Dagger Repair
I tore up the trailing edge on one of my daggers recently. I've got enough experience w/ glass & epoxy (and a little carbon) that I don't think that the repair itself will be too troublesome.
I plan to grind out the damage, which is about 2
high and 3/4
deep in the trailing edge, about a foot from the bottom, and vacuum some carbon in it, then fair.
My question: Do I need to cover it in gel coat? Considering that it is in a spot that rarely sees the sun, I'm wondering if I need to do anything at all to the fairing compound after fairing it? I hate working with polyester resin.
Should I put a single thin covering of non-thinned epoxy over it?
or just treat the whole daggerboard w/ a poliglow-style UV inhibitor?
or re-gelcoat?
Any advice is welcome. Thanks
Rob
high and 3/4
or re-gelcoat?
Rob
Anything you put over it for a finish is just cosmetic...if you don't care, leave it raw. Polyester resins are UV stable and, although it yellows, epoxy is structural stable with UV exposure. Heck, on small repairs, I hit it with a little krylon. Vacuum bagging is probably overkill on that too (did I just say that?).
To repair those dings, I mix up some finely minced glass fibers (either bought that way or self made) and fill the void with that putty. I tape a hotel key cards to both sides of the board to form the flat sides to leave very little fairing.
I have TONS of hotel cards/empty gift cards/vanilla reload cards (twice the size, good for squeegees), but I don't think I've used them the way you're talking..I've seen your pics. I have used them to help make a very square edge at the dagger trunk exit. Anyway, I'll try it like you say.
I have milled fibers from us composites, but I was planning to use carbon just to try to prevent this from happening again. Does that just make the rear of the dagger trunk more likely to get torn up? Is carbon even stronger in that situation or is it too brittle?
I hit a log floating under the surface, but the front of the dagger shows no damage at all. The rear got damaged from getting jammed into the trunk.
I've done repairs in all sorts of materials on the trailing edge of boards...it's all going to crush if it gets impacted with enough force and I'm not sure that it makes much difference what material you use. There is just so little material on the thin edge. I consider this type of repair as maintenance.
You should have had a Nacra infusion when they had
gybing
daggerboards. You would have to repair them after every regatta.
This is the standard 'Inter' rudder. Without looking I'm going to guess that the damage goes in far enough to be about 3/8" thick at its widest.
New semi-related questions:
Can fairing compound be polished smooth? I've never hit it with anything finer than 220 or so (usually just 80). It seems really porous to be on top.
How 'sharp' should the trailing edge be?
Thanks!
I hit a floating 2x4 (was looking/talking to another boat) doing around 8 knots.
it hit both hulls, both centerboards, both rudders. did similar damage in several places.
It was like a car wreck over, and over and over ...
What the heck is a
vanilla reload card
Carbon is standard on the bottoms of the Gen3 rudder blades. Kevlar is the toughest in this type of application (I use it when building a composite part intended to skid along grass/concrete etc.). Trouble is it's the worst to work with and paint doesn't bond well to it. By worst to work with, I mean you need to modify scissors to cut it, and once it's in a layup its an absolute dick to finish cut or finish sand. Will require a hand sander and lots and lots of 60 grit sand paper to get to final shape. But it'll hold up better to repeated groundings, if it doesn't de-bond from the base layers.
http:/
Jake what about on rudder bottoms? glass strands? kevlar? carbon cloth? sheet metal?
Goal being to reduce the loss WHEN you hit bottom (sand or mud around here)
Fibers only prevent a break and high modulus items are pretty useless at the tip of foils unless you really plan on hitting things hard. They won't prevent chips/scrapes/gouges. You need a hard shell to resist that kind of abuse and properly cured gelcoat is hard to beat in this regard.
Yeah, when I hit the thing, since it was completely submerged, I thought I snapped a shroud at first. Then 2 secs later it hit my rudder, and I drew the only obvious conclusion -- my boat and I were being eaten by a lake bound sea monster.
After nothing else happened, and sitting at a dead stop (from trapped out racing to the windward mark.) I moved on and came in last. When I came back to shore and the dagger was stuck I realized what happened. I had to rig a sort of up-@%#$er on the trap line to get enough purchase on the board to free it. The rudder had no damage at all...but I guess that makes sense since the front edge of the dagger didn't either.
You can push the board up from under the boat while someone pulls. Real pain but that's what we've done.
Jake, I think Kevlar pulp has considerable benefit in this application:
The results show that the incorporation of Kevlar pulp into epoxy contributed to improve the friction and wear behavior considerably. The maximum wear reduction was obtained when the content of Kevlar pulp is 40 vol%.
From an abstract by J. Wu, seeing if I can get the entire paper now.
I would not paint over the kevlar, so the surface roughness may be higher but done right you can get a pretty smooth finish and no loss in performance.
I fought a kevlar boat for 2 years and there is no way you can convince me of it's merits on a daggerboard repair, no matter where on the board. Not worth the headache. done right you have to put glass over it as a sanding barrier.If you're trying to offer the most laborious and frustrating method, then I commend you.
I'm sorry. We borrowed a kevlar A-cat last week, huge chunks of paint flaking off. Glad I don't own it.
I warned that Kevlar was extremely labor intensive. I hate using it outside of molds, and I did not use the filler I pointed at to fix the chunks in my rudder tips, elected to go with graphite. MN was asking for options on wear strips. Kevlar is amongst the most abrasion resistant materials the government has made commercially available. Translation, it is also extremely hard to fair.
About the only beachcat use I can see for it is the bottom of a cat that get's dragged up and down the beach, in which case the surface really doesn't matter.
p.s. A cat you borrowed a Waterrat?
