H 16 jib question
Hobie 16 Forum
6
Posts
5
Users
0
Reactions
6,084
Views
My jib flaps and sounds like a motor boat or helicopter in moderate air. (15-20 kts.) My sails are old, not crisp. The boat is old too, hull number 2479 I think, but the spars are from a newer boat, black anodized, no comp tip. Should I use a higher hole in the plate in the lower rear corner of the jib or is all to do with how tight the jib sheet is set? I have been keeping the jib traveler cars way out by the corner castings.
Posted : July 15, 2008 8:12 am
I sail solo much of the time and leave the jib travelers in close to the mast. I seldom have them traveled out as far as you do except when going downwind. The jib shouldn't be acting the way you describe. Set it by the teltales the same way you would set the main, both sides streaming back.
Howard
Posted : July 15, 2008 10:17 am
Forum Information
- 704 Online
Our newest member: TooTallTom
Latest Post: Hobie pearl / tiger mast needed
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
