new hull material
We have just taken delivery of a new set of hulls, made from a new material.
We use a thermoformed Polyproylene/glass fibre material. This has the advantages of being as stiff and lightweight as the best of the current composite boats while having very much increased durability and impact resistance, similar to that of the rotomoulded boats.
This is not a new process, it has been used by some white water Kayak manufacturers and the Royal Navy RIB's, it also used on bus bumpers!, but we beleive we are the first sail boat manufacturer to use this technology. The Royal Navy claim they can't break the boat even with a sledge hammer.
Anyway sailors can be a sceptical bunch, so I want to be able to prove that the material is as good as we say therefore we are having some tests performed at the local university. What I need to know is what is a typical layup for a strong modern composite boat, like an F16, F18 etc. so we can compare like with like. Does anyone know?
All the best
Gareth
www.fourhulls.com
Just an idea..
How about letting epoxy treated marine ply be part of the test? This material has well known properties and have been used extensively in small catamarans. Perhaps not the best if you want to convince 'modern' beachcatsailors about stiffness, longitivity etc. tough..
The F-18 Blade (ref: F-16 forum) was buildt in marine ply, and they added a lot of glass to achieve class minimum weight. So testing with marine ply is at least relevant.
Will your new hulls break if you are T-boned at speed? I bet the Royal Navy never performed that test
Since you have glass added to the plastic, will it be possible for amateurs to do repairs (unlike the usual thermoplastic) with epoxy and standard glass?
Thats a good idea, I have heard it said that this is more impact resistant than a normal GRP layup. So what is a normal layup for epoxy treated marine ply.
I would be happy to supply the hulls to be T-boned if someone wants to volenteer a boat to do the T boning
We are told it can be repaired but have not tried it yet.
Gareth
www.fourhulls.com
Normal layup varies from just the plywood (quite normal), to reinforced with glass on both out and inside.
I buildt a Quattro 16 (Richard Woods design) reinforced with 200gram glass on just the outside. The Houlton ply-Tornados was reinforced with 90gram on inside and 250gram glass on the outside (ref: http://www.thebeachcats.com/modules...
I heard the numbers for the F-18 Blade as well, but I dont remember them now. But it was quite overbuildt to make it achieve class minimum weight, this also made it quite a bit stiffer as well. 135gram and 300gram springs to mind, but I am very unsure about these numbers.
I am totally depending on my long-term memory now, but I seem to remember that Marstrøm uses a 250gram layup on the outside of his Tornado hulls. Dont remember the inside, but I'll try to find out where I read this. He mixes several types of foam, nomex honeycomb, pre-pregs, glue-films etc. in his boats, and autoclaves them to achieve his quality criteria. If you want to go that far, you can probably get more information about this from Kevin Cook who frequents this forum.
After re-reading what I just wrote, I realise that I have a terribly bad head for remembering numbers
Hope it's somewhat useful anyway..
If you want to really test the material, you can always take a sledge-axe to them (the axe you have reserved for the really stubborn, knotty and cross-grained firewood). Not very scientific, but probably very satisfying if the hulls survives
(Warning: might help you find out if it's repairable as well)
Hope you will post some results after the tests are done on your website!
As a WAG I would suggest:
For "high tech"
3mm marine plywood with ~6 oz fiberglass/epoxy on the outside and 2 layers of epoxy resin on the inside
2mm Carbon epoxy either use prepreg or vacuum bag to the highest delta P you can. If you are testing impact resistance, make up a sample with 1 additional layer of Kevlar 49 near the middle. This will reduce crack propagation.
Extreme High Tech
2mm marine plywood or 3mm cedar strip with 6 oz carbon cloth on the outside and 6 oz kevlar 49 on the inside, Epoxy hand lay-up
For production
2 layers 8 oz fiberglass cloth on the inside and 2 layers 8 oz fiberglass cloth on the outside of 4 mm marine foam core. 2 samples 1) Polyester resin, hand lay-up and 2) epoxy resin vacuum bag @ 10-15 mm Hg
3-4 mm Fiberglass/polyester, hand lay-up
Find broken production catamarans. Cut section from the side of the hull in front of the front crossbeam.
