Gunboat G4 Foiling cabin boat
But I doubt if the balance is correct. The hulls tend to lean a bit forward. Pitchpoling!
(and the crew look like a group posh chickens)
I can vouch that at least some of the crew are quite experienced sailors and foilers. This is not a low budget or corner-cutting operation. I agree, though, it did seem a little bow-down for a lot of that video but it seemed to slice through the waves while staying on foil.
I think your impression of the people was one they were actively trying to portray (perhaps with a little
tongue in cheek
)...a relaxed foiling experience....whether that's reality or not, I guess time will tell.
tongue in cheek
The daggerboard wells have three separate fore-aft adjustable positions 31cm apart. They're using this one as the
test
to figure out the best position.
In my experience, foiling a little bow down is more stable than foiling a little bow up. As the boat lifts in that attitude, it doesn't build towards increasing lift and spiraling up until crashing down. Oracle's AC72 often was a little bow down as well.
This is different from
foiling
with C boards in foil assist configurations where you want the bow up all the time and the sterns still planted in the water.
Maybe they want perfectly level flight, but I think they looked very good and very in control, something everyone will want and need when sailing a 3 ton, 40 foot cat.
I think it might look more bow down than it actually is due to the
fat
stern though.
foiling
Bingo!
Boat is upside down.
<img src=" https://scontent-lax.xx.fbcdn.net/h...
Yeahbut..think of the sunsets1
Insurance rates for foiling cruising cats just tripled
That shows exactly my point which I made earlier.
This Gunboat is nothing more than an overdressed sports-catamaran. And like each sport catamaran, it can flip and it can pitchpole.
And when that happens it's a super-heavy unmanageable cat.
The original promo video, showing lounging white dressed yups drinking champagne during sailing, is foolish. They had no lifevests on, so they were all lucky to survive soaked on their capsized dreamboat.
This forum is fooled by this Gunboat mirage.
It's apparently exactly the same failure mode as Paprec Virbac, the classical Extreme 40 capsizes, or the big off Team NZ got at the last america's cup: You can't dump an hydraulic mainsheet instantly.
I expect the G4 will be equipped with a tilt sensor linked to an instant mainsheet release of some sort in a very near future.
Dyslexic driver, maybe steering is slightly backwards when keeping the boat up on foils. Anyway they took that gust up instead of down from the get-go.
TNZ wasn't really the same. They have a sheet with a winch for letting the wing out. Their problem was no hydro to tack the wing. As i understand it, they had to physically tack the wing using hydraulic controls and that had a lot to do with how fast they could tack and jibe. It seemed to me they may have been bringing the boat through the eye of the wind partially using the wing.
If Ronald is correct about the no life jackets, they will probably start wearing them after this.
Agreed. You would think the helm had enough experience to not head up. Hard to tell in the video but it looks like he might have loaded up the lee rudder and lost authority due to ventilation. I would wager we'll see second generation rudders with a bigger winglet and more chord.
I agree - at about 40 seconds in on the wipeout video, you can see the windward rudder at a pretty high angle as the skipper tries to head down, but the boat doesn't respond. The rooster tail behind the lee rudder also tells the tale. Blowing the gennaker only worsens the pressure on the rudders, causing the boat to start heading up and over.
I don't know about the rooster tail, but you can see the leeward tiller arm twitching as the skipper presumably jerks the windward one trying to get it to turn down. I can't correlate the skipper's arm movements to the leeward tiller movement but that may be because the resolution of the skipper just isn't that great in the video.
This is a whole lot of
arm-chair
skippering, but I agree that the release of the genny didn't help the rudders maintain traction. The main (particularly the traveler) did get eased but it wasn't enough or in concert with the genny. (but, I would personally have a hard time hanging onto the winch wraps with the genny if presented with the same scenario)
You can get a better sense for the tiller arrangement with this photo.
It was exceptionally impressive that the rig remained intact minus a few broken battens.
1) I liked that Gunboat isn't ashamed to post and/or isn't denying what happend
2) I liked watching the crew and their choice(s) when the boat was
gone
. The one dude hitting the mast looked bad, but the other guy just hanging until it went turtle was almost funny. Of course, I can only say that as it appears no one was seriously hurt.
3) I'm glad they are actually testing the limits of this boat. And I would like more information on how they righted it without a lot of damage. I suspect the G32 and some of our larger three-legged bretherin (F-28/F-31) may benefit.
4) If you're going to buy an amped-up foiling beachcat, you should probably know what you're doing (or have a big enough wallet to handle what may come...).
5) I hope Gunboat supplies free monogrammed towels to G4 crews. And...
6) you bet your a$$ I'd still buy one if I had the chance.
Read the comment of Peter Johnson (founder of Gunboat and crewmember):
http://www.yachtingworld.com/blogs/...
Ah crap! Was Clean on the mainsheet!?
That deserves a +1
- 1,660 Online
