Tornado Jib sheeting points
What kind of boat and what year was it rigged. Are you using a wire system or loops in your tramp? I recommend reinforcing your tramp and going to loops. Its fairly cheap and your crew will love you for it.
I can send pictures of the loop system. I also have a Marstrom wire system I can try and describe
Hey Carl,
I'm thinking about doing the same thing. If you could send me a picture as well, that would be great. I sliced my foot open the other day on the wire block and have decided that's it on my boat. I'm thinking of just taking it to a sailmaker and having nylon strapping sewn to the tramp for reinforcement and then just lacing the tramp through the jib wire holes in the hulls.
By the way, what kind of mast rotation setup are you using??
Todd Berget
We had the same setup on our two Marstrom boats - now running a self tacker - I have the measurements somewhere (based on Mitch Booth and Bundock/Forbes boats) will dig them out.
You need to be very careful with the eyelets and reinforcing as there is a heap of tension on the eyelets. If you are running a boltrope track on the side of tramp (e.g. Reg White boat), then you have to spread the load so it doesn't rip the boltrope out.
The first tramp sheeting system I used was on a NACRA, which has a boltrope tramp. The trick is to attach the ends of the lines to the original jib attach points, the jib traveler cars.
You can also replace the boltrope with slugs which do not pull out or put slugs in the channel and use a Marstrom style tramp.
The slugs in the channel may be the strongest, fastest to install, most repairable tramp made.
The rotation inducer is part of the mast base. There is an arm on each side of the base connected to the opposite side of the from cross beam via a 3:1.
The neatest part of the system is the outhaul is connected to the rotation limiter. Blow the outhaul and you blow the rotation limiter. When you pull the outhaul back out, you reset the the rotation to it's previous position. When you have to pinch, ease the outhaul/rotator and it really powers up.
- 719 Online