I'll add another option for a tough surface, I tend to forget about as it's heavier than glass/carbon/kevlar, West Systems 420 Aluminum Powder.
Abrasion Resistance – Apply undercoats of epoxy modified for abrasion resistance or temporary UV resistance.
Much easier to sand than kevlar.
We use it as the top surface on a fiberglass mold, as it forms a very hard coating, less chances of dinging the tooling when removing parts.
Kirk's H16 had kevlar strips on the bottom for that reason. We used Aluminum powder on the bottom of my H14 back when I was a toddler, it held up extremely well to the shells that pass for sand around here.
Yep, sailed the club A-cat, a Waterrat, too light to really get an opinion but J liked it for a solo play toy.
+1 for use of kevlar on the bottom.
I use this also already for years because of the high abrassion on my sharp assymmetric hulls. And by the way, it is not much harder to work with then other type of cloth.
On the bottom I use kevlar in ribbon format which covers exactly the sharp end of the bottom. To finish off the wet kevlar-laminate I always use PVC/tape (which I take off after hardening). The sand on the beach will sand it off very smoothly (only shells can make a hairy surface).
With regard to your damaged trailing-edge of the rudderblade, I wouln't suffice with some filler or so.
Sand it off with a overlapping
welding
section of about 4 cm on the sound part of the rudder. reconstruct any core if necessary and start laminating.
Do this for both sides of the rudder. Finally sandoff a nice sharp new trailing edge!
I would take a dremel with a cut off wheel and cut down the depth of the cut off wheel along the trailing edge where the damage is. A slot if you will. Then use carbon, I like around 15lb biax glass , lay up a layer or two a little longer than the slot and about 1-2 inches wide on some wax paper or use what method you like. After the glass has kicked, Trim so it fits into the slot. Mix some epoxy and glue it into the slot. From here you can make up a filler with epoxy, some West graphite powder will make it all black. Shape it up. Now you have a edge than can take some abuse without crushing.
+1
One trick is to lay a piece of plastic that is about the thickness of a ziplock sandwich bag over the repair and squeegee the air and excess resin out. There won't be much sanding to do after it hardens if you put the right amount of fibers in the repair. You would prooly want to tape off the repair area to protect the good part of the project. You can also trim the repair when it is partially hard to save time later on.
polyester won't go off when put over some types of epoxy. You can put pigment in surfboard epoxy, or just spray paint the repair for cosmetic purposes.
Also i have found that the most durable bog is a mix of aerosil, a little bit of finely cut up carbon, and epoxy. Works great on the bottoms and foil tips.
The rule for kevlar is bury it deep. It soaks up water and only forms a mechanical bond whereas carbon forms a chemical bond with the epoxy.
First I like to show you some explanation about how epoxies and polyesters do work:
The cloth in a laminate will always suck up some water when the surface is damaged. (That's why they fill themselves with resin too)
Glass, carbon, kevlar or whatever, it makes no difference.
If the carbon molecules of the carboncloth really are bonded in the epoxy molecules during the hardening (the polymerisation), like you said, then this should mean less stable (disturbed)epoxy molecules.
The strenght of a laminate is largely determined by the fibers in the cloth you use. The resin only keeps all the fibers together; to be more precise, holds them at their fixed position to each other.
It fills the space between the fibres and fills them and holds them internally.
Rob
... Vacuum bagging is probably overkill on that too (did I just say that?).
What Jake said, but forget about the plastic .
Make your own chopped fibers by rolling
some 4oz glass up on a +/- 45deg and dicing the end every
1/4
with some SHARP scissors. Mix 30% chopped glass fibers
with 70% WEST SYSTEM #404 High Density Filler, and add epoxy.
http://www.westmarine.com/webapp/wc...ord=404+high+dencity+filler#.Ulv93lNqkuQ Make the mixture dry enough that it will NOT elongate off
the stirr-stick when pulled up out from the mixing can.Tape the edges of your damaged aria with the Blue 3-M
painters mask , so when Ya sand down initially , you'll
hit the tape but not destroy it. At this point, i usually
paint on a bit of epoxy before mixing in the filler, then
use a Blue shop-towel to remove almost ALL of it.Use a bit of 3
wide tape on the bottom side to hold
the mixture in place while it goes off.
SANDING
No need to wear a mask here, i use a File and water, till i
hit the tape, or 40grit wet/dry sandpaper. When Ya hit the tape
then pull it and switch to 100grit wet/dry ; then 180 ...
If you spend more than 1/2 hour labor on this job, then your
thinking Too much and need More Beer !!
Bille
Your gonna Laugh, but my sanding block is 1/8
thick
aluminum , (1
X 2"). i have 3 of them:
1) the exact length of my sandpaper
2) the exact Width of the papar, (i get 3 pieces of
sandpaper,after folding the edges)
3) is 1/2 the length of # 2.
Every time you drop your sanding block on the floor
then sand all 4 sides with 100grit by using one of
the other blocks. Do NOT forget this or your sanding job
will be screwed !!
Bille
It's Ruff sanding, so i use a 1/2-round or round file
with a rather Heavy groove ; clean Before
the grooves full, and i do it with More water and a file
brush. It only sticks if you don't clean every very often.
Rotate the file every other pass.
Same goes for the Wet & Dry sandpaper, don't let the grit
get filled or ya got to toss that piece.
Wear Very Wet cotton gloves and use them to keep your
work wet; that also helps to keep your girlfriend happy
if you use your hands a Lot !!
Bille
- 1,747 Online
