N20 shortened side stays?
I used shorter stays also. The standard measuring method we ( and most N-20 guys) used was trap with a line held to the bridle tangs instead of the spin tangs, marked and then pulled back down the transom. We usually carried the rake around the top of the tang that holds the rudder down, but would vary a hole either way depending on conditions.
I don't know how you guys carry that much rake without the rudders being utterly worthless around the A-mark.
I never liked the feeling of a heavy-raked mast. I know I'm not exactly lighting up the results board but the boat just doesn't *feel* right upwind with that amount of rake on - personally speaking of course.
I bet ya a bottle of rum more rake is faster... Oh yeah, I already did that. By the way, at the rate your paying up, you just as well buy a distillery.
I had gen 1 rudders, and felt that having rake was a good idea, and had the shorter sidestays which put my setting about the middle of the chainplate. I noticed that having a vertical mast didn't help me point that well (despite my pinching prowess), and sometimes the rudders would stall power-reaching. A little bit of additional rake (from vertical) seemed to settle that down a little bit (along with less daggar and moving back sooner)
I think you get far more enjoyment prodding me about it than you would out of a bottle of rum.
At this point the interest is at least 2 bottles , so pay up the interest and I'll let you keep paying on the principle. And I think you may be wrong about how much joy I can get out of a bottle of rum.
Your right, I was measuring from the bridles, not the spin.
This is the setting I've settled on for the general purpose all-around setting. Really woke the boat up after trying to make more rake work for it. Having the mast raked a bunch only seems to work for us if it's blowing. But then I also use the gen 3 rudders, sail heavy, and bend the spin pole quite a bit to get the right luff tension on the spin.
- 2,258 Online
