OK,you're getting long winded again and I'm going to resort to 5 words by contrast soon.
Bundy never said he was fouled - you guys are assuming that to be the case. Even if so, it did not result in a collision. My point was, even the pros have tight crossings...everyone does. It's a fact of racing and pushing things near the limit and it doesn't result in carnage.
You sort'a have to rely on Starboard to say whether or not you fouled them if it is really really close - there's no other way to know for sure. If I made it that close and I'm not certain whether or not a foul occured, I'm going to bow to starboard's feedback and assume that he is correct (unless, he's really really obviously not correct). So, unless they do some obvious bear away (to which I would do turns whether or not they indicated the foul), the only way for me to know if a foul was committed is for them to indicate that they had to deviate from their course (it's actually written in the rules that the offendee is required to notify the offender by hailing
protest
...i paraphrase).
clean cross
is a decision you have all made (except Pete). My question is, if you are close enough to have to think about it and you decide that absolutely you can make it cleanly, do you still analysis your future responsibility and race position if the other guy calls a protest?
I believe you answered this for your self... YES...you analyze the situation from HONOR starbord right of way.
You make the call on yourself.... the other guy can do what ever he wants... but all he gets to do is give you another bite at the apple... Protest... (not foul)and your third bite of course is the protest room.
I liked your analogy of HONOR ROW.
the football analogy fails because the ref calls the foul and the gamesmanship is to convince him of such. In Sailing you call your own.
legal
cross is in the fear, confidence, and
gamesmanship
of both players. Winning racers will vote on their prowess and boat speed to go for it while others, like Pete, would back down at the 1000 yard mark and tack away or duck.
This is catamaran sailors complete bastardization of the RRS and the sport of sailing.
protest
...i paraphrase).
This is Orphans point... YOU shifted responsibility to Starbord... Starbord does not want to accept the responsiblity... He has absolute ROW. it's your responsibiltiy to call your own foul.... don't shift it! His RECOURSE is to hail protest...
So.. You cross with 6 inches to spare... 10 knots standard conditions.... starbord does not change course in the cross. They hail protest.... (AND now they are pissed off that you pushed the ROW that close, put them in the dicey situation AND you forced them to take the responsiblity to call you on it with the hail protest.
Do you expect to win or lose the protest?
No, Pete, I was crystal clear, assume NO CHANCE of a collision. Now consider you are 5 miles ahead on port and look back and see the starboard boat. Do you park and let him cross in an hour or two? How about 500 yards ahead? When does he gain ROW? When he changes course due to his fear of collision or when perhaps when he's pissed you even got near him to be ahead.
So I agree, it gets down to honor, honesty, and sailing judgement. You can cross, foul your opponent, admit guilt, do your turns, and not be a poor sportsman. Jake's original story seemed to have two results, cross and be in first or tack, gybe, duck the fleet and be in last. His decision was a big one.
Harry Callahan summed it up:
You've got to ask yourself one question, Do I feel lucky?
I bolded a particular part above - if the crossing was that close (6
) It's a safe bet that starboard doesn't consider that
clean
. I wouldn't if it were me. Starboard is obligated to avoid collision and would be reasonably expected to start changing course to avoid that potential collision. There is judgement involved. As a starboard boat, I'm probably bearing away a little toward the end of cross that's only clear by 6
to make sure we don't hit if some other variable comes into play. At that point, I have been fouled and I will make a decision, as the starboard boat, whether or not to cry foul. I don't expect port to do turns unless I indicate foul. I don't expect port to really know if he fouled me unless I indicate foul. I would expect no different as the port boat. If they ended up in the room with a crossing that close, I would expect starboard to win the protest. Starboard has to react in a reasonable manner to avoid contact...so even if you could put a tape measure and video camera on it to demonstrate that you would have been clear by 6", it may not be enough to win the protest.
Jay
I think the rules are written as HONOR the ROW because the answer to your question is... it depends.
(Types of boats, skills of sailors... lowest common denominator of sailor on the course, etc etc etc)..
Honor ROW and call you own foul handle it...
Of course, there is a culture that develops... that defines the local understanding of what's too close, and how you behave. The feedback in the system that starboard supplies by hailing protest and then enforced by the PC (usually drawn from other sailors at the reggata) does the job of interpreting the RRS.
BUT this does not shift any responsiblity for Honor the ROW of Starbord and call your own fouls on yourself to the starbord ROW sailor.
A while back the one of the Hobie class NA's had a protest on Day 1 of the event that completely redefined the accepted common interpretation of honor xxx rule (I forget the detals).... The sailors complained a lot and then quickly adapted to the standard set by the PC at the championship. The rules did not change... the HONOR the rule interpetation was reset and then enforced at the National level by the the judge and jury. The sailors got an education... like it or not.. The standards of call your own and Honor ROW do not change and the sailors called the game the rest of the regatta....
It would appear that Jake believes that Starbord must call his foul or he did not foul and that is the standard that he uses. I assert that shifing responsiblity to starbord to call him is not the RRS.
We disagree.
YMMV.
We disagree.
YMMV.
+1
We disagree.
YMMV.
I'm not sure I ever said anything like that. However, if I'm on starboard in this situation, I don't expect the port boat to KNOW that he fouled me so I want to make it clear since I am in THE controlling position. How can I expect him to know that he fouled me if I made a very slight change in my course to avoid him? Do I show up at the protest room later and tell them that
he should have known
? I'm pretty sure that won't get me very far in a protest.
very true but You are not responsible here for the rule violation call.. You are responsible for holding port to HIS responsibilities by hailing protest (and to the rest of the fleet as well)... Port already violated the rules.. you are just asking him about the violation with protest...
