Wheels for beach wheels
25 Users
60.9 K Views
(@dogboy)
[#28907]
Just wondering if anyone has any sources/suggestions for wheels/tires that work well for beach wheels. They need to be able to support a minimum of 200lb each and work on sand.
I'd like to make my own set because I can't stomach the idea of spending close to $500 for a new set of cat trax or $130 each for just the wheels. There's a motorcycle shop near me that has a used pair of ATV wheels for $70 total which I'll probably go look at, but ATV wheels would require that I make some type of hub to bolt up to the 4-bolt wheel pattern.
Posted : March 21, 2012 11:46 am
(@sail7seas)
Try shopping for 'wheeleze' maybe you can find a better price? maybe not.
http://www.wheeleez.com/beach-wheels-polyurethane.php
Posted : March 21, 2012 11:58 am
(@dogboy)
At $137 per wheel, the wheelez aren't any improvement. I actually have a set of wheels that use the wheelez and I'm not overly happy with them. They don't work well with my boat.
Anyway, I'm looking to make a cheap set of wheels that I can keep by my beach boat and don't have to worry about them getting legs.
Posted : March 21, 2012 12:40 pm
 samc
(@samc)
I've been down this road a number of times. Never quite got to building my own wheels, mostly because you can't find suitable tires for less than $130 each. I just forked over my >$500 for a new set of Cat Trax, simply because they are the only wheels I've used that work well each and every time, no matter the surface. Other beach wheels don't roll easily on soft sand, weigh more, and are easier to puncture.
Your problem however is one that I sympathize with. My boats live on the beach during the summer, which is a 5 minute walk from my house. In general, I'm not worried about stuff getting stolen, but it has happened, and given the current economy is more likely than in prevalent times. I've also had a set of beach wheels stolen or trashed at a different location (not a beach or waterfront for that matter). I doubt these new wheels will be spending time overnight on my beach. So I am relegated to carrying them back and forth, or moving them on the trailer, all of which is a huge pain I'd rather not deal with. The other solution is to lock them up, which I might do on a weekend. As to solving the alternative problem, PVC pipes work pretty well as surfaces to slide the boat on and are very inexpensive compared with wheels.
Posted : March 21, 2012 1:14 pm
(@Anonymous 39549)
Look around the local lawn mower repair shops. Maybe you can find a trashed lawn tractor.
Posted : March 21, 2012 1:18 pm
(@david.ingram)
I have a trashed lawn mower you can have, but have to take the whole thing.
Posted : March 21, 2012 1:29 pm
(@brucat)
Where are you located? You can sometimes find used Cat Trax.
I might even have a spare set... <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
Mike
Posted : March 21, 2012 1:58 pm
(@dogboy)
New Jersey.
I have not had any luck finding any used sets for less than about $250. I think I could probably make a decent pair that's good enough to drag my boat 50 yards across the sand for about 1/2 that price.
Right now I have to cart my current wheels with me to the beach each time I sail and it's a pain (especially because they don't work that well to begin with).
Posted : March 21, 2012 2:04 pm
(@Anonymous 335)
I tried making a set out of ATV tires and rims and they worked OK, but always had problems. That was for my first boat when I was 24 and did not have much money. In the end I would have been better off buying a used or new set with the amount I had in the set I made it was not that much more to buy some Cat Trax.
I did buy some Cat Trax in 1996 which I still use today.
Posted : March 21, 2012 2:10 pm
(@dogboy)
What was the problem with the ATV tires?
Posted : March 21, 2012 2:11 pm
(@Anonymous 13274)
Spend the money. They're essential, work reliably, and like Dave you'll find they last for years. Support a small sailing business.
Posted : March 21, 2012 2:13 pm
 samc
(@samc)
I'm pretty sure a pair of cat trax will easily last 10 years, that's less than $60/year, which is a pretty good way to justify the purchase.
Posted : March 21, 2012 2:34 pm
(@brucat)
I have one set that has lasted since 1997. I did have to replace the tires once, but that was well worth the investment. In hindsight, I'm sure that I probably could have gotten away with just tubes, but my dealer had a spare set of tires at a fire-sale price.
