Think you had a bad day?
24 Users
36.2 K Views
(@calebtar)
1990 H-17, H-14 National Championship at The Gorge. Winds over 50 MPH at the weather mark. You had to be there to believe it.
Posted : September 22, 2013 10:46 pm
Arjan13
(@arjan13)
See this video of guys who keep the spi up in strong wind. http://www.youtube.com/watch?v=i128Pk8vFbE If I see it right they let the spi totally go when the boat comes up, and the helmsman sets the traveler way out together with the S turn. As I'm not that experienced in strong wind combind with a spi, I was wondering if this is the way to do this?
Posted : September 23, 2013 3:13 pm
Jake Kohl
(@jake)
That's about 12-14knots of breeze. Look at the flag on the committee boat:
I suspect that those guys are trying to lay the finish line but there are other things they could do to depower the boat and not flog the kite. You want to avoid flogging the kite if possible. The skipper should be bearing away and changing the wind angle as the boat heals but if they are trying to sail a higher line for some reason, this could explain why they keep it pointed in the same direction. In that kind of wind (or stronger) you carve the boat constantly to keep the power level consistent without having to constantly make sail adjustments. If they are trying to sail a high line (perhaps they are overstood), easing the main traveler is the first thing to execute, putting in a little downhaul to take a little power out of the main would be next (not a whole lot...you can overstress things here). The skipper should probably also be out on the hull but it's hard to tell what the water conditions were...putting your weight in may help take a little pressure off the bow but it won't help you sail a higher line. His crew should also be trapezing back as far as possible...it looks like he's in front of the rear beam. He should have a foot on the stern to help keep the bows a little drier. Oh! and good lord, get the daggerboards up at least half way. That alone would make these guys have a much easier day by keeping the boat from healing over so fast and often.
Posted : September 23, 2013 3:26 pm
pgp
 pgp
(@pgp48)
I don't think a spinnaker will take a lot of that so I'm sure that will get expensive.
Posted : September 23, 2013 3:33 pm
Jake Kohl
(@jake)
that video reminds me of the time I was crewing on a 29er and we wiped out big because the skipper didn't bear away in a puff. In the resulting carnage, while I was picking myself out of the rigging, he asked me why I didn't
depower the spinnaker
Note to self...1) don't crew for inexperienced skippers on skiffs who think they know what they are doing and 2) these small skiffs do not sail fast enough to be thrown clear.
Posted : September 23, 2013 3:39 pm
Tony_F18
(@Tony_FX1)
There was no strong wind in that video (15kts tops), the 30kt winds started about 20mins after the video ends on that upwind leg.
IMO the helmsman is a bit late when bearing away sometimes (amongst other things), and releases the traveler because of this.
At 6:52 they passed the lighthouse and really should have been double trapping since the next gate was at quite a high angle.
(We went swimming when double trapped on that leg though, bummer since we where the first F18 at that point).
Arjan, you should attend some races sometimes.
The more sailors the better <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
Posted : September 23, 2013 3:48 pm
Arjan13
(@arjan13)
Tony --> agree, we try to do that more often. Starting coming weekend in Tiengemeten if the wind is not too bad...
Posted : September 24, 2013 2:00 am
Arjan13
(@arjan13)
Ok thanks a lot! This confirms a lot of my thoughts. maybe I should watch less video's 🙂
Posted : September 24, 2013 2:04 am
(@bille)
Originally Posted by pgp
I go back to the '70s sailing the H16. That boat came with reefing points for the main but it was thought that doing so would ruin the sail. I can't prove it one way or the other. At the same time, it was quickly discovered that in survival mode, you can just come head to wind and all is well. On the other hand, driving these boats hard when it's blowing like stink is a rush! And if you do a cartwheel across the water it's no big deal 'cause they're easy to right. Over time skills increased and people sailed in unbelievable conditions. So, it just became part of the culture.
I refered to it as machismo which,imo, is not a pejoritive.
I guess the quick answer is you don't reduce sail because you don't have to if you're good enough. If you're not, you get wet, right your boat and life continues. It's just not quite as easy as it used to be.
I think that was a rather Polite way of explaining
your point of view ; and i
Get-It
now !!!
Thanks : Bille
Posted : September 24, 2013 9:06 am
(@Wyatt)
Furl the jib, travel out, and stay away from the strong surf; that seems to be the most dangerous part.
Posted : October 1, 2013 5:14 pm
(@jackflash)
We got caught by a squall in the Great Texas that capsized us. When we tried to right the boat we found ourselves capsizing in the other direction. We opted to sit on the side of the hull while the squall passed overhead.
Posted : October 10, 2013 3:09 pm
Tony_F18
(@Tony_FX1)
I'm sure these guys are not having their best day either:
[Linked Image] [Linked Image] [Linked Image]
http://www.vsail.info/2013/10/10/virbac-paprec-70-has-capsized-off-belle/
[Source] This Thursday 10 October, at 13:00 hours, Jean-Pierre Dick and Roland Jourdain were sailing off Belle Ile on VIRBAC-PAPREC 70, training in 15-20 knots of wind with a view to the Transat Jacques Vabre. The boat overturned suddenly. The crew is safe and sound. The Cross, SNSM (lifeboat association) and technical team have gone to recover the crew and the boat.
