The standard wingnet rail is 50mm alloy tube with a 3mm wall.
I decided to make a wing shape for the rail so it would be more comfortable to sit on.
I drew up a modified wing mast shape, laminated some corecell foam and Mark was good enough to machine it to the shape on his CNC machine.
It was then sheaved in 4 layers of carbon and a light layer of glass.(All under vacuum).
I was very happy with the result as it came out the same weight the alloy would have been.
Below are a couple of pics.
I forgot to point out that I moved the rear bulkhead, ie- the one imediately in front of the transom below the **** floor, forward a little and put in a hatch.
This is to provide plenty of room to stowe a stern anchour when in cruising mode and make fitting that compartment out for water ballast, for racing, a little easier later on.
Florin, a friend of many years, flew in from Europe 7 weeks ago to help me with work on the boat.
He has made a huge difference, with the two of us, working 8am to 7pm 7 days a week to get the boat to the stage it is at now.
In addition to that, at night he and my wife Terri have been working on a name and graphics.
So getting the graphics on the boat was a big step forward for all of us. Below is a pic of the graphics being put on.
BTW:- this was the boats first outing and a chance to see how it handles on the road.
Also below is a pic of a couple of blocks that Florin made for my down haul system that will run inside the boom.
The last pic is the first standing of the mast.
Folks,
It has been a long but enjoyable journey from the purchase of the plans.
Lots of friends have been there to help me along the way.
First mention has to be Ian Farrier for supplying such detailed plans and endless support over the years.
My wife Terri who does not even sail. I could not have built this boat without her support along the way, and with significant input regarding the aesthetics.
Mark with his CNC machining, laminating and radical ideas to push the envelope to produce a more refined end result.
Jack was always available when I needed a hand laminating and offering practical advice based on experience from his own boat build.
Peter, along with many of the guys that I ride with, when a big job was on or I needed to move hulls around.
Richard, either by lending me specialised tools or borrowing them from someone.
Florin, with his CAD skills to help work stuff out just to make things easier, not to mention flying 19,000km to work for 6 weeks, 7 days a week, 10 and 11 hour days to get the boat on the water. All just to see it sail.
Yes, the boat is now on the water. Still lots to do to finish her off but she does float and does sail.
Following next couple of posts are just going to be pics.
Well done Phill, The finished boat looks great. When you emailed me and said that you where doing 7 knots in glassy conditions, I thought it was under sail not motor <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" /> <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
Richard
Sorry Phill
From the angle you are sitting and the angle that the photo is taken from it looked like a motor wake out the port side of the boat.
I have now seen the error of my last post.
Sorry
Richard <img src="<>/frown.gif" alt="frown" title="frown" height="15" width="15" />
To get the boat on the water I didn't have much in the way of sail tuning and setup. I'll now go through and fine tune all the control setups. My first little project was the main halyard. I have a 2:1 main halyard but only ran a 1:1.
The preferred fitting between the sail and halyard these days for this type of boat and 2:1 seems to be the Tylaska H8 halyard shackle with a breaking load around 3600kg and a cost of up to 178 dollars. I am going to make my own halyard shackle from a low friction ring by Ronstan RF8090-16 for $23 and soft shackle that I will make from 4mm dyneema with a total cost of around $25 and a breaking load of over 5,700 kg.
My first attempt used 1250mm of 4mm SK78 dyneema with a 250mm bury . The length of the bury was to ensure there were 4 thicknesses of dyneema through the eyelet in the sail. (this link will show how to do this type of soft shackle- http:/
When I started this project my objective was to build a strong stiff boat because I mainly want to do coastal sailing as opposed to closed waters. I chose to build in the heavy glass option for strength knowing that it would end up being heavier than if I used the same methods in the lighter glass option or even carbon.
I knew that the day would come that I would have to come to terms with the consequences of that decision and get the boat weighed. Well that has happened. I bit the bullet a couple of days back and weighed the
Mad Hatter
. It has come in at 920kg. I just missed my target of 900kg. Still if you compare this weight with similar boats it is a pretty good weight.
