tacking and right of way
Tough! - you're entitled to. He has to keep clear. (assuming - if you slowed deliberately - that he has been given time and opportunity)
If you haven't slowed deliberately, then he just has to cope - it's part of racing.
So if instantaneous on new heading, could the new heading be whenever I snap my battens over?
Under the 'old' (pre-2005) rules that would have been the case - you had to have the sail over on the new side and drawing.
Under the 2005-2008 rules all you have to do is get the boat through head-to-wind and on to the new intended heading.
OMG! Pete, you are kidding right. LMAO
This thread comes from a little run in in tacticat.
I was on SB, he was on PORT, tacked in front of me. Stopped the tack when he was heading onto his course. Obviously he stopped his tack mid way, slowed down. In the game its not the right way to tack, but its doable.
I would have had to alter course in order NOT to hit him. Isnt that a big no no??? If it were real life I would have seriously protested him because of that.
If he gets past head to wind and onto the starboard tack, you now have to avoid him...technically. However, the game will usually penalize the port tacker in that case (just like in real life, you roll the dice by getting into a situation that will involve penalties and/or judges). In a nutshell - the longterm starboard tacker must avoid the guy that just tacked in front of him that is now on starboard - even if it means slowing down (no rule gives right of way to a boat that would hit another boat from astern). This is a dirty translation...but if the longterm starboard tacker can't possibly avoid the port tacker (whether or not the port tacker made it to starboard before hand), the port tacker
tacked too close
and is at fault. If the long-term-starboard tacker could have avoided them by either slowing down or steering up past close-hauled but still hit them, the starboard tacker is at fault (on two rules).
Things get a little tricker within the two boat length circle...If you are in the two length boat circle of the mark, the port tacker can come in and tack in front of a starboard tacker - but MUST be on starboard tack before the other boat has to avoid and MUST not make the starboard tacker go past close hauled to avoid.
I think my confusion lies in the way
tacticat
defines completion of the tack, not the way the rule applies on the water.
Tacticat
has become very aggressive in the last week or so. It now is somewhat less cordial and requires far more precision than just one week ago! I'm amazed! The
heat
has definitely been turned up a notch! <img src=
tacticat
Pete,
I programmed the rules engine. There are many many holes, but, I'm pretty proud of how rights are calculated when one of the boats is tacking. It's literally 'from the book':
- When the boat starts the tack ALL rights are preserved while in the initial tack.
- When the boat reaches the wind direction it loses all rights.
- When the boats reaches the new closehauled angle it gets again the privileges of the new tack. A problem there... the normal tack includes falling off a bit to get speed and go smoothly again to the closehauled angle, from the rules perspective the boat has all rights associated to the tack since it passed first time the closehauled angle.
- If the user decides to stop the normal tack procedure, (rudders centered before he reached the closehauled angle, tacticat ENTER key) he recovers the rights immediatly. I aggree this is not normal, but, what if i decide to finish tack and start in the new angle on a course that is very slow ?(and i know this is understatement). How can you protest?
aestela.
tacticat
Pete,
aestela.
Aestela,
The current Sailing Rules apply the sailing tack (starboard / port) to the boat that is tacking as soon as it passes head to wind. This seems to be a little different than the Tacticat Rules. HOWEVER, I think it makes better sense to have them the way you have designed them for Tacticat - sailors just need to understand how it's applied and all is well (it took me a couple of times).
I've seen ONLY one situation (yesterday) where a penalty was clearly applied incorrectly. Two of us were approaching the gate sailing downwind, I was on port and there was a starboard tacker. I wanted the left mark and gybed about 6 boat lengths away for it and clear of a starboard boat. The starboard boat decided he wanted the right end of the gate and gybed. We collided while we were both under
computer control
nearing the end of our gybes. We had both clearly passed dead down wind and I was on starboard and the other boat now on port - but I was shown in black and penalized because we were both still in a gybing manuever...That's not a big deal but if you see an easy workaround....
I think you have done a stellar job with the programming and modification of the rules and program for the simulator. I agree that the programmed rules are not quite perfect, however, neither is applying the rules in real life...you
roll the dice
when you enter a protest room anyway so, as in real life, I find it simpler to just try and avoid any conflict in the simulator or on the race course. I like to beat 'em with my brain, not my bow.
