Boat lift for Hobie 16
If the water is reasonably shallow (<4'), the simplest and perhaps least expensive option would probably be a perch.
You'd need four 6' augers, two ~9-10' cross bars, 4 t-brackets, and perhaps some bunks or carpet-covered wood if you plan to get on the boat while on the perch. For my 18 I use some PVC pipe over the rear crossbar as a type of roller and then trailer bunks on the front that take ~75% of the load.
I use tie-down straps on all 4 corners when not in use. My setup easily survived a 70+mph windstorm last Memorial day. A small boat lift would have tumbled (along with the boat) for sure.
Thank you very much for the tips. I really appreciate your generosity! <img src="<>/smile.gif" alt="smile" title="smile" height="15" width="15" />
- 3,337 Online
