1975 hobie 16 trapeze setup
(@canadiancat)
Newby Registered
[#23353]
I have a 1975 hobie 16 and I'm installing the trapeze rigging. I need to know if, on the older models, the trapeze wires attach to the same D ring as the forestay and shrouds? All the diagrams I've seen have seem to have two rings but my mast seem to only have the hole for one.
Posted : August 7, 2008 1:19 pm
(@flatlander)
The mast tang (hound) was changed sometime after '75 to the current with an extra hole above to attach a shackle for double trapeze wires.
One set (single) of trapeze wires will work with your set up. You can hang a smaller shackle, on each side, if you are installing a double trapeze.
Posted : August 7, 2008 6:55 pm
(@canadiancat)
Newby Registered
Thanks that's what I needed to know
Posted : August 8, 2008 10:24 am
Cousin_Eddy
(@cousin_eddy)
How do you attach the smaller shackle? Drill thru the mast and use a thru bolt?
Posted : August 17, 2008 12:30 pm
(@ucosailor)
flatlander is referring to hanging the smaller shackles on either side of the main shackle that attaches the forestay and shrouds.
Posted : August 18, 2008 8:40 pm
(@banzilla)
Found it,
double trap, single hole tang
Posted : August 18, 2008 10:08 pm