It's often very very difficult to breach that layline procession of starboard tackers from the port tack. Yesterday I tacked in front of a stbd tacker, was well passed the new heading but still below it recovering from the 'fall off' when I was hit from behind and stopped. The trailing boat simply sailed straight through me, out the other end and continued on???
I happened to be in front of a very good sailor from up north at the time, and I thought I had him but unfortunately, (for me) the fat lady had yet to become vocal and another good result went south. <img src=
If you have stopped your tack midway, like Tikipete did, the other boat would have fouled. Its not the right way of doing it, but using the tacticat rules system you will gain a spot. I usually do this to bots and not to real people.
No problem Pete, I will respect that. I have noticed it as an increased trend in tacticat. People will go out of their way (going off course) to foul you, so you drop one or two spots then you have to do your 360s. I have seen it happen quite often now.
Like Jake said, why not win by intelligence instead of by the bows? I dont get it. I try my darn hardest NOT to foul anyone and avoid to get fouled. Yet I have been fouled on purpose plenty of times.
Its the people who will go out of their way, to get you fouled is what annoys me.
Robi, You shouldn't be annoyed.
Trying to force an opponent foul its a usual tactical move in match racing. When sailing Tacticat you are often playing some kind of match race against the boat close to you.
People also likes to play with the rules. I think it a good thing sailors evaluate who is to be fouled and how. And push somewhat the limits.
I agree that it is dumb to try to win using the holes in tacticat rules engine. I think it doesn't pay, in the end.
The only ONE situation we are discussing here would not be clear at the protest room:
A port boat aproching the layline to A-mark tacks. After passing the eye of the wind and before he reaches the 'standard close-hauled angle' the skipper centers the rudders and trims his boat for closehauled. He is now a starboard boat. He is sailing very very slow.
In the water, if you have to change your course to avoid hitting him you can protest him but, will you win in the protest room????
What you (or rules experts) think?
aestela.
Wouter
Zoom in really tight. I've seen some amazing things in the last couple of days. <img src=
/> Takes practice though! <img src=
[quote
computer control
Jake
Rule 13 applies only while tacking, and is not relevant to gybing situations. The scenario described, which also happened to me a while ago, probably relates to rule 16, keeping clear:
when a right of way boat changes course, she shall give the other boat room to keep clear
. However, since both were changing course together, and in limited control, that definately seems like a scenario deemed for stormy jury deliberations, and therefore one to avoid (my personal lesson learned)
I love the way tacticat has improved my understanding of the rules, and think that using the rules well is part of the benefits from Tacticat. What does annoy me are the rare occasions where people misuse the loopholes in Tacticat, such as rules 17 and 18
Misusing the holes require a good understanding of Tacticat and the sailing book. I assume tha people gets tacticat knowledge by playing BUT I've learnt that most sailors have very little understanding of the sailing book when things go a bit complicated.
A token: (only_my_opinion_ON) there it is really a minority of sailors that know when they can luff a windward boat and when they cannot (although almost everybody thinks they DO know <img src=
/>) (only_my_opinion_OFF).
We'll try to make do with what we have. <img src=
Amando.
Not really Pete, look at the sailor called CAN### (I dont remember the numbers) He has been fouled plenty of times and NOT once have I seen him do a 360. Not very long ago there were a few sailors protesting him. He didnt say a word and never did his 360s. Top sailor, ranked two or three, and has never done a 360.
A few other newbies are jumping on the
I wont do any 360
bandwagon as well. Tacticat 360s work on a honor system, not every sailor does them.
This thread has got me totally confused. People keep referring to the person who has been fouled as having to do the 360. It is supposed to be the person who COMMITS the foul who has to do the 360. The person who has been fouled does not have to do a 360.
So why would CAN### have to do any 360's if he has been fouled several times?
I also get confused when you guys refer to the
starboard tacker
or the
port tacker.
To me, when you use the word
tacker,
it means the person is tacking, but it is not clear from what to what.
Would it not be more clear to say the
port tack boat
and the
starboard tack boat
? And if the person is actually tacking, to clarify that they are tacking
from starboard to port
or
from port to starboard
Terminology differences (and maybe language conflicts in general) make it difficult to talk about rules without being able to use diagrams. At least for me. <img src=
- 2,395 Online