This is a guess, but it is probably not too far off.
Because it is a thermoformed plastic it doesn't come in weights that are directly comparable.
i.e. GRP cloth weights are gsm before resin is added, not sure how you turn gsm into a final weight or density as that is what really counts. Also the final weight of various gsm materials depends upon how well it is processed.
Anyway our material has a finished (processed) density of 1.5 grams/cm3 (g/cc). It has a glass content of 60% by mass and 35% by volume.
I think this is a farly long winded way of saying its about the same weight as GRP.
Gareth
www.fourhulls.com
An A-cat hull is about 7 sq. mtr. in surface area and weights about 14 kg.
The specs you give for the new material ; 1.5 gram / cm3 = 1500 kg / m3 suggest that you can make the A-cat hulls of the your material only 14 / (7.5 * 1500 ) = 1.24 mm thick. That is not going to hold.
FX-one hull weights about 35 kg and has about 8.5 sq.mtr. surface area => max thickness with new material = 2.75 mm
You are not going to make lightweight hulls with this new material.
For example marine ply comes in around 600 kg/m3. You can get 2.5 times the thickness for the same weight by using this time tried material. And thickness counts in boat building.
Sorry
Wouter
You are trying to baffle me with maths again, aren't you
1500/600=2.5 as thick ?
Oh no I've been such a fool, I wish I had talked to you before I invested all that money. That 11kg hull sitting outside must be a figment of my imagination
But seriously don't your numbers tell you something, those boat hulls aren't 1.24mm and 2.75mm of solid GRP are they? They are sandwhich construction. And so are mine.
Gareth
www.fourhulls.com
One of the great advantages of this material is it is basically the same as GRP with much higher imapct resistance, So any construction you can do with GRP you can do with this.
So for example to match an A cat construction for weight and stiffness you would use 0.5mm of new GRP/PP both sides of a 5mm foam layer, and to make the FX one you use a 1mm skin of GRP/PP both sides of a 5mm layer of foam.
Many thanks to Carlbohannon and and Rolf Nilsen for those numbers, I will let everyone know the results when the tests are performed, if anyone has any more data (Wouter?) I would be pleased to hear.
By the way when you describe cloth as being 8oz or 6oz is that 8oz per square yard?
All the best
Gareth
www.fourhulls.com
You didn't tell us that a foam sandwhich construction was used, you said it was a new hull MATERIAL.
You wrote :"Anyway our material has a FINISHED (processed) density of 1.5 grams/cm3 (g/cc). It has a glass content of 60% by mass and 35% by volume"
No mentioning of any foam content here.
Apparently, with the new post, the only new thing about this material is that it uses some other stuff to replace the poly-, vinyl- or expoy resin in otherwise the same setup.
Can we call it a new resin then; instead of a new material ?
Or are you calling Kevlar reinforced laminate a new material as well ?
Wouter
You may also want to try a plain 4 mm marine ply saturated with epoxy, no glass applied (if you warm the ply and resin up before saturating than it gets a nice penentration.
This skin setup has a rather good impact resistance as well; combined with being light weight. Homebuild F16's are build this way.
For the remainder I agree with the others
Wouter
From the most recent issue of Multihulls Magazine, there is a report on the speed sailing contest and a catamaran made of Flax fibre was an entry. FlaxCat as it is called, is from a Dutch sailor, name of Neils Haarbosch . I have not been able to find an English language webpage on most of the details, but here is what I did find: The Dope Boat
Mike.
Just a side-note: Zeke Smith in "Understanding aircraft composite construction", refers to a builder (Molt Taylor) who used paper extensively when building airplanes. I dont know the Young modulus for cellulose, but I see that Flax have a breaking strength of about 100k psi. Common E-glass 500k psi and kevlar49 700k psi. I guess the Young modulus fallows approximately the same trend.
