Catamaran Speedometer
HAHA, ANALOG~!
I think the proper method is to tie a line to your rear beam and drag your crew behind the boat. They can hold the pole/prop in the water below them much better than you can (their hands are free)
Every time they come up for air (i assume they will get dragged under often) they can yell the current speed reading to you (in-between their gasps for air)
rch701 wrote: I have an old analog speedo that was given to me with my H-18. Imagine a 3/8" aluminum pole with a plastic prop on the end. i tried it once, but the cat goes so fast i could barely hold the darn thing in the water.
MN3 wrote: I think the proper method is to tie a line to your rear beam and drag your crew behind the boat. They can hold the pole/prop in the water below them much better than you can (their hands are free)
I recall seeing a harness for keeping the crew and analog speedo under the tramp, out of the sun. I think there was an optional Playmate cooler rack/snorkle to add to the crew's comfort.
It had a light so it could be read after sundown as well.
- 733 Online
