Stepping mast solo on P18
I had the same issue with my P-19 mast procedures. After numerous trips to Lowes, experimentation after experimentation and lot of head scratching I finally came across a brilliant product I found on this website. The dude's name is Jon and his email is joncom@juno.com. He sells a gin pole system that fits just about most beach cats and the beauty is in it's simplicity and ease of use. I opted to purchase just the gin pole assembly and not the rear support since I had already fabricated one from electrical conduit piping. He includes all hardware and easy instructions. After install and using the system now I can't imagine anything simpler and safer. Good luck, I give his product 2 thumbs up!
I have owned a gin pole - was a nice tool but doubled rig time (plus was a bear to set up)
Most of us "locals" solo step our 30 and 31' sticks all the time
the secret is to tow your boat "backwards"
this way when at the beach we simply pin the mast to the ball and the mast yoke is holding the mast with about 5' of space to get under it , put a foot on the back beam and walk it forward.
It does get a little tricky walking the forestay forward to secure it solo but can be done
tnell wrote: If you somehow drop it, there goes your car. But I guess y'all do it this way all the time with no trouble.
you gotta ask your self ... "what's more important: sailing or a car?"
jk 🙂
if my pin snaps (never happened) or my mast base breaks (would still stay put) or a stay breaks ... i would simply push my mast a little to the side and it would miss my car
but you are right... added slight risk (i have car insurance)
I dropped my h18 mast once about 15 years ago ... learned a lot -
you can weld or bolt a 5' bar to your mast yoke and your car would be safe!
And if you look at my top pick, i have a telescoping yoke, that's only 1/2 way up... (makes it a lot easier)
i always get there early - beat most of the people/cars and leave room around my boat
I check, double check and tripple check everything, if someone is around i ask for help if i think i need it
then
to answer your comment above:
I have had a h18 mast hinge break on me, i have seen a supercat 17 ball fail and the mast fall, and i have seen a p16 drop a mast during stepping (and hit my boat) ...
but i have never seen someone hit their car with a mast in this config - but it is possible if your mast ball and pin system fails
Edited by MN3 on Jul 30, 2017 - 03:36 PM.
Years ago I took MN3 advice to put boat on trailer backwards and it is the only way... I did it more for setup time reduction but it does make throwing the mast up and down pretty easy. I think the trick is once you start raising mast stay committed and get it up quick.
For solo I have a block on quick shackle I put in bridle for raising solo, then I attach line to forstay and hold tight as I jump down and connect. Although lately I've just been asking a passer by to hold for stay while I jump down.
I don't know about this business of holding the forestay and jumping down to pin the bridle or just tilting the boat bow down - this all sounds a bit sketchy to me. Anytime I have solo stepped my mast, I've used my main halyard as a temporary forestay. Add an extension piece to the end of the halyard and tie it either to the trailer, the forestay adjuster, or a bow tang. Then hoist the mast up and once it's up, pull all of the slack out of the halyard and cleat it off. Then jump down and pin the forestay to the bridle. It also helps to put a 5-6 foot ladder under the mast tang before raising or lowering the mast so you don't have to reach down so far (this is similar to trailering the boat backwards and using the mast stand as a crutch).
it is - sketchy
we all have spins here, so we use the spin halyard tied to the turnbuckle ring above the furler or to a bow tang, Once the mast is up, just reach down and secure the cleat.
If i didn't have that rigged i would tie an extension to my forestay and reeve it through that same ring
if i had to I could ask anyone standing to simply hold the forestay for me as i step off the tramp
but as long as the mast is straight or preferably down hill a little -it is not hard to walk forward with the forestay in hand and get up front to tie it off - but it is nerve wracking and and the last option - i have done it many times, but glad i have a spin halyard reeved
Attach your main-sheet to the front of your trailer... attach the other end to one of your forward trap lines.. Depending on you mainsheet, you may have to rig a pigtail. I always go with the starboard as the mast is rotated to favor this with the hinge set up. Lift the mast, tighten the main-sheet to hold the mast.. from there you can let go of everything and attach the forstay to the bridle wires... easy peasy... I do this all the time.. with my Prindle 18.
Edited by JohnES on Jul 31, 2017 - 12:02 PM.
Stepping a P18 mast is a pain in the ass. Why they designed it to be side step I do not understand. I have not trailered my P18 for the last 5 years. When I did I carried a 8 foot step ladder. I could not use the trailer mast yoke like MN3 because the mast is pinned on the side and the diamond wire is in the way. I had a measured line I would use to place the stepladder behind the rear crossbar. I would rest the mast just above the diamond wires on the stepladder then go to foot of the mast rotate it 90 degrees and pin the mast hoping the other end did not slide off the stepladder (it came close a few times). Once rotated and pinned the mast was just high enough the diamond wire was not touching the rear cross bar. I would then find someone to help me lift the mast. You do not have much leverage when the mast is just above your knees and you can not get under it because of the diamond wire. That is why I keep it at the club in mast up storage. If I had not found the mast up storage I would have gone with the gin pole by the guy listed above.
If you step your mast with the boat on the ground (rather than on the trailer), things are easier because since the boat is lower, the person (or step ladder) holding the top of the mast put the mast at a higher angle relative to horizontal. So you don't have to bend down as far to pick up the mast and you don't have to lift it through as great an arc. You can also place your beach wheels under the rear crossbar so that the boat has a bow-down position which makes it easier to hold the mast up once it's been raised (as recommended in a prior post).
for sure but dealing with the un-stepped mast and boat is a huge PITA too - unless you have a helper... and if you have a helper ... you don't need to do that anyway
Edited by MN3 on Jul 31, 2017 - 01:51 PM.
klozhald
tstein
Did he advertise on thebeachcats.com, or does he have a website?
this is Jon. I had the ad for the gin pole on this site for years and recently pulled it since it was getting pretty far down in the que. if you're interested in my system, contact me and i can send you the info.
thanks!
jon
(PS - thanks for the kind words Todd!)
Edited by arch on Aug 02, 2017 - 10:30 PM.
- 956 Online
