Oxen Block
(@mclarenmp)
Newby Registered
[#23137]
Hi all, I'm new to the forums and new to sailing. I just inheretid a Hobie 18. It is in decent working order except that I need to replace one of the Jib blocks. The port side has a 3" oxen block on it and I don't have the $250 to spend on another one right now, does anyone have a suggestion for something I can use for the starboard side that is a little less costly at least for a month or so? Thanks a ton, and thanks for having me on the forums.
Mike
Posted : July 9, 2008 8:25 am
(@dogboy)
The Oxen blocks are not the standard blocks on an 18, but some people prefer them as they are usually easier to uncleat. One of the problems with them is that there is a part inside that eventually fails and then does not allow the block to release. If you intend to use the Oxen blocks, it a good idea to send them back to the manufacturer and have them rebuilt (I think you can do this throug Murrays).
Originally, 18's came with Seway jib blocks which are horrible when it comes to uncleating. The later boats came with Harken's which are much nicer. If you go to the Hobie web page, you should be able to access the parts guide in the online catalogue which calls out the Hobie part number (60330041) for the Harken block. Otherwise, contact your Hobie dealer.
Basically what you're looking for is a single rachet block with a becket on top and a cam cleat. It can be seen in the murrays catalogue under the jib sheeting section. If you still have the slider and stand-up spring from the original block, you can re-use that. Otherwise you will need a complete assembly. Murrays lists the block alone for about $140.
Posted : July 9, 2008 2:43 pm
(@_removed-account)
Four Star Admiral Registered
you can also look through thebeachcats.com i think there are seveal guys selling hobie gear...
Posted : July 9, 2008 3:11 pm
(@edgarapoe)
Never like the Oxen Blocks. Doesn't make sense that you have to pull a sheet that is already tight to release it.
This is absolutely the best block on the market for jib sheeting as it is ratchet when pulling and holding, and free-wheeling when load is released. Fewer blown tacks.
https://store.catsailor.com/pc/viewPrd.asp?idcategory=0&idproduct=8833
Rick
Posted : July 9, 2008 3:18 pm
