Sail boxes
Earlier this year I got a few people together to buy sailboxes. I have a guy here that makes them, and if we get an order of 5 or more, he cuts a pretty good deal. If you are up for getting a sailbox, please shoot me an email. I want to add another to my trailer, so if we can get 4 others, they'll be $550 each. They are all aluminum (diamond plate), and are made to the same dimensions as the standard fiberglass box. The rear door open down, and the front 5' of the top comes off.
JW, TBack, Joanna, did you like your boxes?
Anybody else what? Living with John in his sail box?
I do know that back in the early 1990's we did a seminar somewhere in the Midwest, like Kansas or Nebraska, and at least three people had sail boxes that opened up into camper tents right on the trailer. Really cool. <img src=
/> I probably still have photos somewhere.
I would like one, but 10' isn't long enough for my one-peice spinnaker pole, which I think is about 11'6", can they make one 12 feet long? There is a guy in Orlando whom I have called, he built some for the local Orlando guys, but he is burried in his regular job until October, and he wants about $1,200 for a custom 12' aluminum box...
buy 4
pvc tube, a 4
to 4
straight coupling, and a 4
cap. Cut coupling in two (to get two sleeves - table saw w/ fence works well). Cut hole in bottom corner / end of box (be sure to leave room for coupling - use inside of coupling as hole template from inside the box), slide one coupling onto tube, slide tube into hole in box, slide second coupling half onto PVC inside box, slather with 3M 4200, slide couplings tightly together against box side, drill and put in three small screws into each coupling, and lightly support the front of the tube...spinnaker pole problem solved.
pvc tube, a 4
to 4
brilliant! once again, you da man.
pvc tube, a 4
to 4
That was actually a WWDLD with a light sprinkling of WWJKD.
Timbo,
I've mounted mine directly on the trailer beams (used some weather stripping as a gasket) and have about 1" clearance below the dolphin striker. Enough room to open the box (with the boat on the trailer) and slide the top section back ontop of the box...still clearing the dolphin striker.
Every time I hear a story like this I wonder if someone else found some
Cycle-Campers
in the corner of a warehouse.
In the 80's there was a company in that general area that made a tiny popup camper designed to be towed behind a motorcycle. It did not sell very well and the company went under.
These things were the perfect size to fit between the hulls of a catamaran. I knew a couple of people who did that. I bought one from a dealer real cheap, with the intent of mounting it on my trailer. A friend begged a lot and I sold it to him to mount like a tool box in the bed of his pickup.
We later found these things did not like water. They would fall apart if you got them wet launching your boat.
I have not seen one in years, I suspect they fell apart when people parked them outside like they were real trailers.
Carl
Well Mary, I know you're refering to the seminar held at Lake Perry (Kansas) but for the life of me I've don't recall any of these campers. Carl, you're probably right they must have been junk.
I've been scheming on a quick/safe way to put the double stack rails on an old pop-up trailer. The tent thing is getting old (or wait, maybe that's me getting old).
- 1,751 Online
