A Cat advice
The only guide to modern multihull sailing that I know of is the French sailing dvd’s:
http:/
there are a few sequences talking with GASHBY and some clips of him on the A-Cat, but I don’t even remember if he gives any real tips. These dvds are applicable to all modern cats, but really not focused on the A-Cat in general.
I plan to re-watch these in about 2 months and I can see how much info is given to the A-Cat.
There are many A-Caters on this message board; you could probably get most questions answered here.
Matt
... I guess you are from the US? Why not having a look at the United States A-Class Catamaran Association at http://www.usaca.info ?
Have you sailed an A-cat before? I am owning a F18 and bought now an A-cat in addition. It's a pretty different subject - but lots of fun!
Yes you do, BUT when you sail most heavier uni's, as you are sheet in tight going to weather with speed, As you start the tack, the second you go head to wind you MUST uncleat 2-3 feet of sheet and recleat it as you go to the other side and change the tiller or. Then as you go to a reach heading on new tack, SLOWLY begin sheeting in and heading up. If you DON'T you will go into irons. TRUST me I learned this the hard way. A cat my be different because it is so light?
Doug
Doug
It was more along the lines that you ever cleat the mainsail upwind. The only time I cleat if I don't have a spare hand while I am doing something else or when the the kite goes up <img src=
Agree 100% you need to ease some sheet as you tack as the boat will slow down, and the apparent wind is changing.
I think you need to cleat in light to about 15, and sail by the telltales and the feel of the boat. Above 15 I agree or if there are a lot of puffs, but then you should be watching the water and be ready for them. In the light stuff I think it is more important to watch the telltales and the feel of the boat and keep movement and healing to a minimum.
Just my 2 cents,
Doug
Doug, you should always be playing the mainsheet when going upwind-don't cleat it. An inch in or an inch out may make a noticable difference. I have my cleat angled so high that it is hard to cleat the sheet, and I only do so when going downwind or tacking. Don't cleat the sheet...
Totally with you on that Trey.
Our Marstrom A-Cat has one of those evil tramp centered main sheets that doesn't even let you cleat for the tacks. You have to hold onto the sheet and stay on the wire until well into the tack before swinging in like tarzan and trying to juggle unhooking, steering, rehooking while not letting the main sheet get away from you. Still a bit of a chinese fire drill for me.
On the F18 we only cleat the main just before tacking.
Chris.
CC
Advice given to me by some sage A-Catters: practice the wild thing when ever possible to improve your technique, but be more conservative when making the transition from mild to wild when racing - they kept repeating 'a good mild is better than a bad wild'.
I have the cleat set up like Trey, sailing out of hand is in my opinion better than cleated which causes you steer more (especially when the breeze is gusty) and that is slow.
Smooth steering is very important. When sailing upwind you should be sheeted in as hard as possible, if you cannot then you do not have enough cunningham on. If you sheet out instead of using the cunningham you will not not be able to point as well as you could. At some point you cannot pull on the cunningham anymore and then you have to sheet out and bring in the rotation. Above 12 knots I have about 30° rotation. If you are racing ALWAYS try and sail in clear air, I would rather have a slightly worse start and have clear air than sit in someones exhaust for 5 minutes till I can finally tack away into clear breeze. Move forward and back on the trapeze to keep the boats trim optimal, I move about 30 to 40cm depending on the wind strength and waves. Downwind in marginal conditions is always difficult.
when in doubt, go deep
. You see people losing a lot of ground trying to go wild when the first boat with a lightweight skipper onboard gets a hull up and everyone else feels the pressure to follow suite. Here is an excellent article by Andrew Landenberger on sail/mast setup and design. I had to read it a few times, but the penny has dropped and it is very good to understand the relationship between mast and sail on an A Cat. http:/
Good boatspeed will make you look like a tactical genius
regards fron Zurich
Daniel
SUI 198
thanks
Basically it's flying a hull downwind. There is a fine line between going too high and too low.
Wild Thing
is going high to gain speed, as the apparent winds moves forward, you can point lower. The ultimate goal is to be able to gain enough speed that you can point as low as you were pointing before heading up to gain speed. So... same angle, faster boat speed.
CC, some possibly useful articles linked to on our web site:-
http:/
- 658 Online