Posted : October 10, 2013 3:11 pm
(@Anonymous 38725)
In that top right photo, is that one of the crew being launched from the high side?
That's a long way to fall! I hope he hit the water and not the mast!
Posted : October 10, 2013 3:18 pm
(@rehmbo)
Looks like a flag to me. Easier to see if you right-click on the pic and open in a new tab or window.
But in the first pic, rudders don't appear to be pointing the right direction. Shouldn't she be heading down? Water spray kinda looks like she's on a beam reach at that point.
Hard to say - easy to armchair quarterback...
Posted : October 10, 2013 4:21 pm
mmiller
(@mmiller)
That's a flag. Three guys are in the center hull ****.
Video of the capsize
You can see one of the guys get ejected. The aft frame ALMOST comes down on him. Yikes! The other two pop out of a hatch under the hull after it flattens.
Posted : October 10, 2013 4:51 pm
Todd A. Hart
(@team_cat_fever)
Originally Posted by mmiller
That's a flag. Three guys are in the center hull *.
Damn! Looks like the driver kind of bounces into then out of the *.
Posted : October 10, 2013 5:44 pm
Tony_F18
(@Tony_FX1)
This s the 2nd time one of the MOD72's has capsized in recently.
In the video there is a hydraulic cylinder under the boom, maybe those thing are too slow for sheeting out quickly in an emergency.
Posted : October 10, 2013 6:02 pm
(@bille)
Ok-- so please don't laugh ; NAH -- go ahead, it's cool.
I told Ya all that i'm a Mono-huller.
I got Numerous Hours on a land-sailor ; more than 1/2
in 25-30mph winds.
When the windward wheel comes up to a height where something
NEEDS to be done , like right now, i would turn the
land-boat down-wind and sheet Out.
If i JUST turn down-wind a few degrees, the windward wheel
will immediately go lower, but it won't Stay there unless
i sheet-OUT.
So when your windward hull raises to high, do Ya come off
the wind to lower it then sheet out ?
Bille
Posted : October 10, 2013 7:30 pm
Todd A. Hart
(@team_cat_fever)
If your below a beam reach, yes. If somewhere near a beam reach (death zone) it becomes more a
which way feels like it will hurt less
kind of deal. The wave action can play into that scenario also.Sometimes it's sheet out AND dump traveler and sometimes it's just time to get wet.
Posted : October 10, 2013 7:56 pm
Jake Kohl
(@jake)
They seemed to be reaching a bit but had the sails sheeted pretty hard on. I would think that heading up into the wind sharply would have been the thing to do there (easy to second guess from a helicopter view, though). It doesn't seem like he tried to steer much at all through the event.
Posted : October 10, 2013 9:50 pm
(@Anonymous 38725)
I was amazed how far they went before they finally tipped over! Looked like they were going fast and then got a big puff, but didn't worry too much about it.
Looked like they were sailing on the side of the low hull for a long time and the didn't try to fix it. It didn't look like he was trying to go up or down to save it, just straight ahead.
Maybe they are so used to sailing it that far up on the edge they were thinking the puff would pass and it would come back down to normal?
Posted : October 10, 2013 10:13 pm
Rob Vaden
(@redtwin)
It looks like the main trimmer tried to release the main as they were heading over but it never eases.
Maybe someone was sitting on the main sheet... <img src="<>/shocked.gif" alt="shocked" title="shocked" height="15" width="15" />
Posted : October 10, 2013 10:39 pm
(@stank)
One Star Admiral Registered
Yeah, that's my job...
Posted : October 11, 2013 10:43 am
(@rehmbo)
I'm liking the lazy-boy recliner the helm is using. Hmm... wonder if I can get one of those on my boat.
Interesting linkage to the rudder. Never saw them move until the very end. Didn't see the boom move much either. Very strange...
When Spindrift went over this past summer, I think I read they use some kind of hydraulic sheet control that doesn't react very quickly in emergency.
Posted : October 11, 2013 11:05 am
(@bacho)
I've read they have some sorta big red button near the helm that blows the main in a hurry in emergency. It appears that button doesn't work as well as it should.
Posted : October 11, 2013 11:32 am
(@pm)
How do you think these guys felt?
Posted : October 11, 2013 11:49 am
Jake Kohl
(@jake)
Part of me wondered if they didn't do that on purpose looking at the lack of reactions to that puff...but there's no way those guys would have taken such a bad fall if that were the case. Just watch the skipper closely. As he finally bails out of his lazy boy he takes what looks like a heck of a fall and I couldn't find him again.
Posted : October 11, 2013 1:00 pm
Todd A. Hart
(@team_cat_fever)
The perils of helicopters filming you.
Posted : October 11, 2013 1:14 pm
(@bille)
The question was :
high, do Ya come off the wind to lower it then sheet out ?
which way feels like it will hurt less" kind of deal. The wave action can play into that scenario also.Sometimes it's sheet out AND dump traveler and sometimes it's just time to get wet.
Thanks for that !!
I've never used the tiller to correct the windward hull's
height yet ; always controlled with the sheeting so far, with
the heading remaining constant.
This info will help !!
Bille
Posted : October 11, 2013 1:52 pm
Page 2 / 2
