GPS Help - What's new out there?
(@palmwolfe)
[#27927]
So I bought my kid the garmin 76 cx, new one with the micro sd slot. Now looking at the Blue chart maps, I read where once you get it you can only open 1 area? Is that still true?
I searched the threads but most are pretty old now.
Any better GPS's out there that include maps?
Thanks, Jerry
Posted : April 13, 2011 10:03 am
catandahalf
(@Bert Rice)
Garmin allows one chart subscription with the base price of the Blue Chart set. Additional 'chart areas' were around $99.00 USD when I last checked.
I am set up with the chart area for Tampa - New Orleans. If you are only planning on sailing in your local area, then select that one. If you travel; spend your money wisely.
I just picked up a Garmin 72 H yesterday to replace my Garmin 76 which disappeared during our last regatta. That unit does not have charts; however, it outperformed my Garmin 76 CXs during field testing yesterday against two other Garmin hand helds and my handbearing compass. Word is that it has the new antenna.
Bottom Line - make sure your gps is running the latest version of available software and check it for accuracy. During the US Sunfish Midwinters we found the 76 CXs was twenty degrees off at .5 nm. I am sure after it failed the field test yesterday that I need to upgrade system software.
Gets some buds together with their gps units, grab an accurate hand bearing compass, and compare the MOB bearing and distance. For example - find a football field - shoot the bearing between the goal posts from the goal line. See how your MOB data compares.
...a two beer project...
Posted : April 13, 2011 11:38 am
(@YaekoCubr1501)
Newby Registered
Garmin 76 will allow you to updates of map. But you need to check that there is availability of Map or not.
Posted : May 30, 2011 7:01 am
(@petecullum)
The new waterproof Garmin 78SC is pre-loaded with charts of all U.S. coastal areas. Costly at $500 but I have abused it mercilessly for a couple of months and it is holdiong up well.
Posted : May 30, 2011 9:33 am
