Nacra 6.0na question
I just received my new foil from Performance the other day and it is about 3 inches longer on either side and about an inch taller than other 6.0na foils when holding them side by side. Is there any explanation that someone could share as to what the heck happened? I can't see the foil size changing, plus it doesn't fit to the bridal tangs correctly.
Is it possible there is some European model of the foil for a 6.0 that would explain this? Any help is most appreciated!
It seems the factory has been shipping the wider foil for sometime now due to "incorrect part numbers". Maybe things were crossed with the Express model you mentioned... it seems to be the biggest mystery between Murrays and Performance! Supposedly the correct foil is enroute this week. I'm crossing my fingers... again!
Thanks for the note.
- 1,942 Online
