3" blocks too large for a 16?
Am considering purchasing the low profile blocks for my older H16. Factory comes with 2 1/4" I know. But while the 3" blocks are more expensive, is there an advantage to them (other than larger line that can move more freely through the blocks?). Or...are they a bit large for the 16, eliminating the advantage of low profile when raking the mast?
Thanks!
Posted : September 19, 2004 8:38 pm
Smaller is better these days. There is no need for 3" main blocks on a H16. 2 1/4" blocks give lower profile/better stack up, are less expensive and work well with a stock 3/8" dacron sheet. Even better is to downsize to a 5/16" spectra/polypro main sheet. If you really want to go crazy ($$) go to 40mm or 50mm carbon blocks with spectra/polypro or other "high tech" main sheet.
Posted : September 20, 2004 7:18 am
Forum Information
- 3,331 Online
Our newest member: wqaz
Latest Post: Hobie pearl / tiger mast needed
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
