security ideas
It's starting to get annoying each time I visit the boat (in a gated storage facility, mind you) it seems things are missing... Nothing major (yet). a few extra pieces of cordage (which have since been secured inside the cabin) which I presume people used when moving items in/out of the facility and forgot to return...
Any thoughts on some rudimentary security to document who may be visiting? As mentioned, everything that's loose is in a locked cabin (out of sight).
I suspect they may try to use some of the miscellaneous lines I have tying down items, but I am concerned that perhaps halyards and other lines may be in danger of being
borrowed
It is hopeless to imagine anything would be enforceable (and the storage agreement waives facility responsibility), but ideally I'd love something I could submit to the facility to encourage them to pay more attention. My only leverage would be bad press on the various web areas... but would love to give them the opportunity to correct any issues I am able to document first.
Not sure if the facility is near wi-fi so constant monitoring is probably out (air card would be expensive, no?).
Perhaps a game camera?
I wondered about that, too... But if I mount on masthead, it's 8 feet beyond the stern and about 10 feet off the ground when it's sitting on the trailer...
So you could probably mess with it if you had a stepladder, but I don't think these are hardened criminals... yet.
And maybe I'm just being paranoid.. there aren't any other loose lines (that aren't attached to things non-sailors would identify) laying around... But they DID have to climb on the boat to find those lines they borrowed....
I miss my old barn. Kept out of sight, under cover, for free... too bad the property owner moved....
I was afraid of that, Mike....
Halyards are internal and replacing them with a runner might encourage repurposig the lesser quality line which would leave me having to re-route a long internal run <img src="<>/frown.gif" alt="frown" title="frown" height="15" width="15" />
As for usage, I consider this the
off
season for me. T-storms and fluky light winds are the norm until about September (oh, and hurricane thingies, too). The rest of the year I use the boat about 1-2 weekends / month. Race probably 2-3 times / yr. It's a dead-boat society member...
This storage facility is closer to home & office, so I have the opportunity to
visit
possibly 2x per week if needed. Not that it would prevent anything...
But yes, I'll recheck and remove anything that can get legs easily (gas tank, cordage, blocks) and lock or otherwise secure the rest..
or just F* it and spend $350,000 on a house with a yard
The people taking this stuff probably aren't major criminals. They're likely people that just haven't thought through the entire act of taking this or that off your boat (otherwise, major expensive stuff would be gone). They're probably looking for a quick fix to their own problem and haven't considered you or what you have to go through to deal with whatever they've taken. Place some signs around your boat that bring to mind the fact that they are impacting someone else and not just a
thing
. Whether or not they're funny, passive aggressive, or just plain old aggressive it will probably fix it.
If that doesn't do it, I'm all for electrifying the trailer with a cow fence energizer (got a plug nearby?).
they must be landlubbers... other boats are here but they didn't take the fender sitting right next to the rope.
The rope had a clear PVC sleeve (where it would rub the hull when I tied the boat with it) that they actually removed and left laying on the pavement next to the boat (BOTH lines).
That was my first clue something was amiss...
maybe a nice boat cover will work best for several things... sun damage, petty theft, and I could live in there when momma kicks me out for being an idiot myself <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
Sounds like you have two things working against you (besides the obvious low-lifes who don't respect other people's property): The availability of useful things and the potential appearance that the boat is abandoned if it rarely moves.
Could you replace the halyard with a monofilament runner or two? If you leave it and they take it, it will be expensive and difficult to replace.
Mike
Mike
I was thinking of just pulling the halyard all the way up to the sheave (right now it's shackled to the mast base), coiling up the line and stowing in some sort of canvas bag attached to the mast (so the line itself is out of sight).
But knowing me I'd hoist the mast and fasten the forestay before I realize I didn't return the halyard shackle back down to the mast base <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
I used a game camera a little over a month ago to catch a junkie stealing our tools from a jobsite.Now he's a jailbird junkie. The thing to remember is that they turn on (I used video mode) every time it senses movement and can fill a memory card rather quickly in an area where there is traffic.You'll have to check it and delete the card often. They also usually have a molded in loop so you can lock them closed and to something. Set it a little ways away from your boat and camouflage it with whatever is around. the thief probably won't even see it unless it's near what he's stealing.
That's what I was thinking.... it will be at the masthead which is behind the boat and might not be where someone would look...