Anyway we took the Hatter out during the week and I checked how fast it would go under motor. At 3/4 throttle (being a new motor I didn't want to go above that until run in) it sits on 8.5knots in flat calm conditions. Just above idle its 4.7knots.
Below is a pic of The Mad Hatter patiently waiting on the Gosford waterfront while her crew had a coffee before the day's sail. The sea breese started at 5 knots and slowly built to 10.The warm sunny day gave a further glimpse of what is in store with summer just around the corner. It all made for a most enjoyable day with the boat feeling light and lively. The Hatter sat on 13 to 14knots once the breese filled in and hit a top speed of 16 knots for the day with just main and jib. I can't wait to get the screecher rigged and really wind it up.
I thought I'd add the pic below just because I like it.
A top sunset to finish off a great afternoon's sail .
The Mad Hatter and friend's cruising cat sitting on moorings as the sun falls below the hills.
Rolf,
Life and the boat are great but as far as having
time to enjoy the fruits of my work
. If only it were that simple.
Apart from the occasional sail, my time is mostly taken up with finishing little details so I can really enjoy the fruits of my work during summer.
It will all be worth it in the long run. This is by far the nicest boat that I've sailed. It is fast and comfortable and light to steer. It accelerates like a sports car and seems to handle like one too. It tacs like a laser, not only with full rig but even when sailing upwind under jib alone. It's all so easy and bodes well for the summer ahead.
Great to hear!
And you even have a shelter for the stradivarius. Much better to have the boat there rather than the car <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
It sounds as if you already enjoy the boat - and is ready for more once spring is there. (I forgot that you have
winter
in Australia at this time of year.. )
I know Ian Farrier used to have some kind of trend chart on his site for how many working hours each
personality
needed to complete their building projects. From the very fast carpenter who went saling after a year in a basic boat to the cabinet maker who spent the rest of his life in the boatbuilding workshop. Have you considered where you placed in between those extremes?
Rolf,
I decided before I started this project that it would be the last boat that I build so I planned on taking my time.
Time wise I've been much closer to the cabinet maker than the carpenter. I rarely considered the time a task would take only the method versus the result.
So it has been a massive investment of time but I'm happy with that investment.
personality
That graph is a bit optimistic. I can't see a person building an F-85SR in 2000 hrs. Especially the beams and the folding mechanisme, including the reinforcements in the hull, are very time consuming. I've allready put in more than 2500 hrs @450/year and I still have about two years to go.
I know vacuum bagging takes more time, but still...
Phill,
I guesstimated that you would tend towards the cabinet maker from how I know you <img src="<>/laugh.gif" alt="laugh" title="laugh" height="15" width="15" />
Doing things properly takes the time it takes. I still have a mini-tractor in my garage with from 1 to 10ish hours spent every week. Once it is out - I have some more boatbuilding to do etc. As we discussed several times before - the journey is the goal and the real experience.
Unfortunately - not everybody understands or accept this. Especially friends and family tends to shake their heads at my priorities.
Nico - I dont know, but if a rough finish is accepted, quick and dirty methods, buying pre-fab materials , very basic fitout and one have experience from similar projects - It is surprising what can be done.
The actual build time serves to calculate the cost, but it is the passing of the years that remain in our memory.
This thread started in 2010, so it took you 6 years to build the
Mad Hatter
It took me six years to build a boat of comparable dimensions and features with the aid of a shipyard and a professional.
You did great! Congratulations!
Luiz
The Mad Hatter sailed in its first regatta last weekend. The 21st Lock Crowther Memorial Regatta hosted by Royal Motor Yacht Club Pittwater. As I only have the boat up to Cat 7 safety standard I could only sail the in shore courses scheduled for Saturday and Sunday. The Saturday wasn't only blowing dogs off chains, the chains also blew away,with winds gusting over 40 knots the racing was cancelled. The Sunday was a much better day for sailing and below is a report.
