Need a little help with a Main Sheet
6 Users
NacraMike
(@mikeomnione)
[#13997]
Anybody have one of these. How do you thread it. All my attempts so far have resulted in crossed lines. The person I bought it from said it was a 7:1 purchase, but I have it rigged as a 8:1.
[Linked Image]
Mike
Posted : July 15, 2004 10:10 am
scooby_simon
(@simonJlongstaff)
I'll try and have a look at mine tonight. But others please feel free.....
Posted : July 15, 2004 10:15 am
Chris9
(@chris9)
I use the Murrays Catalog from about 4 years ago that has our 8:1 system shown in it. Ours is four in a row block as the top block. I looked at Murray website and didn't see your configuration, you may be able to find it in an old catalog.
Posted : July 15, 2004 11:33 am
Josh Fint
(@jfint)
yours looks correct to me, you will always have some lines crossed because you have to come back to the center to exit the block.
Posted : July 15, 2004 11:37 am
(@Anonymous 37800)
I've attached photos of my stock Hobie FX-1 block&tackle. Not exactly the same, but maybe it will help.
Hobie FX-1
Sail#211
Posted : July 15, 2004 12:45 pm
(@Anonymous 1598)
hey that looks familiar!
Boat is up for grabs now if you want that to compliment the mainsheet
Posted : July 15, 2004 12:46 pm
Bob Hall
(@brghc)
Not the same as yours, but the Harken web site has illustrations of 6-1 and 8-1 main sheet set ups.
http://www.harken.com/blocks/taclpwr.php
It might steer you in the right direction...
Posted : July 15, 2004 2:37 pm
scooby_simon
(@simonJlongstaff)
Mike,
Looks fairly similar to mine, I have just rigged it so that the top and bottom blocks (when under some tension) are running aprox 90 degrees apart
I also have all the 'outside' turns before the inside turns and then finally to the top of the cleat to tie off :
[Linked Image]
Posted : July 15, 2004 3:07 pm
scooby_simon
(@simonJlongstaff)
Mike,
Also, I have tried here to colour in the loops as they go around the system :
Hope this helps
Red / original colour in the inside loop
Here :
[Linked Image]
Posted : July 15, 2004 3:14 pm
NacraMike
(@mikeomnione)
Believe I have it sorted out now with all your help.
Thanks much for taking the time to respond.
Mike
Posted : July 16, 2004 2:31 pm