Might paint it silver to match the mast.. Hiding in plain sight type of thing...
Would have to fashion some sort of bracket to mount it where the windex goes (which I remove for trailering anyway)... shouldn't be difficult.
How did you catch your junkies? Were the photos good enough for the police to recognize faces?
I think the $50 Tesco one is 3MP resolution...
I was debating moving, but the agreements with the other storage facilities all read the same
no responsibility, blah, blah, blah
They also clearly state
Video surveillance cameras NOT monitored
. I don't know exactly what that means other than they're either too lazy to actually keep data, or those cameras are fake.
And moving to another facility would cost an additional $125/month. yeeowch.
So, while I search my ideal solution (out-of-sight storage, preferably under cover) a boat cover may be the next best option.
Sat it in the locked room , amongst the tools. Very good video. Someone on the job recognized the guy from them. He then had the gall to come up to us watching the video with the cops, and tell us he ran some thieves off. best part is he was still wearing the exact same clothes as in the video. Police can't use the vid to arrest ( go figure) but used it to get a search warrant which led to the arrest.
At the mast head it very well may be triggered by the wind.
very nice. It's good that you caught that knuckle head. I know a guy that runs a sailing gear business (that rhymes with Mike) once had some guys clean out his workshop warehouse tools. There was a security camera system but the resolution was only good enough to get a head count on how many people were involved. The quality wasn't good enough to ID anybody...which would be a major let down.
You could/should ask management what it means, but if I had to guess, it just means that no one is sitting in a booth watching the live camera footage. I'm sure it's recorded, but then you're at their mercy as to how cooperative they'd be if you needed to have the police see the tapes.
You're probably on the right path with the cover. Besides, how long can a tramp last sitting out in FL sun?
Mike
It's an F-24, but yes, the netting would probably only last about 5 years tops sitting in the FL sun..
It is made by that Sunrise company though... looks pretty sturdy.
I'm booking about 5 regattas this coming season (starting September) and if I can cram in a few cruises to the Keys I shouldn't be leaving it sitting for too long at a stretch... But I guess it only takes about 5 minutes to swipe something...
The Tasco 3MP game camera says it's got good resolution to about 25' away (not so much on the IR / Night side), so that might just fit the bill... The building I'm backed up to is metal, so maybe a magnetic mount about 10' up would give me a good field of vision but still close enough to get decent resolution...
..perhaps that
good resolution
is adequate to determine if it's a fox or a deer in the picture?
Here in Fla. you don't have to give fair warning of video. Why would you warn them? Warnings only keep honest people honest. Warnings will only help them defeat the cameras. You do have to warn if your recording audio inside a building.
I had a problem with coward kids throwing rocks through an open garage door in my shop. I installed an 8 camera system with three of them mounted looking out that door from different angles. I mounted them low so I could get straight on images. Didn't take long before I got him on video. Worth every dime to see the 14 year old tough guy handcuffed in the back of a cop car crying.
I would use the game camera. However I would use more than one. At least two and maybe three. One mounted under the boat might give you a look at a their car or a tattoo on their leg. Maybe mount one on the inside of the drop in board looking back at the ****. Maybe you could make some sort of canvas bag to cover the masthead that held a camera so it wasn't easily visible.
that sounds like a good bit of work...
So far, I haven't noticed anything else has been repurposed... but the line hasn't returned either...
I may have to limit my target area (especially the movement activated cameras) since I've got other trailers in the space(s) next to me, so there might be a lot of photos of cars/people wandering about.
So perhaps the magnet mounted single camera for now, to see if (1) people frequent the boat, and (2) to make it obvious I'm keeping track (the boat is big enough they have to climb aboard to mess with stuff for the most part).
And it will take my selfies when I stop by the boat 3x per week. There seems to be another dude who's in his unit almost daily (I think it's being used as his workshop). Maybe I'll buy him a few beers occasionally and ask him to keep an eye out...
I wondered about that myself Ronald... but he's got so much stuff in that unit I can't quite pick out if any of the ropes look like mine (should have spliced eyes in them)...
Two Goldwing motorcycles, some nice woodworking equipment, and some other stuff... If I start seeing winch drums or halyards, it will be time to break out the .45
And a game camera for the ensuing fun they will have and the endless hours of entertainment for you!
- 1,190 Online