It is ports responsibility to stay clear .. not to ask starboard ... did I foul you?... really?... oh well sorry here is my penalty. ... Port is arbitraging their risk/reward using the rules... which are absolute and clear.
The game builds the safety margin.. irrespective of the circumstances (that Jay picked out) in writing the rules this way.
by requiring Port to both stay clear AND honor that ROW by calling your own foul on yourself (without even asking starbord) the safety margins on the crosses are bigger.... because you call the foul on your self...
You do not call the foul on yourself contingent on what starbord says, thinks or does..... that is NOT honoring starbords right of way.
I learned this racing Pearson 30s as a kid and was dumbfounded when my skipper crossed another 30 cleanly but very closely and he ordered the two circles.... No hail of protest, no course change by starbord .... He told me to read the rules.... what part of honor did I not understand. It was HIS judgement that he had misjudged the cross and violated starbords ROW.... years later... I had a senior A class sailor do the same thing... cross cleanly and then do a circle.. I later asked why?..
because I judged that I violated your ROW
I see it this way.... the rules do not let me arbitrage my risk and responsibility in a ROW situation.
I fight like hell to live up to my responsibility just like those guys and the exact reading of the RRS ... its not easy in the heat of the moment and I push crosses and forget my responsibility to honor starbords ROW.
So... you sail your own race and call your own fouls...
I object to your arbitraging the rules for your tactical advantage. That is what you were doing in the OP (had you decided to push the cross)... You clearly agree you arbitrage the rules for the tactics in all of your calculations of 70 30 etc ... clear to cross. When you count on the Starbord boat to call your foul... you have once again arbitraged the rule for your tactical advantage.
I'm good with that, although sometimes I'm not sure if my cross was as
clean
as I think it was. I usually hope to cross at least one boatlength ahead of STBD in light/moderate wind/water conditions, and more in bigger wind/seas (to allow for faster closing speeds, hiccups in wind, etc).
The
window
method (if STB stays put in your jib window leading up to the cross) gives me a good indicator of the likelihood of a successful cross, but I am a bit more cautious these days and more likely to duck if there's any question...I'm not in the kind of competitive shape or competence to push my luck
And with so many rock-stars in the various fleets these days, if I am lucky enough to be in the mix I can't discount they may have to hunt me a little bit (to maintain their position against other rock stars) rather than let me cross and disrupt their wind
clean
The
window
There is a near foolproof way to tell if you can cross or not.
If the bearings move forward, the other vessel will cross ahead of you; if the bearings move aft the boat will cross behind you. If the bearings remain constaint, you have an issue. Using this method you can see from a long way off what your situation is. You can also tell immediatly if your situation has changed (header/lift). If the bearing is changing slowly you have a close cross, if the bearing is changing quickly then the cross is not an issue.
The only way that makes sense is if your going downwind. In that situation once you can see the lee side of their sails you've already crossed regardless of how near or far away you are. Or are you saying port should never cross starboard no matter what?
We disagree.
YMMV.
This was stated first... then
Is that not opposite? I've been reading this to try to understand what needs to happen but keep getting confused. One assertion is that Port can not cross in front of Starbord at all, then you need to have a couple of boatlengths. Port has to have Honor and not cross because Starb'd doesn't need to tell him he is in the way, then Starb'd needs to tell him he is wrong...
C'mon guys, if someone that doesn't sleep with a rule book is reading this, it is confusing.
On the one hand you need to be aggressive on the course to win, sailors use the rules to their advantage all the time. What is different in this instance? If I am a Starb'd boat and I get crossed by a port boat (a few boat lengths ahead) and it doesn't affect me in any way except it hurt my pride that he is ahead... I can protest him for sailing better than me?
This I gotta read.
C
This I gotta read.
C
It does read that way doesn't it.
You can protest anything or be protested for anything. That does not mean you will win or lose in the room. But I beleive the onus is on the port boat to prove that it did not cause the starboard boat to take corrective actions. So if your are going to cross make sure that it will be clean. Not just the way you look at it but also from the perspective of the starboard boat.
As stated before the rules are to be honored. That goes for both the boats. Calling protest should only be used when you HONESTLY feel you have been fouled. And calling Protest when there obviously was no foul is not honoring the rules.
Think about it. If two boats are going to weather on opposite tacks, the boat ahead will be able to see just a sliver of the leeward side of the leading edge, particularly with a rotating mast (or the jib for that matter).
That is something I think we can all agree with and something Jake has stated from the beginning.
The first Basic Principle in the rules reads:
Competitors in the sport of sailing are governed by a body of rules that they are expected to follow and enforce. A fundamental principle of sportsmanship is that when competitors break a rule they will promptly take a penalty, which may be to retire.
In a hypothetical close crossing, Boat P (port) is expected to keep clear (rule 10).
If P fails in that obligation, then Boat S (starboard) is expected to protest (see rules 60 and 61).
If P honestly believes that she did not foul S, then P may sail on. Otherwise she is expected to take a penalty (see rule 44).
The rules do not place a burden of proof on either boat. A protest committee must find facts and act based on them. If S took avoiding action, then she must have had a genuine and reasonable apprehension of collision. If so, then P broke rule 10. If not, then P didn't. See ISAF Case 50.
I hope that helps,
Eric
I hope that helps,
Eric
What took you so long Eric? 🙂
Leaners commonly use this observation in coastal racing to determine if they are gaining or losing to competition separated by any significant distance.
So they're not crossing but going parallel with each other? What if the other boat trims their sails in or out?
- 2,165 Online
