Racing start on the 1/2 hour.
A couple of recaps from yesterday's practice.
Louis Vuitton America's Cup series - Ainslie impresses in Portsmouth
America's Cup - Emirates Team NZ scores a first and third in Practice
All of these feeds were of suspect quality unfortunately. I have 300mbps internet and all of them were buffering constantly and not even on HD.. <img src="<>/frown.gif" alt="frown" title="frown" height="15" width="15" />
Hope they get the US video rights sorted and quick.
This works perfectly on my PC W/Chrome and ad block+. Can't get full screen and I missed today's events. Will try tomorrow.
Thanks Philip!
Thanks Philip!
The full screen might be an issue with chrome rendering the aspect ratio to 5:4 instead of the native 16:9. I saw it happen with chrome on one of my machines but not on another.
America’s Cup and ISAF reach agreement just ahead of ACWS Portsmouth
'The ISAF jury appeared to be on a crusade to 'save the America’s Cup' and I believe they may have allowed that belief to cloud their judgment.
'In fact, it is interesting to note that around the same time, the President of ISAF was actively discussing moves to try to grab more control over the event.'
'There are many very good people in ISAF that have worked hard and given up a lot to further the interests of the sport. However, the current administration with their politically charged agenda is doing our sport a huge disservice in my view.'
Not really AC related but cool nonetheless.
VIDEO: The first foiling MOD70 – Gitana Team’s Edmond de Rothschild flies during her first trials!
Read more at http://www.yachtingworld.com/news/v...
Here's a question for you designer wannabe's.
As we have been seeing ever since Foiling became a 'Thing', the worst thing that can happen is the dreaded nose-over, pitch pole. As I look at all the foiling boats, from the Phantom all the way up to that 70' Tri above, they all have the main lifting foils mounted at about mid hull, with a T rudder setup in the back. From watching many of these videos, it seams they always start to hobby horse in any type of big swell, and the bows dig in once in a while, often with disastrous results!
Why aren't they putting the main lifting foils further forward, instead of only at amidships? If the would put it way out front, that would stop the teeter-totter effect we see in the swells.
They could make the rear foils bigger and the front foils smaller, to evenly distribute the weight, but it seems to me it would be much more stable if they spread the foil lift to all 4 corners, rather than keeping it right in the middle of the boat and having the nose dive tendencies.
Timbo: Can you provide an example where you saw a foiler pitchpole? The foils actually prevent the dreaded pitchpole in the first place.
The current foilers have a nose down attitude, but that's on purpose, as it is faster (less drag if the front hits the water than if the transom does). The only moment when these boats can pitchpole is if the foil is not working (boat not going fast enough through a transition for example).
Why are plane wings positioned where they are? Balance? The other thing to consider is how would it handle/steer with the foils forward. Very slow I think.
The lack of ability to watch the America's Cup is starting to affect my desire to see any of it. While $8 isn't staggering by any means, I just didn't feel like paying that to see it (partially figuring that it would be available for free moments after I shelled over the $8).
If you want me to pay a few bucks, have a feature presentation put together that compiles the racing action with an inside view from each venue and make it available by subscription at Netflix, or Amazon, etc (where I know I won't have feed reliability issues). I would probably watch the (free) racing and then pay for that to see some inside information on the action.
It's as if our own team kinda gave up on us US schmucks.
Well, that's the problem. They have to design something that's going to 'work' in at least 3 axis', then throw in differing sea state, wind speeds, etc, every design is a compromise trying best to fulfill all those requirements. I'm sure they have lots of smart guys from Boeing and Airbus on staff telling them exactly what/where those foils should be, but I'd still like to see what would happen if they put them further forward, and then did a 'shared lift' concept with larger foils on the rudders.
That may indeed slow down the turning required from the rudders though, maybe that's why we see such small foils back there, with most of the heavy lifting being done by the big L boards in the middle of the boat.
Now, let's think about our A cats, and all the teeter-tottering they do when up on the foils. Have any of them tried moving their big C boards further forward to see if that helps keep them from doing a face plant?
Here's the Red Bull 18's foiling:
https:/
And an A cat:
https:/
they actually started that way. The problem was (didn't we have this conversation before?) that with the shared lift of the main and secondary foils, the boat was very unstable when transitioning from displacement mode to foiling mode. At some point in that transition, the boat needs to pitch up in order to get to an elevated foiling position. With forward mounted foils and rudders lifting (and no allowed trim tabs on any of the foils), the boat tended to porpoise badly and was very difficult to control. It was only until they brought the foils back closer to the center of mass of the boat that they were able to achieve a stable transition from displacement to foiling....which is the same reason airplanes have a primary lifting wing close to the CG of the aircraft.
Think of the rudder foils serving to provide stability, not so much lift. Similar to the horizontal stabilizer on a plane.
- 2,168 Online
