Trailex trailer for Wave and H16
14 Users
16.9 K Views
(@aspariguy)
[#17921]
Hi I currently sail a Wave but will be sailing a Hobie 16 soon. I want to get a trailer that I can use to transport my Wave now, but one that can also carry a H16 when I eventually get one.
Does anyone have the Trailex TX-416-HC? I hear this works great for the H16, but can it be used to carry a Wave too?
On the website photo I see the grooves on the side that carry the hulls of a H16. Can these grooves be moved in to accomodate the 7-foot beam of the Wave?
thanks!
-Will
P.S. here's the link to a picture of the TX-416-HC from Trailex's site... http://www.trailex.com/photos/full/tx-416hc.gif
Posted : June 26, 2006 11:25 pm
(@Anonymous 12203)
I'm not 100% on this but I think Trailex bolts their trailers together. So the cradles for the hulls are mounted using u-bolts and/or bolts through the crosspieces.
Email trailex and find out for sure.
Posted : June 27, 2006 7:02 am
(@mbounds)
Trailex trailers are like Tinkertoys - with a 9/16
wrench, you could reduce it to a pile of extrusions and bolts within 20 minutes.
They are infinitely adjustable - the bolts don't go through the extrusions - they have
T" shaped heads that lock into slots in the extrusions.
Great trailers.
Posted : June 27, 2006 7:36 am
bvining
(@bvining)
Get a trailex and you can put anything on it.
I have a trailex and move the cradles for my HT and then move oneside in 4 inches for my A cat. Easy as pie. The bolts slide in the extrusions and can be adjusted to anyspot along the extrusion.
Best trailers on the market.
Bill
Posted : June 27, 2006 7:47 am
(@edgarapoe)
I have intended to write an article about trailers. The crux of it all is simply make a flatbed trailer.
I have several trailers, mostly Trailex. I started off with a Hobie 18, Nacra 5.5, Mystere, 6.0, Nacra 6.0, Taipan 4.9, Taipan 5.7 and now a Wave (3 of them, actually)
I was constantly having to adjust padding, rollers or whatever.
Finally, it came to me. I stripped all that stuff off the trailer, bolted on two 3/4" Marine Plywood 4x8 pieces to make an 8x8 flat bed.
Went to the local carpet store trash container and pulled out some really cushy stuff and padded the trailer.
Voila! (a little french lingo there) a trailer that can handle any boat any time.
I can also load 4 Waves on my biggest Trailex which was designed to handle 2 20' cats with a total weight of close to 1000 lbs.
Another use of this idea.., just build some framing for siding and you can haul all kinds of stuff while you are not hauling a boat.
Rick
Posted : June 27, 2006 8:23 am
hobie1616
(@hobie1616)
Quote
Be aware that the axle is not designed for a lot of weight. If you carry a lot of heavy loads above the axle's weight rating you may be passed by one of your wheels while crusing down the road.
Posted : June 27, 2006 11:52 am
(@Anonymous 13277)
Either:
1. Order a Trailex for a Hobie 16. Then you can shrink it down for the Wave. Trailex is great but be careful what you ask them for. If you mention the Wave you might get a trailer where you have to buy more pieces or longer pieces to make it fit a Hobie 16.
2. Buy an 8.5' wide aluminum snow-mobile trailer.
Posted : June 27, 2006 6:54 pm
(@aspariguy)
hmm a snow mobile trailer... i bet i can find a few of those in florida. haha yeah i guess i'll go with choice # 1.
Rick - here's my concern with a flatbed trailer. With just a piece of carpeted plywood, what prevents a 16 foot cat from inching its way off while i'm howling down the highway at 65 mph? it doesn't seem very secure, but i've never tried it. how do you get the Waves to stay still and sturdy?
and that brings me to another trailering question - how fast can you drive with a trailer? is 65 the max? I've never driven with one on so this will be new for me. any other trailer-driving tips are appreciated.
it's good to hear about the flexibility of the trailex though. I emailed them yesterday (monday night) with the question and specified the TX-416, so they shouldn't get confused. Man these things are pricey... if I get one it'll be worth more than the boat its carrying! ha.. wow. i guess its worth it though.
thanks again for the response.
