New boat type launched
G'day,
Thought you may be interested in the recent launching of Elementarry, a 7.5m/25' proa with 4m/13' windward hull.
Schooner rigged, unstayed carbon masts, telescoping beams (2.4-4m/8-14'), 22 sqm//235 sq' sail, and weighing 120 kgs/266 lbs, although the next one will be considerably less.
A few issues to be resolved, mainly with the sails and me getting fit enough to move around quickly, but so far it goes pretty well.
For pics and the story so far, see http:/
Rob
wierd looking. It would be interesting to see it up against a beach cat. I figured by looking at the images, that in order for it to sail both ways, the vessel has no stern or bow? as both ends can act as either OR?!?!? also the sails have to rotate all the way around?
Looks killer, and kinda scary. Just like those C clase
catamarans.
ooooaaaahhh please explain this photo?![[Linked Image]](http://www.harryproa.com/Elementarry/Jan2005images/Lg/P1010113.jpg)
the boat is sailing in reverse, but not really? the sails are inverted? confused!!!
G'day,
Weird indeed, but actually just a cat optimised to not have anything surplus to requirements.
Should do well against the beach cats as it has the same sail area and righting moment as a Tornado, but is 25% longer, 25% lighter with a lower centre of effort. What it does not have is a gun crew or the benefit of 30 years development by the world's best scat sailors.
It is double ended. The crew always sits to windward, so this hull can be very small as it is only required when not flying a hull. The rigs rotate through 360 degrees, the rudders through 270. To shunt (equivalent of tacking), the double ended sheets are released, and pulled in at the other end. The rudders are rotated and you head off in the other direction. We are at the stage where we can go from hull flying to hull flying at about the same speed as a cat, but with practise should be fatser. Downwind is the same technique, but at this stage, slower. In both cases, the maneuver is totally reversible at any stage, which should make starting a whole lot of fun.
In the photo, the boat is running near enough square, approaching the beach. The aft sail is doing all the work, the front one is in it's shadow. Going wind and wing is one option and gybing downwind another.
Stewart, the picture is on Coff's Harbour. Should have it over here later this summer. Let me know if you want a sail.
Rob
If your downwind speed is high enough the front sail will not be in the shadow of the rear one and the two combined can actually make a quite powerful rig. The rear sail will have to be sheeted in further because the front sail will skew the angle of attack of the rear sail. Be sure to put tell tales in your sails and sheet you sails to those.
WOuter
Coffs? Ok. just looked like the rocks in the bays down south. But Coffs is nice, lucky buggers..
Im wondering about the centreplate. O understend or think I do about the mechanisms employed with the rudders. But not sure how your pulling off doing a rotation on the plate. Any clues?
First thing I noticed in all the pix was the bad wrinkles in the mainsails.., not enough downhaul.., even when sailing off the wind when you cannot be oversheeting.
Also, I was privileged to sail on an outrigger in Saipan. It was sailed by real natives with all the parts tied on with local woven weed. It was quite an experience.
And in tacking it did the same thing that you have described. But, it was a very, very slow procedure.
How can you swap ends with the rudder that quick and claim it will tack with modern beach cats?
Just curious,
Rick
G'day,
No centreboard. Just 2 oversize rudders in daggerboard cases hung off the side of the boat. A fixed centreboard makes shunting too slow and adds weight and cost as you still need 2 rudders. Two foils are all that is needed, and if they both rotate, they work much better. Can even angle them both slightly to force the boat to windward. Experience so far is that this is very costly in terms of speed, but handy when jamming for a mark, or stopping someone going past to windward.
Rob
G'day,
The luff tension is inadequate. Not enough purchase, too much friction from the batten camber inducers. Working on it. May also be some luff round issues?
Not sure what you mean about swapping the rudders? All we do is rotate them through 180 degrees. The helmsman has 2 tiller extensions. When the boat is stationary he pushes one, pulls the other and round they go. The slow part is coming to a halt, although reverse sheeting the sails does this pretty quickly. With practise, we should be able to luff head to wind until nearly stopped, then sheet in the new aft sail, move crew forward and spin the boat round to hard on the wind on the new tack. This will be slower, but should have better vmg. Hope this is clear. We will be making a video next time we go sailing which may be a bit clearer.
Tacking from reach to reach we are definitely quicker, although this is not a whole lot of help!
