yep, I learned my lesson this way too .... gotta tie down the F16's (and secure the mast rotator to keep from oscillating).
http:/
Live coverage of Course B for the F18's. Really want to follow the N20's...but can't find anyone providing updates anywhere online. Been to Velocity sailing, here, anarchy...
We keep warning everyone for this, but for some reason most people prefer to learn it the hard way.
Besides, with so many F18's around there isn't really any excusse to not tie your F16 down to a secure point properly ! <img src="<>/grin.gif" alt="grin" title="grin" height="15" width="15" />
On out games we used our trailers as secure point. Two F16's side by side with the two trailers on the outside on other side. Then use the trap lines and some additional line to ties everything down.
Worked great !
Wouter
Unfortunately, my boat was staked down and the mast rotator was taught. It pulled the nearly 4 feet of the auger out of the sand. More F18 than F16 flipped and they were staked down as well. Wind was howling. What I did learn was to stake down both sides using the trap wires.
Mark Thomson has loaned me his Blade mast and I am back in business.
Not much to report today. F18, 20s, F16 got in only one race. Fog was a major issue. On the Alpha course with the 20s and the 16s, they literally could not find the marks. From shore, all you could see was the tops of the sails. Low winds as well. Very weird conditions.
any results out there? I found some F18 results from today in this thread:
http:/
I use various anchor methods depending on the soil.
For sand, I use 2x4 (about 2' long) with a line tied to them. I dig a hole in the sand to bury the 2x4 and then secure it to the trap line (same for the other side).
If the ground is hard I use 18" screw anchors for each side and tie the line to the trap handle.
I know that with A-Cats, they tie them down usually with dog screws (do not know if that is the correct term for the item) in the sand with the boat lashed to a couple of them and have seen it done a few other ways. Looking at a photo, I saw the Pease and jay had done that with their boat. Don't know if that began after the turmoil. Sorry to see the damage that happened.
on the beach, I use a couple of 30
auger style anchors available from Northern Tools for a pretty reasonable $7 each.
http:/
/ www.northerntool.com/ shop/ tools/ product_200336262_200336262 On harder, more stable ground, I have a couple of 15
versions of the same auger. I've used the dog style screws for tie downs but I've broken three of the handles off while screwing them in the ground or trying to remove them from the ground. I've not had any trouble with the augers and a piece of conduit to form a
T
handle to work them into the ground.
- 844 Online
![[Linked Image]](http://surfcityracing.smugmug.com/Other/Racine-WI-F18-North-Americans/IMG9334/963636753_kwgmB-XL.jpg)
