Prindle swivel cleats?
I have finally come to the realization that my jib is rigged incorrectly.!
After looking at some pics of other Prindle 18's it looks like I'm missing the "swivel cleats", i think.
Mine is rigged like a hobie 16 with cleats on the front crossbar, but that just makes the jib suck. It looks like a cupped hand rather than a flat sail.
My question is is the "swivel cleat" the correct part name that I need instead? I currently have a pulley/shive on each cable that is anchored in the hull by the hull access port.
Swivel cleat is an after market item attached to bottom of the mast (perhaps one on each side) so that downhaul is easily managed even from the trapeze--about $65 each. Your cleats on the front crossbar are your "barber hauler" system. Your 30' jib sheet goes thru jib block attach to cable coming from hatch, thru small pulley of pair attached to clew of sail, back to becket (place to tie off) on jib block. Now take other end of jib sheet & do same thing on other side. When you get comfortable with that, you can buy two 2" rings and 20' of 1/4" line to finish your barber hauler system.
Ahhh!
Now I see why the blocks are on the crossbeam.
I am missing the two jib blocks that attach to the hatch cable. I will call the seller to see if he has them in a box somewhere, but if he doesn't what blocks should I buy?
Thank you guys so much for your help! 😀
- 3,416 Online
