcikter than say F18 for it rules on hull shape too.
Wouter
Sam,
FYI for the future
Take Care
From Harekn Tech Support.
Bob,
It is a reference to the color not the element. The blocks are molded from
a long grain plastic of a proprietary material but they do not contain
carbon.
Jim Bourne technical service,
----- Original Message -----
To:
Sent: Tuesday, April 09, 2002 11:30 AM
Subject: Carbo AirBlocks
> Hello,
> Do Carbo AirBlocks have carbon in their construction? My class rules
state
that I can not replace blocks with blocks made of Carbon.
> Thank you for your time.
> Bob O'Connor
Actually, almost all plastics and rubbers that appear black, or other dark colors, contain Carbon black for UV stabilization.
The Harken catalog even states that their Big Bullet, Dinghy, 2.25" and 3.00" blocks have "Carbon-black filled balls" and "UV stabilized Delrin sheaves and cheeks".
Are these considered deadly "carbon blocks"?
The point I am trying to make is that some knucklehead at Hobie thinks up these arbitrary "rules" and has them approved without properly researching them through.
Here is the rule in question:
"6.6 Replacement blocks or fittings shall not be constructed of exotic materials such as carbon, titanium, etc."
In the first place, carbon is not so "exotic" anymore.
By using the term "Replacement", the onus is on the boat owner to prove that the blocks came on his boat.
What if they are not the original purchaser of the boat?
Now in reality, if every Tiger shows up with the same "carbo/carbon" blocks, then no one will protest, but the screwed up rule is still there.
I have done a lot of contract administration and I just don't like goofy rules.
HEY, a least the Tigers and Foxes are allowed to use an 8:1 mainsheet 🙂
Most of us are stuck with a 7:1 or lower 🙁
who cares? is there any racing going on? or just idle chat and politics? i am ready to switch to a monohull where i can actually go one design racing every week and talk about RACING, not read two pages of whats in some blocks, or what changes may or may not occur. get focused guys or you are going to lose any interest you may have left. It is spelled R-A-C-I-N-G and there doesn't seem to be any of it going on. what am i supposed to do with my new Tiger? go look at the blocks and wonder whats in them? thats all its worth right now because there are no RACES that i can even enter, as an F18, NAF18 or whatever you are this week, and we all know where the Hobie fleet is heading. Yes i'm bitter, that is alot of hard earned money that is just sitting on the trailer. an expensive daysailer. i post as anonymous, but i say the same things to anyones face. who says this is not important, but that is posted here might wake some people up. If i am wrong i'd love to hear about the west coast F18 races that are scheduled, or where there might be some 20-boat (or even 10-boat) Tiger starts. I did my part, i bought a boat. I will show up at any race and pay my money. I will work committee, donate my power boat, whatever it takes in addition. But lets go RACING!
Dear Tiger sailor,
You obviously feel "ripped off" and mislead because you were sold a Tiger and apparently promised One-design or Formula racing. This is wrong of the dealer, however quite naive of you. There simply are not enough Tigers around YET to have a one-design class. Nor are there enough NAF-18 class members to have a formula race, especially on the West Coast.
The largest pockets of Tigers are currently in the NY area and in the Georgia/upper Florida area (Hobie Div 9). Even in these pockets, the numbers are not proven large enough for true one design racing (4-5 boats usually). As far as the NAF-18 class, it is strongest in the Mid-West, near its "wizard" Mark Biggers. The NAF-18 guys recently received new Nacra F-18 boats for 4-5 NAF-18 members. Hardly a great "fleet".
My point goes back to my previous posts, stating that racing these classes, as well as the F-18HT, will be best within the Portsmouth Class (scored together and separately). The numbers are not there and I don't see these classes gaining necessary DENSITY (as opposed to total numbers) to acheive more than sporatic one-design or formula racing. The F-18HT class stands the best shot of acheiving this density in the East Coast areas and they are a waiting for the next two loads of customer's boats to acheive this. Even then, the HT guys plan to sail all but their North Americans, W-1000, and World Cup within handicap class (scored separately and together).
Group ALL THE BOATS into classes of similar performance, and score them under handicap and separately as one-design or formula class (for 5 or more 1-designs or formula boats). IMHO, this is the best way to nurture catamaran racing in the USA.
Thanks for the input... I see your point. It may have been naive of me to buy and assume I could race it, and now I'll just do the best I can. I want to race "one design", and given the realities of this I thought "one formula" was a good compromise. Looks like it may not happen here though! Part of my decision was based on other sailors saying they were going to buy; then they didn't. It's a fun toy anyway and if this is my biggest problem in life then I'm doing well, right? Thanks again, I'll stop whining now and try to do some sailing. Hope the east coast boys realize what they have... sailing this boat I just drool over being able to race it with the chute up in 15-20... enjoy it guys!!
- 740 Online
