Trio fails to right 18; drift all night
20 Users
16.1 K Views
(@samevans)
There are basically two types of shroud extender (righting) systems.
The bigger boats, or boats with very tight shrouds, usually use Hyfield Levers in place of, sometimes in addition to, the normal shroud adjusters.
Smaller boats or boats with loose rigs can often get by with a simple cable shroud extender.
In order to use either system, the crew must be able to reach the shroud attachment and pull a pin.
This may involve climbing on the elevated hull or installing an access hole in the tramp.
Pictures and diagrams of these and other righting systems can be found in the Hobiecat catalog on page 18.
Or http://www.hobiecat.com/support/pdfs/18_19.pdf
Posted : June 11, 2003 5:24 pm
(@_removed-account)
Four Star Admiral Registered
Hello Maugan17,
You have not seen the SC mast base and pin. With the pin in place the mast base can act as a hinge for raising and lowering the mast. When the mast is vertical, it is free to rotate with the pin still in place. The SC mast base and pin act like a universal joint, free to flex, rotate, swivel in any direction, but at the same time it will not allow the mast base to come off the ball. It is slick trick, 1978 technology!
Bill
Bill
Posted : June 11, 2003 5:46 pm
(@_removed-account)
Cookie Monster,
I've got another trick for righting the RC30 and it does not require shroud levers. I'll tell you about it sometime.
By the way, those shroud levers on your boat are a go fast device also. In very light winds and going downwind usually the mast rotation is limited by a tight leward shroud. The leeward side of the mast runs into the leeward shroud and this limits you to about half as much mast rotation as you would like to have. Open the leeward shroud lever and the leeward shroud goes slack and the mast cranks right on around parallel to the beam or even more. Now the mainsail and mast take on a much more desireable airfoil shape and you can actually feel the boat accelerate in light winds. Tighten the leeward shroud before jibing.
Bill
Posted : June 11, 2003 6:03 pm
Cookie Monster
(@cookie-monster)
Bill,
Thanks for the advice. We'll certainly give it a try. By the way, we're having a ball with the ARC22. Hope to see you in Ft. Walton for 'Round the Island in September.
Don
Posted : June 11, 2003 6:26 pm
 danb
(@danb)
so this dude stayed all night with a couple of hot babes and they had to cuddle to stay warm and uh who had a problem here except the media got involved and rescue folks who had better things to do.... maybe they shoulda had a little less conspicuous plan...
Posted : June 11, 2003 7:58 pm
(@mauganh17)
broberts: my H17 mast base provides the same functionality.
What I'm saying is that if I'm on the water and my mast for some reason comes down, I DON'T want it staying on the ball, because it would only cause more damage if it remained attached. This is why I pull the pin out so its free to come off (if the shrouds didn't keep it down)
Posted : June 11, 2003 11:38 pm
MaryAWells
(@maryawells)
Quote
...except the media got involved...
That was kind of hard to avoid, since the people involved ARE the media.
Posted : June 12, 2003 6:52 am
(@kbcatman)
First off, it really annoys me that these numbskulls got 15 minutes of fame from this. Just another "catamarans are dangerous" story to add to the public's view of the boats. For this reason alone these people should be smacked hard on the head.
Second - if the shroud extender requires the mast to be pinned to keep it from falling off the step, you can't use it on the 18. The 18 has a really stupid design to the mast base - there's a "hinge plate" on the bottom of the mast that hinges/swings from the mast. The pin locks the plate to the mast step on the boat - with the pin in place the mast can't rotate. Even if you did leave it in, the mast could still "hinge" away and break the plate, putting you in the same situation of not having the pin in, except with broken parts.
!! rant mode on !! Afterthought to #2 point - why the hell hasn't Hobie gotten rid of this stupid design? It's the only boat in their lineup that has it. Are they so locked into one design they can't fix something like this? How dumb. It would seem they could easily make it consistent with one of the other boats, retire the need to have unique parts, and save money/cut costs. They could sell a retrofit kit and make more money. I'd buy one in a minute for my 18. !! rant mode off !!
Posted : June 12, 2003 8:53 am
Jake Kohl
(@jake)
The H16, while it's a little different, is pretty much the same concept. I kind of like the TheMightyHobie18 system - you don't have to rotate the mast to step it. I don't want to sail with the pin in anyway (lest you become the nut in a nut cracker should you suffer a dismasting).
Posted : June 12, 2003 10:07 am
(@kbcatman)
One slip raising the mast letting it go to one side inadvertantly or having something catch on something and you'll break the plate. You might not like it so much at that point... Once you do that you learn to keep a spare in your tool box. I've broken one raising the mast, and I've had one shatter/break into pieces while sailing which was interesting...
I very much prefer the system on my 20 in contrast, even though the mast needs to be rotated.
Posted : June 12, 2003 10:35 am
(@mauganh17)
The 17 mast base fits into the 18's mast yaknow.
Posted : June 12, 2003 10:51 am
(@kbcatman)
'zactly my point about why it shouldn't be the way it is anymore...
Posted : June 12, 2003 10:57 am
(@samevans)
It is disappointing that Hobie Corp has quickly jumped in and changed the Dragoon mast step fron the antiquated Hobie 16 style to the modern ball step, while they have made no effort to FIX the US 16 & 18.
They could have/should have changed the US 16 and 18 many years ago.
The Dragoon had to have it in order to achive official youth boat status and increase sales in Europe.
Money talks and Hobie Corp listens.
It is sad that the main premise of capitalism, competition improves products, is working more in Europe than in the US.
Posted : June 16, 2003 11:40 am
Page 2 / 2
