Fixing a jib halyard with sister clips...
My jib halyard is fraying, and we won't have a new one from Murray's by Saturday, so I would really like to fix the one we have.
Can I buy some dacron or polyesther line and attach the sister clips from the jib halyard that is breaking? How would you attach the sister clips? I don't want to sacrifice the old one by cutting it open until I'm sure I can make something work....
Jonathan
Instead of the sister clips,learn how to tie a sheet bend. Very simple knot to tie.similar to a bowline.I'm assuming you have a long line(hoist or painter) attached to a shorter line(luff tension) attached to a wire? The long line is just used for hoisting so get something small and cheap. The short line is used to adjust the jib luff,get something low or no stretch. The sheet bend is used to tie two similar or disimilar (size&material) lines together.I've been using this ever since my line frayed and I had to replace my sister clips...............
Have Fun Mike
Jonathan, we had been sailing our Hobie 18 for many years before I had ever heard of or seen such a thing as "sister clips." When I finally saw a jib halyard that had them, I said, "What a neat idea!" But all they are is a more convenient and faster way to do what we had been doing for years -- using a bowline in the end of each line to attach one to the other. So you don't even need them -- just learn to tie a fast bowline and do it the old-fashioned way. When you are a sailor, it is always good to know how to do almost everything without having to rely upon new-fangled gadgets. A Hobie 16 sailor at one of our recent fleet races did not even have a tiller extension -- he used a rope attached to his tiller crossbar to steer when he was out on the trapeze. And he did well in the races, too. Not that I recommend doing this, but it is nice to know that it CAN be done.
I assume that you are using a thinner line for the longer line, and a thicker one for the one that matters? My current halyard is all of one thickness.
So I take it that the sheet bend works pretty much as well as the sister clips? It's easy enough to tie...
Jonathan
Try it.....You'll like it. Just make sure you draw up the knot properly.One other thing, if you are using larger line the knot may not fit into the zippered luff. so go easy as you hoist.Yes thinner for the longer line.I use vectran for "the one that matters". It is quite thin also.Just use something good.
Mike
the halyard does not take any of the load. the hook on the ring at the head of the jib takes it all. thin line will work just fine. you can find splicing directions at http://www.neropes.com/splice/ i would use some single braid and some heat shrink tubing. single braid is way easier to eye splice than double braid. you should be able to make a halyard in about half of an hour.
- 728 Online
