Looking for Tornado Plans
12 Users
17 K Views
(@bronco9588)
[#22521]
Hey guys,
I wanted to say that I am addicted to my Hobie Cat, but the hull is going through some major delamination, and I feel like it will only be good for a couple more years. Its rather outdated, but I got my money's worth out of it.
I would really like to build my own 18-20 foot catamaran out of wood. I think it would look really cool in a clear coat, and be a little different. I was reading that the tornado class was created so that designers could make them at home. Anyways, I was wondering if there was any place that I could buy the blueprints/ specifications for cutting out the hull shapes. I know that thebeachcats.com has plans for them, but they look more thorough on instructions and not so much on the actual measurements. Apparently, the Guegon brothers and tornado.org have plans, but I can find no URL to find it.
Any help would be appreciated.
Posted : April 29, 2008 9:15 am
Jake Kohl
(@jake)
nothing specifically on the Tornado but The Gougeon Brothers are West System;
http://www.westsystem.com/
Click on projects and then boat construction...cool information inside.
Posted : April 29, 2008 9:33 am
(@_removed-account)
Four Star Admiral Registered
There are folks here who can probably give you an answer on this. However another thought occurs... I don't know whether a timber Tornado would now be competitive within the class, so if you're more interested in creating something a little different and perhaps with a more modern hull shape, I seem to recall that Phill Brander, the designer of the Blade F16, at one point was talking about a 20ft design. He has produced plans for the Blade 16 in timber so perhaps would be interested in doing so for a 20 ft boat, or there is also the Blade F18 design. Phill is a regular here so perhaps he'll chime in.
Posted : April 29, 2008 9:39 am
(@bronco9588)
Sweet. Sounds pretty cool. I like the wave piercing bows on the blade. I was completely unaware of plans for the blade. Are there any polar comparisons for a contemporary tornado vs. blade. Speed is good. Does wood vs composite really affect speed beyond an increase in weight?
Posted : April 29, 2008 9:52 am
PTP
 PTP
(@CaptainPP)
and you would need a tilt trailer for a tornado
Posted : April 29, 2008 10:35 am
(@stewart)
I would suspect the Tornado association could have plans.. Go to their website.. Email them as Im sure the plans would be on paper (still) and each set would have a license fee.. Hence them not being
freely available
on the website..
My heads up comments:
I recall the earliest wooden Tornados had no bulkhead structure under the main beam.. This meant after a few seasons the main beam and keel started to become one.. So look at the plans and re-engineer if this is the case.. Secondly the original plans also needed engineering in the bow sections. The bows tended to flex quite a lot even with the old rig. I suspect the forces have increased with the new rig. So look at that before building as well..
Now these two areas could well have been sorted on the plans but I dont know..
hope this helps..
Stewart
Posted : April 29, 2008 10:49 am
(@bronco9588)
So if I go with the blade, I wouldn't be loosing much performance in epoxy covered ply?
And how through are the plans?
Posted : April 29, 2008 10:58 am
PTP
 PTP
(@CaptainPP)
check out the boat building part of the forum, a couple guys are in the process and describing it there
Posted : April 29, 2008 10:59 am
(@stewart)
if the engineering is sound.. and flex is controlled your hull should be as quick as any composite..
The example is the Tiapans wood vs composite shows old wood hulls are still winning major titles even after a few decades..
Posted : April 29, 2008 11:03 am
(@Anonymous 13024)
The plans on thebeachcats is all you need, including the measurements for cutting all panels.
Gougeon bros. stopped building tornados a long time ago and I dont think they distribute/sell plans anymore. At the time they built the best Tornado available, but it was done in cold moulded veneers with an inside supporting structure. They sould their Tornado business to Jerry Houlton who continued for some time. Jerry Houlton was the same person who collected the information from many sources which is now on thebeachcats. He started out building in plywood, continued with cold moulding but Marstrøms boats got a reputation for being faster in chop so eventually Marstrøm became the sole builder. Note that the glass boats Marstrøm built in the beginning was no better than wooden boats as far as I know, but the sailors went for his boats after a while. A 1987 or later Marstrøm is built with pre-pregs and autoclaved and is structurally probably better than a wooden boat. Not neccesarily faster..
You can buy plans directly from ISAF in the UK, but the plans on thebeachcats are better in my opinion. ISAF sells the originals, but the amassed experiences collected in the plans on thebeachcats make them much better.
A wood Tornado can do well at national events, but sadly the Tornado class is very, very, small at that level. It is not the boat which is fast but the sailors, you know <img src=
I sailed in the Tornado class for several years, but sold the boat last year. Now we are building F16 Blades..
Before you decide on any model, you need to decide on what you want to do. Sail or build a boat for several months? Pretty much the only reason to build yourself is to enjoy the process. Unless you have built before and have lots of connections you will not save money, and you will definately spend a lot of time on it, doing lots of mistakes. If you just want something different to sail, buying something used is the way to go. If you want a clear coated Tornado, you can find them around for a song from time to time. At the time, you could not give away wooden tornados. But these days I see some announced for ridicilous sums.
Before getting lost in dreams about clear coated wood, think through why you want to build and see if you have the right motivation. If
money
and
looks
are on top of the list, I would advice you to buy something instead.
If you decide to go through
the process
, you can get a lot of tips on models, sourcing parts, how to do it and support in the builders forum.
Posted : April 29, 2008 11:13 am
(@_removed-account)
Rolf and Gato both have great websites with photos of progress on their Blades -
http://woodastic.blogspot.com/
http://www.gust.ax/gallery/blade/
and Tony Jenkins recently posted some photos of his project.
http://www.catsailor.com/forums/sho... amp;amp;an=0&page=0&vc=1
Posted : April 29, 2008 11:25 am
(@Anonymous 13024)
Dont forget the Blade 16 Valtteri documented building on his Blog: http://www.rahkonen.fi/blog/
I definately recommend building in ply for the first couple of boats and not go for strip planking or composite. I dont know any available building plans for strip planking or composite beachcat construction, just ply. But the building method is not what is important, the motivation, available time, building shed and budget is whats most important.
