Ultra Ever Dry? Effect on foils?
Just saw that recently. Looks interesting, although I'd be curious how you would get it off of something...
The water behaves similar to a highly waxed or oiled surface, so I would suspect that it might be worth trying on a hull. Not sure about a foil (for fear of increased cavitation)?
Interesting uses for the stuff.., say sunglasses while sailing to keep from spotting. Gloves and spray suit to keep dry.
Since it started water beading immediately, from what I have heard, it may not be good for a hull. One theory is you don't want the water to bead.
Rick
great point, although I wonder if both surfaces (sail and telltale) are coated, would the water bead up between the two and hold it together similar to what it does untreated?
Came across this article which talks about a potential performance gain of 8%, but by the looks of it not worth the hassle! (good read though)
http:/
I think it could be useful to treat the tramp and snufferbag, also because it has UV protection built in.
Might even be useful to spray the inside of the hulls with as well <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
Rustoleum bought the rights to the stuff.
Interesting, I may pick a pack up to experiment with.
Air doesn't
cause
cavitation.
Cavitation results when the local pressure on the foil surface gets below the water vapor pressure and bubbles of water vapor form and explosively collapse - which is a real problem on propellers (the force can erode stainless steel). On catamaran foils - not so much, if ever.
What most people think of as
cavitation
is actually ventilation - the local foil pressure drops below the surface air pressure and draws air down from the free surface. And since air is 1000 times less dense than water, the foil loses it's lift.
A hydrophobic coating is probably going to promote the ventilation process, since the surface tension will create a natural crevice for the air to bleed down the foil. Wetting agents would have the opposite effect.
- 1,737 Online