So, it's quite possible to build a boat with flax and epoxy as matrix, but it would need to be heaver than the same boat buildt in carbon or glass.
I think it's cool that boats are buildt in different and 'new' materials. Who knows what we might learn.
Wouter,
Its not really correct to say that it is just GRP with a different resin.
The properties of a composite aren't just the sum of their parts.
To take the classic, glass fibres in epoxy as an example. Both glass fibres and epoxy are terribly brittle on their own and pretty much useless as an engineering material. It is the way they are combined that makes them a useful composite (or material).
It may not be right to call it a new material (lets say a new composite), but its more than just a new resin, as the impact resistant properties come from the way this composite forms during processing.
As John Alani points out you could make a hull out of anything that absorbs resin, but you may not get the properties you expect.
People have been trying to combine carbon and aluminium for some time with varying degrees of success, it is very difficult to get them to process together but when they do you get a great composite. This is starting to be used in Formula one.
Gareth
www.fourhulls.com
It always seems to be implied that a boat of 10 x stronger (in tension) material is 10x stronger. You boat/mast whatever does not fail in tension. That is, in laymans terms, the skin does not pull apart (on the leeward side of the hull,say) but rather buckle on the compressed side. As such, the method of spacing the layers (foam) is very important.
It is a bit like trying to push things around with ever stronger string!
This is why wood stays a firm favorite with everyone except the quantity manufacturers, and gee wizz crowd.
Honeycomb cores (wood cells?) (and other duplications of nature) are the key to this resistance to buckling.
Wouter,
"People have been trying to combine carbon and aluminium for some time with varying degrees of success, it is very difficult to get them to process together but when they do you get a great composite. This is starting to be used in Formula one."
Aircraft Industry uses kevlar skins with aluminium honeycomb floor panels, other areas use Nomex core with aluminium skin. I've been using sheet aluminium hand molded to shape, its soft and retains the shape, then covered in carbon. Its like using a one off male mold that you leave in the layup, its light and the aluminium gives you something decent to screw through or attach fittings.
Darryn
Mosquito 1704
South Australia
Darryn:
Can I ask what kind of glue and surface processing you use to make that combination stick together? It would also be good to know how you deal with electrolysis if you use carbon.
I know that you need special glue films and autoclaving, or great amounts of epoxy-filler to make alu-honeycomb stick to glass.
I got a tip some time ago, to sand the alu with 80grit sandpaper and apply the epoxy immediately before oxydation starts. Is this what you are doing?
Darryn,
What I was talking about is slightly different, I think what you are describing is a sandwhich construction, where a composite skin is sandwhiched with an Al skin or honeycomb.
I was talking about a aluminium that has carbon fibres impregnated into it.
In this case you get a composite that is nearly as light as Al but as stiff as steel.
Gareth
www.fourhulls.com
Probably, Have you seen the new machine they use to make carbon tubes. It knits a tube over a mandral. It looks a lot like the machine used to make tube socks.
If you are interested, I have ~1000 yds of 58K carbon. We could make a boom.
All joking aside, that is roughly how I made my new cross beam for the F14. I made a thin tube as a form and then wrapped it with nontwisted carbon yarn at 45 deg, -45 deg, 0, 45, -45. It is very slow. Watching epoxy harden while you do it is entertainment and makes the time go faster
I did not think about it but there was a machine on TV years ago that knited tubes when you turned a crank. It would have to be faster. I will have to check ebay.
Look up aluminum alloy M2 and I think M4. They use boron instead of carbon. It's good stuff.
There has been a steady development of metalic composites over the years. They started with dumping a handfull of something into molten metal. They are getting a lot better at it. The current best looks like fiberglass applied with a chopper gun except they are using ceramic fibers and aluminum instead of epoxy.
- 5,520 Online
