Riveting into a carbon tube?
I'd assume a washer for a backer?
monel rivets, plenty of sealant, and a backer won't hurt.
http:/
there are special rivets for carbon fitting. AHPC/GD should be able to supply them
I've seen machined alum inserts that slip into the end of the pole, with a smoothly chamfered hole in the end for the tack line. They have a lip that's the same dia as the pole so they can be epoxied in without fasteners, and the load is transferred to the pole by the lip, not the glue.
Or I've also had alum caps constructed to distribute the loads, and the tack line could come out the end of this design as well.
Karl,
With reference to your original post:-
Things to note- If stainless is in contact with carbon it will rust or corrode. So any stainless needs to be insulated with glass or resin or something else depending on your application. So bed all stainless fittings that you add in epoxy.
ALSO Carbon is not an especially great material to drill let alone rivet. So keep drilling and especially riveting to an absolute min and bed it all in a thickened epoxy mix.
Being the anal kind of person that I am, if I was making a pole that I was going to drill I'd make sure I included at least some glass in that area of the laminate if I was going to rivet I'd add kevlar just in that area.
As your not making the pole from scratch I'd follow Team VMG's advice. Paul summed it up as well as it could.
Good luck.
Phill
- 3,009 Online
