Alternative to anodize?
The paint is awl-grip. IT is the same as they use on yachts. Two part system that can be brushed but has a better finish sprayed with a airless spray gun.
To do the beams you need to sand them down and prime them with an approved primer. Of course you need to remove everything from the beams first. Also, you need to use a dewaxer before you start to sand and between every step sand, prime, paint to remove any wax, sweat, etc.
If you don't the paint will peel as it did not bond to the metal. You can use an etching primer to bond even stronger and if I where taking the time to do it that's what i would use.
Awlgrip comes in about 70 different shades and colors so you can do just about anything you want. Also, if your doing the beams you might as well do the mast it isn't that much more work.
Good luck
- 3,533 Online