We just finished the Lock Crowther Memorial Regatta. This is the way racing unfolded as seen by Mad Hatter, my recently launched F85SR.
Being a new boat, we had not raced seriously before and had no idea what was ahead. Personally I just wanted to have fun, and hoped someone would take a good pic of the boat over the weekend.
In a light breeze we started the first race in the pack with the fleet and soon pulled out a lead that made our jaws drop, working up the eastern shore. We had noticed some boats started tacking to the other side, and figured they were looking for a fresher wind line but they kept going. When we finally checked the map we found we had completely misjudged the position of the first mark. Post race analysis of the tracker showed that we had sail for 6 mins past our lay line. Once the light was turned on, we pulled the screecher up and kicked up our heels to get across from the eastern shore to the western shore where the mark was actually located. We still rounded third boat just behind Quickstep (a 40ft racing cat) and a Sprint 750 with Evil Gnome (F85) very close behind, also having overlayed the mark. As the breeze started to fill in a bit more we managed to pull away and kept building the lead as the race progressed. This is where the 'but' usually comes into the conversation 'but' not this time. We finished 6 mins 22 secs ahead of the second boat, Evil Gnome.
The second race was in a freshening breeze. We got boxed in at the start by some big boats, with both Quickstep and Evil Gnome getting off the line much better. By the time we got to Lion Island we had managed to reel Evil Gnome in, but not Quickstep.
Rounding the island we hoisted the masthead A0 and even though Quickstep had several hundred metres on us we pulled her in and flew past. Rounding the bottom mark well ahead, we started cranking everything on to work back towards Lion Island but the sound of carbon cracking alerted us to the fact the main sheet pressure had started crushing the boom. When we worked out what was happening, the boom was in a state that was still easy to repair in my workshop so we decided to just nurse it to the finish. Without the required main sheet tension, Quickstep started to pull some ground back on us and it looked like they were going to get us. As we rounded the point to go back into Pittwater, we could come off the breeze enough to get the screecher up and honking. We held Quickstep off to cross the line 43 secs ahead.
The sail maker, Rob Meizer, from Ullman Sails was good enough to sail with us to show what the boat should be able to do, and he steered and called the shots. At the end of the day he said-
don't change anything, this thing goes like it's on rails.
No doubt the boat will be much slower if I'm steering, but I now know what is possible.
Mad Hatter passes the first test.
Rolf,
The sails were designed and built by Rob Meizer of Ullman Sails and they are fantastic. The combination of Rob's sails and Ctech mast just works so well together.
I'm glad that i got the carbon mast from Ctech. I got them to put in Hi mod carbon to stiffen the mast through the minor axis.
This would have allowed a 3kg weight reduction however I choose to keep the weight and increase the safety factor.
Still the weight of the mast with 5 x 8mm halyards (including 2:1 for main, jib and screecher) and stays plus all fittings and clutches for the halyards, still weighs less than 65kg.
The building never stops.
I have been trying to find someone to make a pullpit to a specific design but the engineering places around here all seem swamped with work.
Finally I gave up chasing someone else to make it, borrowed a pipe bender and got to work myself.
I filled the stainless tube with sand, made plugs for each end of the tube and applied some heat while I made the bends.
Once everything was bent,the parts cut and notched to fit neatly, I did some tac welds and timber bracing to hold it just right.
I found a chap who makes alloy wheels to weld it up properly. Ultimately this pullpit will carry the mast when trailering.
Carrying the mast on the pullpit will reduce the time taken to get the boat off the trailer, I always raise my mast on the water.
The pullpit will also take the nav lights. They will be mounted on the side plates and the wires will run down inside the stainless rear tubes.
The rear tubes fit into sockets in the deck that drain into the anchor well.
Now I have to polish it all up and fit it to the boat.
- 4,004 Online