Posted : June 28, 2006 12:01 am
(@edgarapoe)
With the flatbed, just as any other trailer, you have to tie the boat down. I use those ratchet type tie down and criss cross from starboard beam to port frame of trailer, and vice versa, front and back.
I am usually pulling them with my diesel RV. While I can go about 85 with it, I usually travel at 60. Otherwise, the boats get covered with diesel soot and my mileage drops drastically. At slower speeds I get over 10 mpg.
With the car, I pull the trailex at whatever speed limits are + 5 mph. No problems yet.
Rick
Posted : June 28, 2006 6:55 am
Jake Kohl
(@jake)
You don't have to get an aluminum trailer - a galvanized trailer will be about 1/2 the cost. I'm sure there are dealers around you but you might try www.Sailmax.biz to look at that option.
Posted : June 28, 2006 7:04 am
PTP
 PTP
(@CaptainPP)
It can't be good to have the hulls of a 6.0 or f18 on a flat surface trailering though, right?
Posted : June 28, 2006 9:05 am
(@Anonymous 4388)
So, butting in on another thread with another newbie question:
I have an EZloader galvanized trailer which I just got with my boat. I'm pulling it with a Ford Ranger.
The question I've got is this: bringing the boat home, I was doing only about 60-65mph on turnpike/interstate, but up around 65 the wind effects boat appeared to become noticeable, I expect this to get worse at higher speeds. I had some concerns about trailering with the tramp installed, believing it might provide some wing/sail effect making the trailer even more squirrely back there. What says the collective? Should I never go these speeds, tramp or no tramp?
Posted : June 28, 2006 9:28 am
(@terryback)
Just came back from Daytona (I-4) doing about 75-80 mph. I was admiring how the boat/trailer really could handle the speeds.
I think the tramp' DOES provide some sail (lifting) ... In fact I don't think my tires even saw the pavement over 70 mph <img src=
Now if I could only keep the
pointy
side up on the water like on the trailer ........
Posted : June 28, 2006 9:33 am
MaryAWells
(@maryawells)
There are all sorts of ways you could cushion the hulls, or you could use cradles. Be creative.
Posted : June 28, 2006 9:34 am
PTP
 PTP
(@CaptainPP)
Quote
have you checked the tongue weight?
Posted : June 28, 2006 9:38 am
(@Anonymous 4388)
Quote
Heh...yeah, I'm more likely to stick to ~72...the troopers around here in the mid atlantic are a little tougher on that. I know your stretch of I-4 though, so I'm not surprised...
Quote
You know, I haven't really. The tongue weight is actually quite low, because I can lift the tongue move the trailer, with the boat on it, by myself without much trouble. I expect the tongue weight is about 50lbs, perhaps a little more. I think of squirelly behavior when there is too much weight, but I guess too light would do that too.
This trailer used to have a platform screwed to it - looks like some old OSB - that rotted out and was just yanked off. I was thinking of replacing that with marine grade 3/4" ply and putting astroturf on it. I need to build a sail box anyway, so I can put that up front to increase the tongue weight. Thanks for the tip!
Posted : June 28, 2006 10:28 am
PTP
 PTP
(@CaptainPP)
Too little tongue weight can certainly make the trailer fishtail a little. As far as I have learned- about 7-10% of the trailer weight should be on the tongue. I experimented with mine and eventually figured it out.
Posted : June 28, 2006 10:42 am
MaryAWells
(@maryawells)
There is another thread about trailering and tongue weight here: http://www.catsailor.com/forums/showflat...&PHPSESSID=
Posted : June 28, 2006 10:47 am
(@Anonymous 4388)
Thanks for the pointer to the thread!
Posted : June 28, 2006 11:22 am
(@Anonymous 9184)
Rick has an interesting idea with a carpeted flat bed trailer. Why would this arrangement create more damage to the bottom of the hulls than that with cradles or rollers? On a flat bed trailer the boat weight is evenly distibuted over a larger area as opposed to cradles or rollers.
In the near future I will upgrade my galvanized trailer to cradles or possibly to another configuration. I was considering purchasing recycled plastic decking boards (2'x8' if available) and bolting them to the trailer crossbeams so that the boards run under the hulls length wise. The boards could be covered with marine carpet. I could even make a lip an the outer part of the boards to limit side movement. Any comments?