Tacking downwind we are definitely slower, but crew weight movement will speed this up.
Rob
G'day,
You can lift the front rudder, and many proas do. I don't as
1) Two rudders in permanent use can be half the size of one at a time
2) Control with a bow and a stern rudder is awesome, particularly during a shunt where speed is slow
3) Lifting and lowering is more work, at a time when you are already busy.
We do only use one downwind, and as we get better, will only use part of that.
Rob
G'Day Rob,
First of all, congratulations, I strongly admire people who think out of the box.
My question is how did you decrease the weight/surface area relation, for example comparing to a tornado. On light winds I can see the advantage, as you basically don´t need the weight of the winward hull, but on strong winds I believe that the extra weight of the cat would be an advantage, because the weight of the winward hull and the weight of the rig are helping to reduce heel. In this boat, all the weight of the boat, except for the crew and the small hull do not counterbalance heel.
G'day,
Rudders at 90 certainly slow it down, although nowhere near as quickly as sails at 90. Both waste inertia/energy/whatever it is that keeps you going forwards. With a bit of practise, we will kill the speed by luffing head to wind. Unlike a cat, where this is done as quickly as possible to maintain momentum through the tack, on a proa it can last a lot longer. Once the boat is stopped or nearly so, then rotate the rudders, sheet on the aft sail, move crew forward and spin it round onto the new tack as quickly as possible. Maybe not as good vmg as a cat, but should be close, with no chance of getting into irons.
Rob
G'Day Rob,
G'day,
Thanks.
By increasing the beam. A Tornado has rm of half it's weight (80 kgs) x it's beam (3m) plus 2 crew (160 kgs) x beam. RM~ 720 kgm
We have 2 crew (160 kgs) plus ww hull plus half the beams (20 kgs)x 4m beam RM~720 kgs.
The weight cost of increasing the beam is offset by the weight saving of not having to support the mast in the middle of the boat and not having a boat which has to sail on both tacks.
Rob
Very clear. The lack of trapeze would also be a need to add some cm to the beam, or some wings, doesn´t it? Anyway, adding beam to this boat doesn´t seem to affect it´s performance as it would on a cat (particularly on it´s turning ability).
Other things that called my attention are:
- The lack of stays, that must be a very special and expensive mast?
- The front rudder is just left free or is it necessary to fix it while sailing?
- Very clear. The lack of trapeze would also be a need to add some cm to the beam, or some wings, doesn´t it? Anyway, adding beam to this boat doesn´t seem to affect it´s performance as it would on a cat (particularly on it´s turning ability).
Could add trapeze although the short masts/wide beam may make this uncomfortable. Wings are easy as the same hull is always to windward, so there are no tripping issues. Extra beam will mean it will exceed 8' on the trailer. Certainly is not a problem for tacking.
Quote
Not at all. Each one is 8m/26' long, weighs 12 kgs/25lbs and we sell them, unpainted for $Aus2,000/$US1,500. The trick is in the form of the carbon (tow, not uni) and the construction method.
The loads on it are pretty light, it can be tied off. Very handy to have it when sudden turns are required, though.
Rob
When going upwind, what happens when the boat is sideways to big chop as you are turning it? It does have to be broadside to the waves temporarily, doesn't it?
The waves go undermneath, it wobbles a bit, but very little. Has to be pretty big waves to affect a 4m/13' beam. The actual time spent broadside would not be more than a single wave, so I guess you could chose your momment, much like when tacking. So far, though, it has not been a problem, on this or the bigger ones.
regartds,
rob
Great looking proa Harry -Proas have a long history of course ,-The most famous being Cheers by Newick raced across the Atlantic in the 1968 OSTAR --it was an Atlantic --{ proa smaller hull to leeward } rather than Pacific Proa
here is the copy --CHEERS, Dick Newick's 1968 OSTAR Atlantic Proa
Painting by Bruce A. Alderson, ASMA
68 Wilmarth Bridge Road, Rehoboth, MA 02769 (508)336-5298
CHEERS was piloted in the 1968 OSTAR (Observer's Singlehanded Trans-Atlantic Race) from Plymouth, England to Newport, Rhode Island by skipper Tom Follett in 27 days, 13 minutes. He finished 3rd overall, beaten only by two monohulls, the 56' Sir Thomas Lipton and the 50' ketch Voortrekker. Follett sailed from the Caribbean to England before the race and from Newport back to St. Croix afterwards.