Posted : April 29, 2008 11:33 am
(@_removed-account)
Cool, I don't remember seeing that before. Which probably has something to do with age.
Posted : April 29, 2008 11:41 am
(@bronco9588)
Thanks for the material. I'm pretty interested in making a blade. I will definitely have access to good old hardware, but what does the rigging run for? I figure that I am moving out in three years so I figure that would be a good end goal. Is there a price catalog or something?
Posted : April 29, 2008 5:52 pm
(@davefarmer)
I know of a nearly new 80s Houlten T here in Spokane that's been sitting in the rafters since it was stored 20 years ago. I think it was sailed one season and then carefully put away.
Dave 509 276 6355
Posted : April 29, 2008 11:23 pm
(@walke)
Quote
money
and
looks
True enough to think about. I did pretty well in Miami Key Largo (3rd in class, 11th over the finish) and corrected out in front of a Tornado Sport with a more than highly skilled crew. The best part was that I was just happy toi have finished the race with no break downs, and no blood spilled. There are however more hard parts on the boat than I remember from my competetive days int he late 80s-early 90's.
Posted : April 30, 2008 2:24 pm
(@tomsiders)
I think that I still have plans and templates for a tornado kicking around. I will look tonight and let you know. My tornado took 6 months to complete with building 1-2 days a week. I know that Tornado racing in this country has diminished over the years and you can find some older T's out there for sale. I do not for a minute regret building one and it is still my favorite platform to sail. the big down side to Tornados is the transportation issue. If you have a place to keep it rigged then it is not an issue.
Posted : April 30, 2008 3:19 pm
(@bronco9588)
I have a nice beach about a 10th of a mile from my GF house. The community has no problem with beached cats... there are 5 hobies including my dieing one.
Posted : April 30, 2008 4:33 pm
(@Anonymous 39155)
You gotta come up to Gulfport!
Posted : April 30, 2008 4:44 pm
(@bronco9588)
Posted : April 30, 2008 5:01 pm
(@bronco9588)
Hey Rolf,
Can you give me a review of the plans for the Blade?, and the basic outline of cost? Thanks.
Posted : April 30, 2008 8:50 pm
(@Anonymous 39109)
the f18 blade that is here in AUS and is the one pictured here is timber. http://www.formulacatamarans.com/
If you are keen contact Phil Brander phillbrander@bigpond.com
he will be able to assist.
Posted : May 1, 2008 1:30 am
(@Anonymous 13024)
Review of the Blade F16 plans? Well, I am pretty biased as I count Phill as a friend.
To build to the plans there is some stuff you will have to think through, but that is the case with all building projects. I think the plans are good. They would be better if illustrated by a professional, but all you need and then some is in the plans for the ply Blade F16. However, as a first ply/epoxy project, it is a large project. Instead of plunging into a 200+ hour project, how about doing a plywood kayak from http://www.clcboats.com/ to get to know the tools, materials and processes. Better to cut your theet on a small project than learning the hard way that building was perhaps not what you thought.
Cost.. The answer to this will always be
it depends
. It depends on what gear you put on the boat, how you get a rig on it, sails, foils, rudder system, lines, building materials, how you use those materials, tools you need to buy, renting a building to house the project. Manufacturers can often strike deals with Harken, SP and others so they buy all their stuff at a lower cost than you can. If you know where to get good deals and have the right connections, homebuilding can be done cheap. If not, your boat might cost more than a new one from the manufacturer! An estimate for a first go with some reality in it might be the cost of a new boat minus 20%! Buying something used is attractive..
When I did the first boat, I bought a wreck of a Tornado for the gear and the rig. I then went on and spent 8 years sailing tornados instead of the boat I had built. Buying the wreck of a beachcat for the gear can be a money saver, but it can also seriously sidetrack your project. Sailing is even more fun than building..
You still have not shared why you want to build. As I wrote earlier, I definately dont recommend someone to begin building unless they are doing it to enjoy the process of creating something. If the goal is to save money or go sailing on something special, there are some long odds that the project will not be completed. Sorry to say so, but it is much better to get all warnings and think things through before spending money.
Posted : May 1, 2008 11:40 am
(@bronco9588)
I actually live about 4 miles from CLC. I like their shop. I had 2 CLCs for a while.
Posted : May 1, 2008 7:30 pm
(@kevin-cook)
I have built three of them. I have plans for the cose of postage. just give me your mailing address.
Kevin
Posted : May 2, 2008 1:28 pm
(@Anonymous 13024)
Kevin,
Catsailor have a homebuilders forum now. Would be good to see you post there from time to time.
http://www.catsailor.com/forums/postlist.php?Cat=0&Board=Homebuilt
Posted : May 2, 2008 1:42 pm
(@bronco9588)
Matthew Carr
1251 Turkey Point Road
Edgewater, MD 21037
Posted : May 5, 2008 9:01 am
(@Anonymous 39832)
Kevin Cook is the man.
His backyard is a carbon addict's wet dream.
Posted : May 5, 2008 9:30 am
(@bronco9588)
Posted : May 5, 2008 2:07 pm
(@catmancan)
I would like to get the tornado plans you have.How much fir the postage? Also, I am interested in any thoughts you may have about building a 30 Tornado. Thanks. Robert Heess, PO box 1139, seaside, Oregon 97138
Posted : March 24, 2017 6:01 pm
Page 1 / 2
