Miscellaneous Maintenance
I wanted to run by what I was going to do to my boat and see if anyone has any ideas on whether there is a better way to do them.
My boat has a hole about the size of a pencil (it might be as big as a dime or even a nickel after I clean it up) from a wind storm. It is up near the bow above the waterline. My plan was to pull a small wood block with a thread up to the back of the hole and glue it there. Then I was thinking about filling the hole with some bondo marine epoxy (stick) I have. I guess I could get some epoxy resin and mix it with some fiberglass threads and put that in there. I would just have to buy some epoxy resin. Then I will gelcoat over the repair. The boat is a foam sandwich.
What do you think about this? What should I use to glue the block?
The second thing is the bottom of my boat. The gelcoat is worn down to the epoxy due to repeated beaching. I have bought new gelcoat. My plan was to sand down the underside and hit it with some acetone. Then I was going to paint on the first layer with a paint brush over the bare epoxy areas making the layer 1/8” to 1/4” and trying to taper it into the unaffected areas. Finally, I was going to use some gelcoat that was heated to coat the tapered gelcoat. Phil told me this heated gelcoat would produce a smoother finish. Then I would spray the gelcoat with a yet to be determined curing agent. Then I plan to sand the gelcoat smooth.
What do you think about this? What curing agent should I use? Has anyone used pledge? The stuff sold at west marine looks like it is sprayed by a “windex like sprayer” I am not sure how that will work.
Thank you for your help,
Matt
The curing agent you are referring to is most likely a mold release agent. You can spray this over the gel repair so that it cures tack-free. Gel coat that cures in the open air will remain tacky - great if you are going to apply more layers, not so great for the finish.
Some guy on the beaccats web site did the same thing to his 6.0 hulls and apparently he used pledge spray to block air from getting to the curing gel-coat.
http://thebeachcats.com/modules.php...
Matt,
Just about anything will work for that pencil sized hole. Marine Tex would be a good quick and easy solution - I don't know that you even need the piece of wood on the inside...but it wouldn't hurt. It's probably not very structural so having glass fibers in the repair isn't critical.
I don't recall what kind of boat you sail, but if your bottoms are worn extensively, you probably need a layer of fiberglass in there to rebuild the bottoms before a top coat. Some put Kevlar fabric on the bottoms instead of fiberglass because it has considerably better wear characteristics. Also note that if you intend to gelcoat on top of your repair - do NOT use epoxy. Use polyester resin instead because gelcoat does not adhere as well to epoxy resin.
With regard to gelcoat...I'm learning a bit too there (www.teamseacats.com). I've yet to try and cover a large area with it but there are multiple options and methods for coating an open 'wound' with gelcoat. If you are spraying it, you will need to thin it somehow. Some recommend using acetone to thin the gelcoat, others claim that's the worst possible thing and recommend using styrene (a rather harmfull chemical). You can purchase gelcoat that already has a wax additive in it so that when you spray it the wax floats to the surface and seals the gel so it will fully cure. Other "mold" system gelcoats are intended to be sprayed in the bottom of a mold before glass is laid on top sealing it off. the "mold system" gelcoats require either the wax additive or a top coat of a PVA (poly vinyl alchohol) to seal out the air so it will fully harden. I'm going to be experimenting soon and will keep the website updated.
In my experience I don't like the wax additive. The gelcoat will cure fine with the wax. But the finish is not as nice as if you spray it and then use PVA. So wax in my experience causes you to have to sand quite a bit. I'm sure pledge is basically the same thing as PVA. Anything that keeps the air out will work. I've heard wax paper, hair spray, PVA, Pledge, ... I would just use PVA. It's cheap and it washes off.
Mike Hill
www.stlouiscats.com
Jake,
I have been looking at the pictures on you site every couple days. Thanks for the tips; I will use your suggestions.
Matt
Mike Hill
www.stlouiscats.com
I was just at the store and all the pledge products they had make a big deal about not containing any wax. I don’t know if they changed the formula, has anyone used pledge recently?
Matt
I use the wax additive and find it works well. Don't over catalyze the gelcoat and make sure it's at least 70 degrees. Mix it well. The only time I have trouble is when Gel is sprayed over epoxy. Styrene to thin.
If you do a search you'll find a lot of info on this.
ok, i ve watched this kind of stuff here for years now. it is chemistry. plain and simple. pledge may 'work' but it is not right. pva will 'work' but it is not right. use the wax additive and be done with it. this is why these things are made. it is what the professionals use. dont screw with the chemistry.
Gelcoat is resin mixed with a thickener and color added. The resin is usually not a finish resin (containing wax). If I have a small repair I can mix a bit of coloidal silica (not microballons) with finish resin and color. You have to add a bit more hardener to this mix (same as you would with gelcoat). This drys pretty nice. You just mix enough thinkening material to get to a gelcoat consistancy.
Most of the time gelcoat is sprayed or brushed on the inside of a mold then glass and resin is put over the top of that. This seals the gelcoat from the air and allows it to harden nicely. If you watch a repair shop add gelcoat to the outside for a repair, they will spray it with PVA. This is just a spray-on plastic material, usually green, that is water soluble when dry. A water wetted sponge will take it completely off.
Later,
Dan
dan, ive been building boats and doing repairs for the last 20 odd years. dont do it, just add the wax. that is what it is there for.
Later,
Dan
Listen to Basket.case…I have been using fiberglass for 39 years…use the wax additive. I don’t know where these off the wall fiberglass techniques come from…probably someone that didn’t have a clue what they were doing in the first place, screwed up the job by using tooling gel coat (no wax) and then tried all kinds of stuff to try and salvage the job.
Use the wax additive…if for some reason you can’t find it locally you can make the same thing by dissolving some paraffin wax shavings in a small amount of styrene…but use a wax additive.
Fiberglass is not a mystic art…get the right products…use them as intended …and you will get predicable…repeatable…quality results. Make up your own rules as you go and you may be dealing with a sanding nightmare. Ever sand wax free gel coat?…I have…it’s a royal pain in the butt. It can turn a half hour sanding job into a day long sanding job...
Seeker
Yo Basket,
I didn't mean to imply you didn't know what you were doing - you have to admit that there is a lot of confusing information out there about applying gelcoat.
I do have a question though - what should I look for and where can I find the wax additive? I hear that you can make it by disolving parafin wax in styrene but I really don't want to mess with all that. I have found a "Duratec high-gloss additive" that appears to do both thinning and adding an air dry additive - do you know of this stuff? Apparently it's widely used in mold making.
Secondly, I ran across some info about spraying gelcoat that I thought looked interesting. You spray three layers, each wider than the first. Pre-thin each batch/layer..mix the catalyst and spray the first covering about 75% of the repair area. Cear the spray gun with acetone (or styreene). Catalyze the second batch and spray it covering 100% of the repair area. Clear the gun again with a small amount of acetone. The third layer should already be thinned but have the wax additive (whereas the first two did not). Catalyze and spray the third layer feathering it out over the non-repair areas as you go. Thoughts? Comments?
jake, it was not taken that way.
you should be able to get 'air dry' at your local composites store. where ever you get the rest of your stuff should have it.
ive used duratec a fair bit, in all of its' forms. it is good stuff. still though, use the air dry. 5%. the high gloss makes the repair 'nicer'.
chances are you would spray the repair area wet on wet for the best results. if you have air dry in your gel wet on wet will be fine. the types of repairs we generally talk about here are no bigger then a softball and done outside so to do it any other way you risk contamination. dust, dirt and bugs.
find attached a bit of duratec work i did a while ago.
- 663 Online