I have yet to see a set of home-mades that work as well as the Cat Trax or Roleez. Most of them wind up to be extremely heavy, and/or dig into the sand too much.
$250 for a used set is about as cheap as you will ever find them, and worth every penny in the long run.
Mike
Posted : March 21, 2012 2:37 pm
(@Anonymous 39549)
I vaguely remember paying $300 for my Tiger Tracks in 1985. They need new end caps, but stil work.
(@Anonymous 335)
There was not a problem with the tires or the aluminum rims it was making a hub and bearing that worked good. Getting all the parts that fit together and last in salt water is the biggest problem.
Posted : March 21, 2012 2:39 pm
(@beachsailor)
Find a place that services golf carts. They will give you the worn tires and rims for free. Since you don't need or want the tread(extra weight) these work great. I used to use a PVC drain fitting that I could bolt to the rims and was greased to slide on a aluminum pipe. You can make cradles but turning the boat over and using the hull for a mold. But trax will always work better and ater I had used a set of homemade for a couple of years I just broke down a bought a good set. They lasted 14 years( money well spent). Check craigs list and some of the sites and you might be able to pick up a set cheaper.
Posted : March 21, 2012 2:43 pm
(@terryback)
I had mine stolen while being stored (I now lock them to the trailer)...I made my catrax .... you'll need to purchase the wheels and rims from the outfit in Ft. Lauderdale that makes the catrax and also purchase the cradles (alternate source). Beyond that the other parts can be purchased. You'll save a hundred bucks or so ... so in the end probably not worth doing yourself.
Posted : March 21, 2012 8:43 pm
 Karl
(@sogncab)
Yep.
Cat-Trax are a one time purchase assuming they don't get stolen, fall off the trailer, or die in a drunken rage. I refuse to sell a boat with beach wheels anymore, just because they cost too frickin much, and the next boat needs em' anyway.
Posted : March 21, 2012 9:10 pm
(@mbounds)
I had a set that went from 1984 to 2004 with virtually no repairs. I lost an end cap (Daytona, 1995) and one of the inflation points leaked. I fixed it by shoving a plugged inflation needle into it. I sold them in 2004 for $150 and got one of the
EuroTrax
for my Tiger. What a POS those were. They got sold with the boat in 2008, and I'm back to owning another set of CatTrax. I'll probably die before they do.
Posted : March 21, 2012 9:22 pm
(@harrymurphey)
The set of CatTrax that I currently use for my TheMightyHobie18 was purchased in 1986(?). Now they leak a little and need to be re-inflated every month or two .... so I keep a
bicycle
pump in my trailer box. A couple pumps ... and
hi ho a diary-o ... a sailing we shall go
I made my first set of
beach wheels
(for my first Hobie a 3-digit H16!!!) from two
appropriated
1/2 barrel beer kegs ... I should say I ATTEMPTED to .... while being ROUND ... they didn't roll to well on New Jersey sand!!!
To Mr SRM .... you reconize most of the
Forum
members who
posted
in .... and there ain't a novice among them ... if there was a cheaper solution ... they would have found it. But if you do find alternate solution ... let us know ... when it comes to saving $$$'s ... I'm all ears !!!!
Harry
H18Mag/P19MX
Posted : March 21, 2012 9:44 pm
 Karl
(@sogncab)
Originally Posted by HMurphey
A couple pumps ... and "hi ho a diary-o ...
jesus Harry, makin' it too easy.
and get some tubes.
Posted : March 21, 2012 9:55 pm
(@brucat)
If you're really having trouble finding a used set, and if you have the cash, you could always buy a boat that comes with a set, then flip the boat and keep the Cat Trax. This takes cash and cajones (you don't want to get stuck with the boat)...
This works best with a boat like a Hobie Wave, you can usually turn them around very quickly. During the start of sailing season, they don't last on CL for very long.
