Painting w/gel coat
Rafael Quesada
(@rquesada)
[#8674]
Good day fellows
A small area of the SB hull of my H-20 needs to be repainted.
I checked w/Hobie and they sell the can of gel coat; do you know o anyone that sell Hobie white color in spray can.
Otherwise, which is the best way to paint with gelcoat.
Rafael
Posted : July 3, 2001 10:50 pm
(@Anonymous 37740)
Just had to fix a hole on my I 20. I did the finish with white gel coat. You can buy a small reusable spayer at your local marine dealer. They are caller
Preval
sprayers.
You should thin the gel coat with acetone about 10% when you mix it. The directions for this are on the can. When you finish, clean the sprayer with acetone again by spraying thru it until all the gel is out of it.
If you are spraying multiple coats, I have had good luck with spraying a coat then placing the sprayer in a bucket of ice, let the first coat get tacky, then spray on second coat. This worked for at least 4 coats.
It is very important to cover the gel coat so it will
go off
The easiest thing I have found was PVA Mold release spray.
All the directions are on the products. Read and follow them.
Posted : July 4, 2001 5:09 am
(@basketcase)
there is an additive called 'air wax'. mix this at 1.5-2% with the gel. this will do a better job of getting the gel to go
off
, well not stay sticky. i know pva works, but it scares me to use it for this application.
Posted : July 4, 2001 10:13 am
