Nacra mainbeam and dolphin striker
Tobin,
Keep it simple, with no load on the beam your beam should be level and/or
straight
, then simply screw the lower nut up 3/8 in. and then tighten your upper nut. Just curious, after you straightened the rod, did you put a compression tube back inside the beam? If you did I hope you marine greased the snot out of it. . .
Posted : April 1, 2008 8:50 am
Forum Information
- 2,733 Online
Our newest member: TooTallTom
Latest Post: Hobie pearl / tiger mast needed
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
