sail storage
6 Users
Edward
(@eddiecat)
[#939]
not been looking forward to this post:
when putting sails away for winter storage do you recc taking out battens? If so is there a handy guide to tie that knot at the end of the batten again next season?
Posted : October 9, 2009 5:06 am
Scott Finley
(@smfinley)
I always have stored the sails with battens in the sail. I would recommend loosening the batten tension for the winter if you don't regularly.
Posted : October 9, 2009 6:14 am
Eric
 Eric
(@mma600psi)
same...untie knots. The hobie guide book tells you how to retie battens. Also Hobie sells a cool device that is a "screw" tension adjustment, so you do not to tie knots anymore. I don't think that are very expensive at all either.
Posted : October 9, 2009 6:43 am
I've collected several diagrams for tying sail battens. The method depends on what type batten caps you have.
Check the Technical Album here
Batten Tying Methods
Posted : October 9, 2009 7:24 am
Edward
(@eddiecat)
thanks Mates that will do it
Posted : October 9, 2009 8:03 am
yurdle
(@yurdle)
damonAdmin wrote: I've collected several diagrams for tying sail battens. The method depends on what type batten caps you have.
nice link, thanks.
Posted : October 9, 2009 8:50 am
just to clearify...
it is best to release batten tension after every sail... this can extend the life of your sail/batten pockets slightly....
BUT its such a pain, adds time to your set up, and will only prolong the inevitable (stretch sails, loose batten pockets, etc) that its just a trade off... less rig time/ vs wearing out my sails 10% faster.....
I prefer less rig time... as i sail so often, i need new sails regardless..
Also, it makes for good practice to really know how / why to adjust batten tension. this is kind of important and can improve your sailing if you adjust for wind/wave conditions... but the same can be said.. rig time vs, on water time...
i have owned my Mystere for 2 years now (almost) and gone through 3 jibs and 2 mains and 2 spins... i am in need of all 3 replaced again.
edited by: andrewscott, Oct 14, 2009 - 11:29 AM
Posted : October 14, 2009 5:28 am
Scott Finley
(@smfinley)
andrewscott wrote: i have owned my Mystere for 2 years now (almost) and gone through 3 jibs and 2 mains and 2 spins... i am in need of all 3 replaced again.edited by: andrewscott, Oct 14, 2009 - 11:29 AM
Sound like you are sailing to much, better cut back a little 😉 You know even to much of a good thing, can be a bad thing.
Posted : October 14, 2009 7:27 am