Mike
Posted : March 21, 2012 11:25 pm
(@_removed-account)
Four Star Admiral Registered
Mike
I think the wave only has a 7' beam so those wheels wont work on most beach cats ... make sure you get wheels that fit your beam.. or you will have to add weight, expense (and a new and exciting way to bleed when you get your hand pinched by the extension).
Posted : March 22, 2012 8:37 am
(@mystere50xl)
OK, speaking of leaky beach wheels and adding inner tubes...
Does the valve stem on a 12x12-8 inner tube exactly match the location of hole on a tubeless wheel? I have those POS EuroTrax and wonder if they used a metric (S.I.) measurement in locating the hole in the wheel. I'd hate to have to figure out where to drill a new hole for USA tubes.
And why should they leak to begin with? Couldn't you just clean and reseat the bead on the tire and wheel, maybe grease it up to help the seal?
Posted : March 22, 2012 9:05 am
(@Anonymous 13274)
If you get Wave Trax or something, just visit your local metal supply joint and pick up a new axle - pretty sure it is 2-inch aluminum tube. I used the Trax Mike Fahle sold me with a Mystere 4.3 for four or five boats, just swapping the axle to fit whatever boat I owned at the time. The Glasers have those Trax, now, and they just put tubes in.
Posted : March 22, 2012 9:38 am
(@Anonymous 37755)
If you have tubeless beach wheels that are leaking or you can't get the tire to seal to the wheel, try adding a sealant made for tubeless mountain bike tires. This has worked for me on various beach and lawnmower tires. Some problems like hard to seal to the rim can be fixed with one application. Other issue will require that up refill the tires with sealant once or twice a year as the sealant dries up or is used up.
Right now my preferred sealant for big tires is Caffélatex. Next is Stan's. I don't use Slime especially on beach wheels because it has ammonia in it and can corrode aluminum wheels.
Trying this will cost you $10-25 depending on product and wheel size but if it works you can get a couple of extra years of life out of a set of wheels. This has extended the life of my original Rolleeze by 5 years.
There are some cases such as a damaged rim and tire bead where nothing short of a tube will work and the damage keeps poking a hole in the tube so you have nothing to lose. In cases like this SLIME makes some heavy SLIME filled tubes that will sometimes work.
Posted : March 22, 2012 10:01 am
(@millcreek)
When it comes to sealing the tire to the wheel, you could try cleaning it real well and taking it by a big tire shop like Tire Kingdom. They have a commercial bead sealer they put on wheels to prevent leaking. They don't use it all the time but just on old ones that won't close up.
Posted : March 22, 2012 10:07 am
(@_removed-account)
Makes sense
Posted : March 22, 2012 10:23 am
 Karl
(@sogncab)
NO!
I've changed a lot of tires, that sh!t is straight up nasty to deal with, and it doesn't really work that well in the first place. It will eventually leak again. And I really don't care if it worked for you, you're an anomaly.
Put a tube in, the tires are soft as hell, and easy to get off of a rim, or go somewhere and pay them $4 to put the tube in. You don't even have to pull the tire off, just break the bead on both sides, get the tube in. I think I broke the bead on mine with my foot.
This isn't a high stress application. Cat-trax have a strange tire size, and its tough to get a tube that is the right size. The tire is a 21x12x8, I think both of mine have a 22x12x8 tube in them. You aren't putting any load on them, and the chance of the tube pinching itself and leaking is pretty low. I threw tubes in close to three years ago, and I don't think I've added air since then.
Posted : March 22, 2012 10:47 am
(@dogboy)
You guys mean to tell me that no one has successfully made a decent pair of beachwheels on their own using ATV tires or something similar? Of couse I could buy a set of Cat trax. My folks have a pair that they've used for close to 20 years. I know they work well, but I also know that it didn't take a rocket engineer to design them. All we're talking about is a pair of wheels, an axle, and a basic hub/bearing assembly.
Throwing a fist full of cash at the problem is a simple and obvious solution, but unfortunately one that isn't available to me right now.
If anyone has any actual input about the original post topic - sourcing parts to build a set of wheels - that would be most helpful.
Posted : March 22, 2012 11:15 am
Page 1 / 2
