That's kind of like the guy that leaves me voicemails at my desk stating
I'll try you on your cell phone, so disregard this message
Post intentionally left blank.....
EXACTLY!
Shouldn't this conversation be over on the
Test
The bow looks like it is raked back more on the FXone, hard too tell any other differences in hull shape. The color really makes things look different. I wonder if the production models, both the F18, and the Carbon FXone will be produced in white, or this color.
Both look really nice!
I wonder if the boards are actually the same size as the current boards, but the holes just look smaller because of the color, and the larger volume hull.
This translates into this: a short fat foil will provide the side force needed to control the boat off the start line - when it's moving very slowly in the water. A long narrow foil will stall and not generate much lift until it achieves a certain amount of flow over it's surface. This will make a long narrow foil very sensitive at low speeds and susceptible to stall.
The conclusion is correct in general, however not only aspect ratio but also the area itself is important (a high aspect ratio foil would work, if it is only big enough). It is hard to judge the controlabilty without knowing area and span.
But even more important: I have my doubts that it will bring any hydrodynamic advantage upwind. The reduced induced drag of the increased span, might be easily overcome by the increased friction drag due to reduced Reynoldsnumber. If the area is too small, there will be also a risk of cavitation at high speeds.
Would be interesting if the production boat will have more conventional daggerboards or if they learn it the hard way.
Cheers,
Klaus
those boards would look even nicer if there were slanted slightly forward of center along the lengthwise midline. Kind of like a forward-swept wing.
I said LOOK nicer, because that would probably be inherently unstable (and collect seagrass like nobody's business!)
This isn't a production hull, It's the master male plug. Plugs are always done in dark colors.
Martin Fischer did the design work, the same guy that did the Capricorn F18.
some differents, added spray rails <img src="<>/frown.gif" alt="frown" title="frown" height="15" width="15" /> newer beam saddles <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" /> new daggers <img src="<>/smirk.gif" alt="smirk" title="smirk" height="15" width="15" /> hulls are not cantered <img src="<>/shocked.gif" alt="shocked" title="shocked" height="15" width="15" />
Rich
Price of the I-cat (FXOne Carbon) is about 17.500 euro in Europe (I guess that is the base model, one-up).
I also really wonder what the boat will weigh. Hobie Holland didn't reply yet.
In my opinion the F18 bows look very thin. I really wonder how they will cope with heavy seas under kite.
If you see the shape of the new hull, it is clear that the Cap, Viper and Blade were really innovative already years ago. Especially the Blade if you check the thin high aspect daggerboards and rudders.
Gill
i dont know if you've seen these..... but the new prototype Hobie F18 was released at the Pairs boat show in December....... its calll the
W...Cat
there isnt much of a pic.... but it has the specification!
http:/
- 1,494 Online
