Stepping the mast
Hobie 16 Forum
4
Posts
3
Users
0
Reactions
4,718
Views
The stepping link stops the base of the mast flying up out of the base when you lower the mast. If you don't use it, make sure you have someone holding down the base of the mast very securely unless you want your mast to crash down. Since I don't actually use one, I'm not sure if it helps keeping the mast in line, however I doubt it.
Murrays website is www.murrays.com/
Hope that helps
Schobiedoo
Posted : September 15, 2003 10:16 pm
Forum Information
- 5,108 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
