Looking for Nacra non-captive mast base
(@Anonymous 37751)
[#13917]
Hi there, I just moved and I am now in a fairly remote location (50.27N-66.44W) and I want to modify my current Nacra 5.2 to make easier to set-up and sail singlehandled.
Stepping the mast and righting the boat are a big concern for me. I could try to build a mast hinge and a mast stand to try to step the mast alone but I would rather spend my free time sailing instead of building and adjusting such a device.
I am looking for an old, used and beat-up Non-Captive mast base. I would like to install a 24’ mast and sail on my boat.
I already have the 24’ mast, sail and enough spare rigging but if I would find a mast base, I would be able to setup my boat like a H14 to make mast stepping much easier.
I do not mind is the mast step is damaged as long as the cup is still ok, my new mast will have a smaller mast section so there will be some tinkering.
I am simply trying to salvage what’s left of my sailing season.
If you have a mast base lying around, please contact me and we will try to work something out.
email using the Catsailor message or directly at
leblancc_99@yahoo.com
Posted : June 29, 2004 9:21 pm
NacraMike
(@mikeomnione)
Charles, I changed out my 5.2 to a captive mast base last year. I have the old non-captive with the old rod and bolt somewhere. I will take a look this evening and see if I can find them. I'd be more than happy to send it to you (no charge) if I can find it. You know that the ball is smaller on the non-captive unit although still available but expensive.
Mike
Posted : June 30, 2004 8:05 am
Jake Kohl
(@jake)
I upgraded my 5.2 as well...I'm quite sure I no longer have the casting but I might have the old post if you still need it (no ball though).
Posted : June 30, 2004 8:35 am
(@Anonymous 37751)
Mike,
Thank you for your help, my Nacra 5.2 is still completely set up with the non-captive system with the small ball. I did own a Nacra 5.7 before and it was with the captive mast system so I can tell the difference between the two systems.
I almost did the upgrade last year but I think that the one person mast stepping will be easier with the non captive system and the vertical pull technique.
Posted : June 30, 2004 5:32 pm
NacraMike
(@mikeomnione)
I found it Charles. Click on my username and email me your shipping address and I will get it off to you.
[Linked Image]
Mike
Posted : July 1, 2004 8:39 am
Jake Kohl
(@jake)
Do you still need a post (I forgot to look)?
Posted : July 1, 2004 9:24 am
NacraMike
(@mikeomnione)
Charles, mast base is on it's way to you by USPS.
Enjoy.
Mike
Posted : July 2, 2004 12:59 pm
