Nacra 5.5 rudders
8 Users
(@h17racer)
[#18286]
Could someone give me pointers on replacing the pull-up bungee lines on a Nacra 5.5 rudder system?
It looks pretty straight forward. For each, the plan is to use 5' of 5/16 shock cord with a couple of stainless hog rings to bind the bungee ends. Could it be that simple?
Pull-downs will be replaced at the same time with a 3/16" prestretch line.
Sail fast, Tom G
Posted : August 15, 2006 7:39 am
Rob Vaden
(@redtwin)
I replaced the same lines on my 5.2 . It is that simple.
-Rob V.
Panama City
Nacra 5.2
Posted : August 15, 2006 7:49 pm
bullswan
(@bullswan)
Quote
Sail fast, Tom G
I took the opportunity to eliminate the bungies and went with a pull up / pull down system. I much prefer the ability to lock the rudders at any setting in between all the way up and all the way down.
Good luck,
Greg
Posted : August 15, 2006 8:08 pm
(@kennethsf)
Bullswan
which system did you use?
Posted : August 16, 2006 3:24 am
(@h17racer)
Thanks for the suggestions. Did one rudder last night. Simple, although lesson learned, always recheck the precut lengths before installing. Guess the cordage person decided to be a bit generous.
Sail fast, Tom G
Posted : August 16, 2006 7:38 am
bullswan
(@bullswan)
Quote
Bullswan
I got rid of the bungie cords and use two pull cord lines one to pull the rudders down and one to pull the rudders up. I used two Ronstan Cleats so that I can adjust the amount of UP or the amount of DOWN I want and it stays there. I also got rid of the slop in the tiller/tie bar connection by using tie-rod ends instead of the existing connectors. I got the idea from a prior posting. Can't take credit for what I stole!!! <img src=
Greg
Posted : August 16, 2006 2:20 pm
(@kennethsf)
Quote
Quote
Bullswan
Greg
Guess it was me, I posted a picture with the tie-rods about a year ago, still works perfect for me. Nice to see that you use them as well!!
Posted : August 17, 2006 8:11 am
(@h17racer)
Ken, for those of us who did not see your tie-rod ends. Could you enlighten further? I added Hobie 20 connectors to my H17 and they worked rather well.
Just finished refurbishing my rudders and they work like a dream. I added Hobie connector bushings in each of the pin connector points and basically eliminated all of the connector looseness.
Rudder bushings are next.
Sail fast, Tom G
Posted : August 17, 2006 8:30 am
bullswan
(@bullswan)
Quote
Quote
Quote
Bullswan
Greg
I'm sorry Ken for not giving you the credit directly but I did use your suggestion from last year and I love it. I didn't use the control lever on the rudder arms you designed. Instead I went with two simple Ronstan Cleats to control up and down of the rudders.
Posted : August 17, 2006 9:15 am
(@kennethsf)
Quote
Quote
Quote
Quote
Bullswan
Greg
no problem <img src=
/> for the others: I fill try to find the pictures and repost them
Posted : August 20, 2006 4:26 pm
bullswan
(@bullswan)
Here is one of the pictures.... I saved it.
Posted : August 20, 2006 8:46 pm
(@h17racer)
Woaaa, now that is industrial strength! Thanks for the pic post bullswan.
Sail fast, Tom G
Posted : August 21, 2006 5:17 pm
(@kennethsf)
found the other pictures
Posted : August 22, 2006 7:40 am
(@kennethsf)
another
Posted : August 22, 2006 7:41 am
(@kennethsf)
last one
Posted : August 22, 2006 7:42 am
Jake Kohl
(@jake)
I remember that now...I really like that flip lever you came up with...now if you can just figure out how to make it work the opposite direction and be able to adjust the height of the line as it turns toward the pivot arm so you can infinitely adjust the amount of pressure required for release...!
[Linked Image]
Posted : August 22, 2006 8:56 am
Jake Kohl
(@jake)
Here's a thought...use a couple of those harken micro-through hull sheaves running part of the line internal to the rudder arm...The black standoff on top of the arm could be adjustable to control the angle of the line leading to the flip lever allowing you to really dial in the amount of pressure required to automatically release the rudder from a ground impact (or fish).
[Linked Image]
Posted : August 22, 2006 9:07 am
bullswan
(@bullswan)
Here is my version.
Posted : August 22, 2006 1:57 pm
bullswan
(@bullswan)
Number 2 picture...
Posted : August 22, 2006 1:58 pm
(@catman)
Quote
Number 2 picture...
Greg, your tiller arm looks like it's pointed in the wrong direction. Looks like you might of swapped the castings.
Posted : August 22, 2006 2:08 pm
bullswan
(@bullswan)
Man you are good!!!
I only put it on that side of the boat for picture purposes... Good eye!
Posted : August 22, 2006 2:13 pm
(@catman)
You had me worried for a moment. <img src=
Posted : August 22, 2006 2:18 pm
(@mystere50xl)
Quote
I agree. That's why you needed the long extension in the crossbar that's visable in your photo.
Anti-Ackerman steering? <img src=
Posted : August 22, 2006 3:33 pm
(@Anonymous 38749)
Thisw is an old factory version off my Hydra 16.
Posted : August 22, 2006 10:00 pm
(@Anonymous 38749)
Another try.
Posted : August 22, 2006 10:05 pm
(@kennethsf)
Quote
[Linked Image]
Like your idea as well. Please keep in mind that the intention is to both lower and raise with the one arm [see the second line on the picture-lower on the arm-other side]and and it can be converted back to the original system without any damage [as safety when making this system up]. When sailing on to the beach I normaly release the arm from the black
clamp
[not sure if this is correct English]and pull forward to raise the rudder.
The
pull forward
is not realy needed, the rudder will be raised gently by the beach.
If the rudder is in lowered position it
sticks
there due to the fact that the arm is over it's turning point [line attachment is slightly lower then rotation point - bottom of arm] The attachment point of the both lines are very importent!! this took the most experimenting to figure this out.
If something hits the rudder when in lower position and in clamp, the rudder will come up if the resistance of the both the clamp and the
dead point
is overcome.
At the beach I keep the rudders
up
with a little bungee
o-ring
that is near the tie-rod
It is a bit of long description but I hope it is somewhat clear.
Posted : August 24, 2006 3:19 am