Posted : June 28, 2006 3:02 pm
Jake Kohl
(@jake)
If your boat has a considerable amount of rocker (most of them do) then only one small area of the curved bottom of the boat will contact the flat board. It works well for the Wave because of the skeg keel.
Posted : June 28, 2006 3:04 pm
MaryAWells
(@maryawells)
Like I said, with a flatbed, you have to be creative in how you cradle, support, or cushion your hulls. Lots of possibilities.
And, who knows, if you have a hull with a lot of rocker and you flatten it out in transit, maybe it will go faster on the water. <img src=
But is that legal? <img src=
Posted : June 28, 2006 4:05 pm
(@Anonymous 37790)
My husband says my StreetPilot clocked me doing 98 while towing our I-20.
Posted : June 28, 2006 6:59 pm
(@Anonymous 335)
Fiberglass boats do not like to sit on wet carpet on flat trailers. The gel coat will blister on the bottom.
Posted : June 28, 2006 9:22 pm
(@aspariguy)
Jake, what exactly would I be loosing if I got a galvanized instead of an aluminum? I know aluminum is lighter and won't rust, but is this all? Can the galvanized trailer be painted or cured with something to safeguard it from rust? How severe is the rust anyway?
I'm getting a Hobie 16 really soon, within the next month I hope, and I'll be getting whatever trailer comes with that. Should I just use the trailer it comes with? <img src=
/> I'm just wondering if it's worth it to get another trailer.
This, of course, leaves out the unprobable possibility that a H16 actually does come with a trailex! that would be nice... <img src=
Posted : June 28, 2006 9:35 pm
Jake Kohl
(@jake)
A galvanized trailer is usually dipped and coated with a layer of zinc (the whole thing!). The zinc provides really good rust protection (better, usually, than paint). It will be a good bit heavier than an aluminum trailer and you'll really notice the biggest difference while moving it around by hand with a boat on it. You might notice some increased efficiency while towing with the aluminum trailer, but my experience has been that the mileage difference is pretty tiny.
Are you buying a new boat? They should be able to tell you what trailer it comes with - often, however, trailers are optional items.
Posted : June 28, 2006 9:43 pm
hobie1616
(@hobie1616)
If you can keep the trailer out of the water then rust becomes a non-issue. If you launch at a ramp, back up just enough to get the boat into and out of the water but keep the trailer dry. I did that for eleven years with my last boat/trailer and never saw any rust. H16s are fairly light so, at the worst, you use a winch to haul them back onto the trailer.
Posted : June 28, 2006 10:54 pm
(@aspariguy)
Just an idea, but why don't they dip and coat galvanized trailers in aluminum? or is zinc more rust resistant than aluminum? looking at my periodic table i see how zinc would work, but aluminum is tough to rust too. Just a thought
OK well when I go to launch my future H16, it'll be my first time launching a boat from a ramp. Will I need cat trax or some sort of wheels to get the cat from the trailer safely into the water?
I know the H16 is pretty light, but is it light enough so that I could load it off and on the trailer alone if I go sailing solo?
A winch is a good idea... I'll look into that.
Posted : June 29, 2006 12:36 am
Jake Kohl
(@jake)
I don't believe the aluminum would bond well with steel...another benefit of the zinc is that it acts as an anode and protects the steel electrically from galvanic corosion. (hence
galvanized
). You can read more about it here: Wikipedia - galvanized
Posted : June 29, 2006 6:02 am
bullswan
(@bullswan)
I have 4 trailers.
Two Galvanized Steel, One Steel (painted), one aluminum (2 position snowmobile). My boats are on Glavanized trailers and neither has rusted although admittedly I only put them into fresh water. The Aluminum Trailer is the greatest. Light and VERY versatile as Rick pointed out. In addition to towing two snowmobiles with it and towing around a Hobie 16 I had for a while, I use it almost every weekend for something...... getting mulch, or bringing brush to the recyling center etc. etc. It's great for carrying odd size things like mattresses too.
A friend had a steel trailer sprayed with the bedliner stuff from LINE-EX. That is one great system and completely impervious to weather I think. I will watch and see how he likes it and report back at some point.
Posted : June 29, 2006 9:02 am
Page 1 / 2
