new Gibbs shark
hello, I just picked up a Gibbs shark folding cat, and can't seem to find info for it, like tips or tricks to folding and unfolding it, etc, and where would a good source of parts be? pics would be great so I can finish her as factory would have.
Mudslinging79, Welcome to TheBeachcats.com. You've got a cool boat there, be sure and post some photos.
You've also got a fairly rare boat so be patient but you'll find help. There used to be a Shark Association website but it's gone away and I haven't found a replacement.
OK, I pretty much figure the cats are a displacement style hull, as I was looking around in a hull preparing to replace hardware, I noticed the floatation foam along the top of the hulls is barely hanging up... how important is this foam really? can it be yanked and forgotten about?
DON'T YANK IT!
Hopefully, for your entire life, the foam does NOTHING, except add a bit of weight. It is there in case of dire emergency.
Lets say you forget the drain plug, or you hit a rock & tear the bottom out. Your hull will flood, completely. BUT, that foam will displace an amount of water equal to its volume. Archimedes principle says that buoyancy equals displaced volume of a liquid. If the foam displaces a volume (apps 10lbs/imp gal) equal to the mass of the boat, it will still float, even though the hull is completely flooded.
I can't remember if the standard was for 100% buoyancy, or double,(200%).
Disclaimer...the standards may have been less at daye of build.
most beachcats are rigged 5:1, 6:1, 7:1 or even 8:1. if there are 2 blocks on the boom, there needs to be a main block single, double or triple near the traveler. Check out the harken website for tips on mainsheet systems
http://www.harken.com/content.aspx?id=3901
HTH
Edited by the-renovator on Sep 14, 2015 - 01:58 AM.
- 2,912 Online
