creaky boat
2 Users
(@Anonymous 32191)
[#14147]
Boat is making lots of creaking noise.seems to be comming more from side bars.tramp is very tight,and boat sails relativly stiff.Is this noise usual and/or can it be fixed?
Posted : August 10, 2004 8:10 pm
(@Anonymous 2658)
There are 2 options for this:
A. if your boat is older than 5 years, it is time to replace it because the beam will break 😉
B. if your boat is new, this is normal sound of the boat that enjoys sailing. Nothing to worry about.
Fritz
Posted : August 10, 2004 8:48 pm
(@Anonymous 32191)
Beam will break?
not sure what you mean
where should I be looking for stress points
the hull has no soft spots
Posted : August 10, 2004 9:11 pm
 danb
(@danb)
i doubt your beam is about to break, my boat is an 81, its always been creaky and ive never had a prob. the annoying sound is probably friction between a beam and a corner casting. some of us glue our boats together with epoxy, i glued my 16. its quieter now.
Posted : August 11, 2004 1:23 pm
(@Anonymous 32191)
Found the problem.The shock cord for the righting system,which I had tied off on the dolfin striker,was way too tight.When I losend it off the creaking from the side rails disappeared.
Posted : August 24, 2004 8:55 pm