For the full story, read 'Project Cheers' (Adlard Coles, 1969), a book detailing the saga of Newick's giant-killing Atlantic proa.
Race Committee letter, October, 1967: Royal Western Yacht Club of England
"I notice that you are taking steps to enable the crew to right the vessel when it has capsized, but my committee are more interested in any steps you may take to stop the capsizing in the first place. We are still of the opinion that to race along at 25 knots in between periodically capsizing is not a proper way to cross the Atlantic..."
end copy --
Great craft ,congrates Harry ,looks like great fun .
all the best
Carl
Just a comment about the name, if you forgive to give unrequested advice...
It reminds me the brand of a new type of telemark skis, the "scottybobs" (www.scottybob.com). Quite an interesting development, and a successful business for the guy that designed them (guess his name..). I'm even thinking to expend that kind of money, which is above what I can pay for skis, plus shipping. But naming the brand as a person, to me limits the power of the product. It makes me think of a home made product, the guy himself making it on his garage, then having some success and making his own little company, which started to grow perhaps to an unimagined size, but still on the artisan concept, with a name that now is not quite adecuate for a big selling product (if that is what he expects now for the product anyway..). It also makes me think about scottybob's vanity... something I wouldn´t like to think everytime I use the skis...
It is my impression that you made a very cool boat, but with a not so cool name. Sorry to be so direct and if this post was inadecuate...
snip....It is my impression that you made a very cool boat, but with a not so cool name. Sorry to be so direct and if this post was inadecuate
G'day,
You mean like that Hobie chap? 🙂
Actually the name is nothing to do with me or anyone in the business. The first one was called harry as my wife liked the name (no idea why). I called them weight to windward Pacific proas, which is technically what they are. The traditionalists on various chat groups gave me plenty of stick and made a huge fuss. So we changed them to harry proas. We have since had some fun with names derived from harry such as Visionarry (50 footer for a group of blind sailors in Holland), Harrigami (35' folding version, combination of harry and origami) and Elementarry for proa learners. Some people like them, some don't. If we had to put a marketing spin on it, it might be something like "If you think the name is different, wait till you see the boat!"
If you build or buy one, you can call it whatever you like.
I thrive on directness. Please keep it up.
regards,
Rob
Hi Rob,
In that case, consider the scandinavian countries, where Harry is a quite ordinary christian name. What makes this funny, is that most guys named Harry, drives late 80's Ford station wagons, uses barbecue suits all the time, 70's style sunglasses and facial haircuts last seen in porn flicks from the same era and can easily be mistaken for a plumber when viewd from 'astern' (sorry for the prejudice it there are any plumbers here).
Can you see the picture I try to paint for you?
I have seen the hailstorm like pounding you get on the Proa list from time to time, but you are the one building boats and doing it, instead of spewing hot air.
Any racing Harry's coming up, extreme low-cost and possible to race for two days offshore for a crew of three under wildly variating conditions? Downwind under variously sized Outleaders, but able to really fly to windward in light air but steep waves. (Norway to Shetland, a stop to rest and race back)
Good luck with your European tour, looking forward to see the results from Texel and other races.
didn't someone have a problem getting a proa into Round Texel a couple of years ago?...I seem to remember it was a pretty wild design with an articulating crew pod. Has the latest Harry Proa been accepted by the Texel folks?
Personally, I kind of like the name....it is different and if the concept proves to be fast and affordable, you could probably call it "snot blob" and still get away with it.
For those of you who haven`t had a look at the web-site for this boat (link in one of the earlier posts)....
Make sure you have a few hours, I ended up getting deeply entrenched !!
Lots of info about proa`s in general, lots of good VR images of all the designs. And some interesting designs, especially on the bigger boats. And if his material lists and building costs are accurate, I think I`ll be sending off for a set of plans, one day when I grow up.
Cheers
G'day,
We tried to enter two years ago with the boat you describe. Got banned, so the potential builder lost interest. It is currently being built in Sydney, with a 10.5m/35' leeward hull. Should be an impressive machine.
The latest one has not been accepted, as their contact page doesn't work. Does anyone (Wouter?) have a contact for the race committee. They have said we can race in the Dutch Open the week before and they will assess the boat. Interesting times.
Still looking for crew for all the other European races next year.
Rob
- 2,881 Online
